mission requirements
250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude doable? |
On Tue, 10 Feb 2004 15:21:50 -0500, tongaloa
wrote: mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude doable? Sure. As long as the 'stuff" does not include fuel; and if size, weight, and cost are not important to you. BTW, range is not expressed in 'kt'. A Cessna 421 may be just about right for you. Sounds like a troll, but I an responding anyway. O-ring Seals |
"O-ring Seals" wrote in message
... On Tue, 10 Feb 2004 15:21:50 -0500, tongaloa wrote: mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude doable? Sure. As long as the 'stuff" does not include fuel; and if size, weight, and cost are not important to you. BTW, range is not expressed in 'kt'. A Cessna 421 may be just about right for you. Sounds like a troll, but I an responding anyway. O-ring Seals Hey Bob........ How 'bout strapping a saddle on a V-1 or a Baka Bomb??? Rich S. |
O-ring Seals wrote:
On Tue, 10 Feb 2004 15:21:50 -0500, tongaloa wrote: mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude doable? Sure. As long as the 'stuff" does not include fuel; and if size, weight, and cost are not important to you. BTW, range is not expressed in 'kt'. A Cessna 421 may be just about right for you. Sounds like a troll, but I an responding anyway. O-ring Seals Not a troll. Living in HI and wanting to travel in Pacific. Size and weight are considerations, hence the 250lb limit for pilot and 'stuff'(change of cloths, some tools, water, oil). Fuel efficiency is a consideration with Pacific prices. Speed and range matter for say HNL-NSTU-FUN. Fuel is often not available at FUN. -t |
Earlier, tongaloa wrote:
mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude doable? Sure. For about $250,000. ![]() Bob K. |
mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude The 2500 mile range is likely doable, after all, Lindbergh managed it with 1927 technology. What he did was take an airplane and modify it so that it was a flying gas tank. That required a number of modifications to the original airframe to beef it up so it would hold that much gas and not collaps when landing or clap the wings in turbulence. He also had a gas tank in front of him such that it totally blocked any view straight ahead. He compensated for that but hanging his head out the open window. Not something I'd recommend at 25,000 feet. You've heard of the Voyager, Dick Rutan and Jeanna Yeager flew it around the world with what they carried internally for gas. That was a one off type airplane, and Burt Rutan has designed another to duplicate the feat, this time jet powered and it will fly a lot higher and faster than the Voyager. The 25000 mile cruise altitude is of course obtainable, you just need to size the wings accordingly and supercharge the engine somehow. It's not new, it's done all the time by certified airframe manufacturers. You'll need full time oxygen at that altitude, and a lot of it if you are traveling 2,500 miles. The big problem to me is the 250 kt cruise speed. There aren't many singles that can manage that, those that do are running a pretty big or they aren't big or both. Pretty big engines pulling an airplane along at 250 kts don't get great milage, but perhaps that can be compensated for by putting in enough fuel tanks. But then the wings get larger and cost more drag and you have to beef up the airframe in order to be safe and now you need more power to pull it through the air. Tis a dilemma. You are probably talking about a one-off type airplane. Maybe you should speak with Mr. Rutan. Corky Scott |
Corky Scott wrote:
rlier, tongaloa wrote: mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude The 2500 mile range is likely doable, after all, Lindbergh managed it with 1927 technology. What he did was take an airplane and modify it so that it was a flying gas tank. That required a number of modifications to the original airframe to beef it up so it would hold that much gas and not collaps when landing or clap the wings in turbulence. He also had a gas tank in front of him such that it totally blocked any view straight ahead. He compensated for that but hanging his head out the open window. Not something I'd recommend at 25,000 feet. You've heard of the Voyager, Dick Rutan and Jeanna Yeager flew it around the world with what they carried internally for gas. That was a one off type airplane, and Burt Rutan has designed another to duplicate the feat, this time jet powered and it will fly a lot higher and faster than the Voyager. The 25000 mile cruise altitude is of course obtainable, you just need to size the wings accordingly and supercharge the engine somehow. It's not new, it's done all the time by certified airframe manufacturers. You'll need full time oxygen at that altitude, and a lot of it if you are traveling 2,500 miles. The big problem to me is the 250 kt cruise speed. There aren't many singles that can manage that, those that do are running a pretty big or they aren't big or both. Pretty big engines pulling an airplane along at 250 kts don't get great milage, but perhaps that can compensated for by putting in enough fuel tanks. But then the wings get larger and cost more drag and you have to beef up the airframe in order to be safe and now you need more power to pull it through the air. Tis a dilemma. You are probably talking about a one-off type airplane. Maybe you should speak with Mr. Rutan. Corky Scott Well maybe, since I can't speak to Ted Smith. Was posting in the event that someone might have done some paper scratching and cared to reveal. -t |
"Corky Scott" wrote mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude You are probably talking about a one-off type airplane. Maybe you should speak with Mr. Rutan. Corky Scott How about a CJ, or a falcon? -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.580 / Virus Database: 367 - Release Date: 2/6/04 |
wrote: mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude 250kt cruise is really pushing it in a piston engined airplane. A 421 can max out at 250kts, but cruise will be more like 220-230kt. The only exception might be a Lancair IV-P and this was posted to the homebuilt newsgroup, so that's a thought. 2500nm range is not do-able in any production light aircraft, and for that matter probably isn't do-able in any reasonable homebuilt aircraft. Many corporate jets do not have that kind of range. 250 lb useful load is easy - any plane that comes close to the other specs will have this useful load. 25000 cruise altitude is attainable via turbocharged engines, and will likely be a requirement to hit 250kt cruise. -Nathan |
Nathan Young wrote:
On Tue, 10 Feb 2004 15:21:50 -0500, tongaloa wrote: mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude 250kt cruise is really pushing it in a piston engined airplane. A 421 can max out at 250kts, but cruise will be more like 220-230kt. The only exception might be a Lancair IV-P and this was posted to the homebuilt newsgroup, so that's a thought. Will have a look. Aerostar does 250kt OK at 25000. TIO 540's. Range is limited by 38-42GPH and gross - empty = 2000 lb. Looking for single that can do the 250kt and max gross - empty = big enough number for fuel plus 250lb. |
| Pitts Number 1 registration number | Mirco | Aerobatics | 3 | December 4th 04 12:50 PM |
| TrueType N number Font? | Errol Groff | Home Built | 3 | November 21st 03 02:43 PM |
| Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 06:39 AM |
| ZZZooommm rant latest | Kyle Boatright | Home Built | 181 | September 19th 03 04:30 AM |
| Phone number for Dillsberg? | Robert Bonomi | Home Built | 2 | September 10th 03 12:17 AM |
