Everything will eventually be electric
Old December 12th 12, 01:51 PM posted to rec.aviation.piloting
Mark IV[_6_]
Default Everything will eventually be electric
World's fastest electric plane. (so far )
http://www.youtube.com/watch?v=rNAPLxZtoPg
http://www.flightofthecentury.com/long-esa/
Motor-Trend, Car of the Year is Electric:
http://abcnews.go.com/blogs/business...r-of-the-year/
400wh/kg is achieved:
http://enviasystems.com/technology/
(They already know how to produce
1500wh/kg. It is forthcoming.)
Thin-gap electric motors, Amazing:
http://www.thingap.com/products/index.htm
http://www.youtube.com/watch?v=y10o9...=results_video
Other aviation electric motor specialties:
http://www.yuneec.com/PowerMotor_Tech_spec.html
Plane with built-in solar panels:
http://inhabitat.com/elektra-one-sol...rging-trailer/
(Actually, the entire surface...both top and
bottom should be covered in photovoltaics)
Mark
Old December 12th 12, 05:29 PM posted to rec.aviation.piloting
From the article:
"Following the record run, a cell inside the pack became damaged and Chip
executed a "priority landing" with no power, at Inyokern's 7,100 foot long
runway 33."
You also have to go far.
Priced at a mere $49,900 to $97,900.
Gasoline is 13,000 WH/kg; only an order of magnitude short.
"ThinGap Embedded Motors are not well-suited to low-speed or "traction"
applications.."
Can't pull the bass boat up a hill.
For flying inverted?
On a clear day with your panels at 90 degrees to the Sun you get about
1 kW/square meter.
With the panels at 45 degrees to the Sun you get about 700 W/square meter.
Be sure to land well before dusk.
Old December 12th 12, 05:36 PM posted to rec.aviation.piloting
Orval Fairbairn
In article
http://abcnews.go.com/blogs/business...-motor-trends-
car-of-the-year/
http://inhabitat.com/elektra-one-sol...own-photovolta
ic-charging-trailer/
Mark
"Everything will eventually be electric?" I don't think so! Unless
someone can come up with something like the sci-fi "zero point module,"
"dilithium crystals" or some other means of storing large amounts of
energy in small, lightweight packages, it won't.
Batteries, which must store the equivalent of fuel *and oxidizer* will
always be deficient here. For gasoline engines, the ratio is 15:1 by
weight of oxidizer/fuel.
It isn't the motors, but the energy source which fails.
Old December 12th 12, 07:37 PM posted to rec.aviation.piloting
george152
And how would such a machine fit into an average fleet of training
aircraft ?
Most of the day it would be out either being recharged or having the
battery pack replaced.
And range.
Any landings and refuelling away from base would have to take account of
facilities at the destination..
At the moment it sounds far to complex to return revenue
There was one electric powered aircraft in the 30s that looked great but
could only fly circuits..
Old December 12th 12, 09:33 PM posted to rec.aviation.piloting
Orval Fairbairn
aircraft ?
And range.
Did it have a very LONG extension cord?
Old December 13th 12, 04:23 AM posted to rec.aviation.piloting
george152
aircraft ?
And range.
No but it did have a very large lead battery
Old December 13th 12, 12:46 AM posted to rec.aviation.piloting
Vaughn
aircraft ?
Training is all about economics, and the economics for battery powered
aircraft (or virtually any new aircraft) for the training market simply
aren't there...and may never be.
Not necessarily so. You could have quick change battery packs that
presumably would take no longer to swap than it takes to refuel a plane.
However, that would require multiple battery packs, so economics rears
it's ugly head again.
And range.
Quickly improving. A few electric models are plenty good enough for
sport use today.
As they always have...
Complex? Nonsense! Electric planes can be quite simple compared to an
equivalent IC plane.
Return revenue? You mean economics? That's another matter! It's
actually the real issue, and perhaps the deal killer.
Your point?
Old December 13th 12, 01:40 AM posted to rec.aviation.piloting
aircraft ?
And range.
sport use today.
Your point?
The real problem for for any vehicle application is charge time which
is limited by basic physics and how much power you can get down a wire
and through a practical connector.
Say you have the equivelent electric airplane of your typical bug smasher
that has 180 HP and runs at 75% power.
Neglecting any losses and conversion efficiencies, which just make the
numbers worse:
That is 180 X .75 X 745.7 = approximetely 100 kW.
If you fly for 3 hours you use 300 kWH.
Assume the battery voltage is 100 V, which is a rather ballpark typical
value for an electrical vehicle, you have to supply 3 kAH to charge the
battery.
If you want to charge the battery in a half hour, your cable and connectors
must carry 6,000 Amps.
Increase the battery voltage to 200 V and an hour charge time and you still
have to carry 1,500 Amps.
FS: Electric tow Bug Dout General Aviation 0 October 16th 10 06:27 PM
Hawker Kestrel - led eventually to the Harrier jd Aviation Photos 0 April 25th 09 07:10 PM
Where old planes go to die (eventually) Kingfish Piloting 3 May 14th 07 04:40 AM
Electric DG Robbie S. Owning 0 March 19th 05 03:20 AM
Electric Vehicle sanman Home Built 3 May 24th 04 07:08 PM
