PowerFLARM core external display software update
Old January 26th 13, 06:00 PM posted to rec.aviation.soaring
kirk.stant
Default PowerFLARM core external display software update
For US PowerFLARM, does software 2.6 in the core now allow updating the external Butterfly display without having to use a special cable?
Kirk
66
Old January 26th 13, 06:25 PM posted to rec.aviation.soaring
Dave Nadler
Not in 2.6. In 2.74 Alpha test; worked for me a couple
days ago. Not sure the release schedule but its coming...
See ya, Dave "YO electric"
Old January 26th 13, 06:30 PM posted to rec.aviation.soaring
kirk.stant
So 4Q 2012 is on the Mayan calendar... ;^)
Is there a non-beta 2.6 released yet?
Cheers,
Kirk
66
Old January 26th 13, 07:02 PM posted to rec.aviation.soaring
kirk.stant
Another configuration question:
Is the following PCAS setting still needed in 2.6 beta:
# configure PCAS sensitivity test setting
$ADSB,CONFIGURE,MTLAC,300
The current configuration tool on the PF website does not include this in a FLARMCFG.TXT file.
Also, the max PCAS range is 7.5 km (about 4.7 miles) on the tool. Max range used to be 9620m, which is almost 6 miles. Which is correct, or does it make any difference?
Kirk
66
Old January 28th 13, 09:36 PM posted to rec.aviation.soaring
Andy[_1_]
Also, the max PCAS range is 7.5 km (about 4.7 miles) on the tool. *Max range used to be 9620m, which is almost 6 miles. *Which is correct, or does it make any difference?
Kirk
66
Since the PCAS function doesn't work (at least not well enough to
replace a Zaon MRX) it makes no difference.
Andy
Old January 28th 13, 09:56 PM posted to rec.aviation.soaring
seems to work for me. Albeit, I only tried it out at aguila but got two hits on a helo and power plane about 3 miles south while parked on my ramp
Butterfly external display questions Andy[_1_] Soaring 30 October 15th 12 08:20 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
New PowerFLARM display? Andy[_1_] Soaring 1 November 23rd 11 11:04 PM
PowerFLARM Display Update Paul Remde Soaring 2 November 11th 10 07:40 PM
Q: Apple MAC Book (pro) with Intel core 2 duo running Windows XP plus soaring software Ruud Soaring 1 October 31st 06 02:02 AM
