Tow Pilot Checkouts, Rough-Field Tri-Gears?
Old November 13th 12, 12:28 AM posted to rec.aviation.soaring
noel.wade
Default Tow Pilot Checkouts, Rough-Field Tri-Gears?
All -
Do any of the USA folks here on RAS operate in a club without a 2-seat
towplane? If so, how do you check out new towpilots? Do you find
simulated towing acceptable training?
On a related topic: Given the dearth of Robins in the USA for tri-gear
towing, does anyone have suggestions on a tri-gear towplane that can
operate out of a rough grass strip? We now land on asphalt, but our
takeoff area has some broad swales and occasional mole-holes. It has
spawned legends of bent Cessna firewalls; so a 180 or 182 seems to be
out of the running. Any alternatives out there that are capable of
hauling up a loaded 2-seater like a G-103 or L-23?
Thanks,
--Noel
Old November 13th 12, 01:00 AM posted to rec.aviation.soaring
Tim Taylor
On Nov 12, 5:28*pm, "noel.wade" wrote:
All -
towplane? *If so, how do you check out new towpilots? *Do you find
operate out of a rough grass strip? *We now land on asphalt, but our
takeoff area has some broad swales and occasional mole-holes. *It has
out of the running. *Any alternatives out there that are capable of
Thanks,
--Noel
Socata Rallye, one for sale here in Logan I think.
Old November 13th 12, 02:02 AM posted to rec.aviation.soaring
Paul T[_4_]
At 01:00 13 November 2012, Tim Taylor wrote:
On Nov 12, 5:28=A0pm, "noel.wade" wrote:
All -
towplane? =A0If so, how do you check out new towpilots? =A0Do you find
operate out of a rough grass strip? =A0We now land on asphalt, but our
takeoff area has some broad swales and occasional mole-holes. =A0It has
out of the running. =A0Any alternatives out there that are capable of
Thanks,
--Noel
Varga Kachina, Maule?
Old November 13th 12, 02:15 AM posted to rec.aviation.soaring
T[_2_]
On Nov 12, 4:28*pm, "noel.wade" wrote:
All -
Thanks,
--Noel
Any airplane is going to have problems with runways with mole holes,
you can drop a main tire into the hole as easily as nose wheels or
tail wheels.
A C180 is a taildragger, a C182 a nose dragger. So why is the 180 out
of the running?
We have a single seat Pawnee for towing, best tow plane made, Piper
Pawnees. Simulated tow training works, we've used Super Cub,
Decathlon, and C170 for training. First three tow flights for the new
tow pilot, a CFIG is in the glider, first tow is normal, 2nd tow,
worst student you can be, moving all around and box wake and slack
line training. 3rd flight, pattern tow. Followed by critique and
question/answer session.
A good tow plane? Depending on where you are and density altitude
issues. C150 with 150HP or better. C182 if light weight, high DA
you'll not want full fuel. Super cub with 180HP. Scout.
T
Gear Up, pt 7 - pilot Howard Hughes in a ploughed field.jpg (1/1) Mitchell Holman Aviation Photos 0 April 20th 07 02:21 PM
Rough Field Landings [email protected] Piloting 38 December 19th 04 01:42 PM
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) Kyler Laird General Aviation 0 March 1st 04 12:11 AM
J-3 Checkouts/vacations Dave Owning 9 August 14th 03 10:32 PM
J-3 Checkouts/vacations Dave Owning 4 August 11th 03 02:07 AM
