I've just finished machining my instrument panel. It is (I say with
no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? |
In Richard Riley wrote:
I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? I think I would rather have a matte finish on mine, but ya gotta admit that Pat Fagan's engine turned panel is a thing of beauty: http://www.airbum.com/pireps/PirepPatFaganBH.html ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
Here's my experience with Anodizing. I liked it a lot.
http://www.eaa292.org/noon_patrol/dec_00/p1010006.jpg Richard Riley wrote: I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? -- John Kimmel I think it will be quiet around here now. So long. |
Well, mine started out as just a plain piece of 0.125 aluminum and I used a
fly cutter to cut out the instrument holes and I went to Menards (Home Depot-like place) and bought countertop laminate to put over it. Drilled through a few instrument mounting screw holes and used machine screws and nuts to keep it in place and used a laminate cutting bit in my dremel to "rout" out the instrument holes. Worked really nice. Do not glue the laminate to the aluminum, just use the instrument and panel mounting holes to keep the laminate in place. I have an open cockpit plane, so laminate is good incase it rains while I'm at a fly in. -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die "Richard Riley" wrote in message ... I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? |
Depot-like place) and bought countertop laminate to put over it. Holy smokes! what a great idea! Wish the hell I thought of that. Besides durable and cheap just think of the choice of finishes. Did you use a wood grain theme or something like that? Jim |
On Sun, 01 Feb 2004 21:52:15 -0800, Richard Riley
wrote: I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? A flat finish is helpful for reducing glare on an instrument panel, so I definitely would not go with polished. -Nathan |
3 inches thick down to 0.120 ??!!!
How long did it take to machine? Can you post a link to a photo? thanks Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. |
![]() "Richard Riley" wrote in message ... I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? Alodine it and then put up a frilly little placard that says 24K. It would be reminiscent of you. |
" jls" wrote: "Richard Riley" wrote in message ... I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? Alodine it and then put up a frilly little placard that says 24K. It would be reminiscent of you. If you first polish it, then dip it in alodyne, it will look like a piece of gold jewelry. |
... I've just finished machining my instrument panel. It is (I say with no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120 with .120 webs between each instrument and around the perimeter. Now the question is: how should it be finished? Polished? Engine turned? Anodized? Clear powder coat? Engine-turned then clear powder coat. Yeah, that's what I'd do. |
Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 02:41 AM |
Instrument panel labelling options | John Galban | Home Built | 12 | November 18th 04 10:42 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
Aluminum instrument panel finish? | Richard Riley | Home Built | 31 | February 4th 04 02:09 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
