Hangar dolly for heavy glider
Old February 28th 13, 03:22 PM posted to rec.aviation.soaring
Dave Nadler
Default Hangar dolly for heavy glider
I have a customer looking for hangar dolly for heavy
glider (Antares). Anything that works for Duo, Arcs,
DG-500/1000, or similar will probably work. Anybody
know of commercial fabricators of such things, or
a used one available ?
Thanks,
Best Regards, Dave
Old February 28th 13, 03:29 PM posted to rec.aviation.soaring
Dave Nadler
Anybody ever used either of these ?
http://www.pacificaerosport.com/products.htm
http://www.zendextool.com/gojak/
Old February 28th 13, 03:55 PM posted to rec.aviation.soaring
Peter von Tresckow
The gojack works great on trailers but I've never used it on a glider. It
would probably work but you do need some free space for the foot pedal.
Pete
Old February 28th 13, 04:45 PM posted to rec.aviation.soaring
Renny[_2_]
Dave,
I have the dolly from Pacific Aerosport and it works great for my LAK-17B FES which has an empty weight of 752 lbs. Would it work for 900 lbs? My guess is "yes," but you may want to call them to confirm....
Thx - Renny
Old February 28th 13, 09:58 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
$80 at Harbor Freight - #67287
No idea about the quality.
email me)
Old March 3rd 13, 07:13 AM posted to rec.aviation.soaring
bumper[_4_]
Like their previous hydraulic wheel dolly (which I've read is prone to leak), the mechanical #67287 has pick up rollers that will be too far apart at their minimum distance (13.5" center to center) to pick up glider wheels. The jack would need to modified by cutting off the mount (or making a new one) and welding it back on so it's closer to the movable roller.
Old February 28th 13, 04:35 PM posted to rec.aviation.soaring
Dave Nadler
Additional info: 900 lb weight on main-wheel...
Old February 28th 13, 04:52 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Tim Mara sells a version of the GoJack. You will notice from the pictures on his site and the ones direct from the GoJack site that the jack is tilted on the glider version, to get the lever out away from the fuselage.
I haven't used either, so I can't say anything about the functionality or durability. The big advantage of the GoJack is that you don't have to push the glider onto it. You park the glider, bring the dolly up to it, pick the glider up with the dolly, and off you go.
Steve
Old February 28th 13, 10:47 PM posted to rec.aviation.soaring
Dave Nadler
Us cool pilots don't push gliders, we taxi under electric power ;-)
Old February 28th 13, 11:01 PM posted to rec.aviation.soaring
Tim Mara
I have them here
http://www.wingsandwheels.com/page46.htm
tim
"Dave Nadler" wrote in message
Thanks,
Best Regards, Dave
Glider Main Wheel Dolly Jim[_18_] Soaring 0 March 9th 11 04:19 PM
ETA glider landing with heavy front wind in Rieti, videoclip PCool Soaring 2 October 1st 09 03:10 PM
Glider Hangar Tie-Downs V1 Soaring 0 March 19th 09 02:09 PM
Club Glider Hangar? noel.wade Soaring 33 January 14th 08 10:47 PM
Ideal Glider Hangar Dimensions SGS135 Soaring 3 November 27th 04 11:04 PM
