Cambridge 302 Problem
Old November 8th 12, 08:02 PM posted to rec.aviation.soaring
pat
Default Cambridge 302 Problem
My 302 won't go. When you turn it on it just starts up with "CAI 300"
on the LCD and thats as far as it goes. It did this a couple of times
last year but seemed to sort itself out after a while. This time its
well and truely stuck.
Any ideas?
Old November 8th 12, 08:56 PM posted to rec.aviation.soaring
One reason could be that there is a short in the temperature probe line. See if it will boot up after you remove the temperature line. The manual addresses this condition.
John
Old November 8th 12, 09:41 PM posted to rec.aviation.soaring
JohnDeRosa
On Nov 8, 2:56*pm, wrote:
One reason could be that there is a short in the temperature probe line. *See if it will boot up after you remove the temperature line. *The manual addresses this condition.
John
Another reason (also in the manual) is;
"B. The 302 LCD screen shows [300] [CAI] but nothing else.
Disconnect any devices on the “CAI Bus” such as the 303-NAV or 306 DDV
repeater. If the
302 is then OK, check cables and connectors. If the problem persists,
the DDV main
processor has failed. Return the instrument to your dealer for
service."
If you have a 303 (pretty common) or a 306 (rare) it could very well
be the cables. These use "phone" connectors (RJ). These are fairly
robust but in our bumpy environment get loose, corroded, etc,
especially when repeatedly removed/inserted. Disconnect and inspect
them. Replace where needed. If this is the case contact me and I can
make you what you need.
Old November 9th 12, 12:51 AM posted to rec.aviation.soaring
Andrzej Kobus
Any ideas?
Try to switch Serial - USB switch a couple of times. Switch to USB
boot it and then shut it down and switch back to Serial and boot it
again.
Old November 9th 12, 06:33 AM posted to rec.aviation.soaring
Mark Tyrrell
Any ideas?
again.
Thanks for the imput guys!
Cambridge GPS NAV problem, need help Morteza Ansari Soaring 12 July 15th 14 08:23 PM
Cambridge 302 Problem - Help Leroy Tire Soaring 2 August 8th 10 05:05 PM
Cambridge 302 problem..HELP Please Colin Milner Soaring 0 July 20th 09 07:15 PM
Cambridge 302 problem..HELP Please Robert Holliday Soaring 11 June 25th 09 02:15 PM
Cambridge 302 problem..HELP Please Andy[_10_] Soaring 2 June 24th 09 09:21 PM
