The St Louis Soaring Association is interested in setting up a winch demo for our members at our field (H07) in Highland, Illinois. Are there any clubs with winches within reasonable distance that are willing to give us a demo, and possibly give ground launch endorsements?
Our club is in the middle of discussions on the feasibility of acquiring and employing a winch, for both cost and membership attraction. If interested, please contact me directly, at kirk dot stant at gmail dot com. Kirk 66 |
On Tuesday, January 29, 2013 9:43:08 AM UTC-7, kirk.stant wrote:
The St Louis Soaring Association is interested in setting up a winch demo for our members at our field (H07) in Highland, Illinois. Are there any clubs with winches within reasonable distance that are willing to give us a demo, and possibly give ground launch endorsements? Our club is in the middle of discussions on the feasibility of acquiring and employing a winch, for both cost and membership attraction. If interested, please contact me directly, at kirk dot stant at gmail dot com. Kirk 66 Hire Don Ingraham from Cross Country Soaring in Minnesota. However, unless SLSA owns the land between John Dr and I-70, you are about 500ft short of a practical length. If you can stage near I-70, it'll definitely work. If you don't own it, perhaps you can lease a path through the field. Doesn't have to be too wide, but you'd only be able to launch to the north. Frank Whiteley |
Frank,
Thanks for the info. Yes, SLSA owns the land all the way to I-70, and we have discussed what we would need to do to use it for winch launching - at a minimum a path for the winch cable, to extending the runway as necessary. So our useable field length extends from IL 40 to the south (the displaced threshold) to I-70 to the north. Not ideal, but OK, and we normally launch to the North. Kirk |
On Wednesday, January 30, 2013 5:57:19 AM UTC-7, kirk.stant wrote:
Frank, Thanks for the info. Yes, SLSA owns the land all the way to I-70, and we have discussed what we would need to do to use it for winch launching - at a minimum a path for the winch cable, to extending the runway as necessary.. So our useable field length extends from IL 40 to the south (the displaced threshold) to I-70 to the north. Not ideal, but OK, and we normally launch to the North. Kirk With a stout winch and good technique, 1500-1600ft launches would be doable on a regular basis, higher possible, especially with 8-10kts of headwind. Don's winch sports a 350cid Corvette motor. Check out the video and pictures at www.crosscountrysoaring.com. If you do this, develop a cadre of good winch drivers. You don't expect all members to fly the tug, don't expect everyone to drive the winch. Others can help with rope retrieves and as launch marshals. Then spend some of that flight scholarship money on youth. Frank |
Hi, you mention making a pathway as part of the take-off zone. This needs
to be not too narrow. As a worst case scenario you need to allow dropping space for the cable in the event of a winch stoppage, such as it jumping out of gear (as happened to me once at 50ft.). The cable with drouge chute will travel almost 45 degrees from it's release point in even the slightest cross-wind. Trying to retrieve the cable from a tree usually results in damage to the drouge and to the tree. Also you need to factor this dropping zone into the equation if you are near any roads. (is I-70 a busy main road?) Pete (UK) At 15:56 30 January 2013, Frank Whiteley wrote: On Wednesday, January 30, 2013 5:57:19 AM UTC-7, kirk.stant wrote: Frank, =20 =20 =20 Thanks for the info. Yes, SLSA owns the land all the way to I-70, and we= have discussed what we would need to do to use it for winch launching - at= a minimum a path for the winch cable, to extending the runway as necessary= .. So our useable field length extends from IL 40 to the south (the displace= d threshold) to I-70 to the north. Not ideal, but OK, and we normally laun= ch to the North. =20 =20 =20 Kirk With a stout winch and good technique, 1500-1600ft launches would be doable= on a regular basis, higher possible, especially with 8-10kts of headwind. Don's winch sports a 350cid Corvette motor. Check out the video and pictur= es at www.crosscountrysoaring.com. If you do this, develop a cadre of good winch drivers. You don't expect al= l members to fly the tug, don't expect everyone to drive the winch. Others= can help with rope retrieves and as launch marshals. Then spend some of t= hat flight scholarship money on youth. Frank |
On Fri, 01 Feb 2013 11:21:25 +0000, Peter Higgs wrote:
Hi, you mention making a pathway as part of the take-off zone. This needs to be not too narrow. As a worst case scenario you need to allow dropping space for the cable in the event of a winch stoppage, such as it jumping out of gear (as happened to me once at 50ft.). The cable with drouge chute will travel almost 45 degrees from it's release point in even the slightest cross-wind. Trying to retrieve the cable from a tree usually results in damage to the drouge and to the tree. W"inching 101: NEVER try to retrieve a cable that's off the field by pulling with the winch. Send the cable truck down with a bod or two to manually get the cable back on the field and then pull it in slowly. If the drogue starts to fly there's every chance that the cross wind that dropped it off the field in the first place will take it off the field again. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
At 16:43 29 January 2013, kirk.stant wrote:
The St Louis Soaring Association is interested in setting up a winch demo Kirk, You probably know this but the BGA has a good web page on winch launching safety at: http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm Bryan |
I recall years ago when a soaring club in Colorado, USA dropped the winch
cable across overhead power lines. It started quite a grass fire! "Bryan Poehler" wrote in message ... At 16:43 29 January 2013, kirk.stant wrote: The St Louis Soaring Association is interested in setting up a winch demo Kirk, You probably know this but the BGA has a good web page on winch launching safety at: http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm Bryan |
And naysayers please note you cannot short power lines or cause a spark with modern spectra line. Ya for technology. Karen
On Friday, February 1, 2013 9:48:52 AM UTC-7, wrote:
And naysayers please note you cannot short power lines or cause a spark with modern spectra line. Ya for technology. Karen Thanks, Karen. That's absolutely true. Among its many other superb attributes, UHMWPE is one of the best dielectric materials. When making off field rope recoveries, often the best solution is to cut the rope wherever it's convenient to do so and bring it back in bundles. Trying to get it back in one piece can be more trouble than splicing it back together again. Plastic rope weighs so little one person can carry it all. If you have some drawstring canvas bags, just dumping the rope into the bag hand over hand results in being able to just pull it out again without tangles. Making rope coils cowboy-style does tend to produce tangles. When you get it back on the field, spend some time figuring out why the winch couldn't pull it all in before it got off field. This is not a problem which should happen if everything is working right. |
(Fokker D-VIII Demo Index 1.jpg (0/1)] [01/24] - Fantasy of Flight Fokker D-VII demo | Indrek[_4_] | Aviation Photos | 3 | April 3rd 12 12:04 AM |
(Fokker D-VIII demo index 2.jpg (1/1)] [02/24] - Fantasy of Flight Fokker D-VII demo | Indrek[_4_] | Aviation Photos | 0 | April 2nd 12 05:47 PM |
Best winch metrics - what is the best winch operationally? | Bruce | Soaring | 19 | July 19th 09 11:45 AM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Winch Experts wanted | Ulrich Neumann | Soaring | 117 | April 5th 04 06:52 AM |
