Aircraft takes off with no pilot...because of wind.
Old March 16th 13, 09:03 PM posted to rec.aviation.soaring
Jeremy Keeling
Default Aircraft takes off with no pilot...because of wind.
A stationary aircraft with no pilot inside took off because of nothing but
a stiff breeze...lessons to be learned...
http://video.uk.msn.com/watch/video/...keoff/886gu2cd
Old March 16th 13, 10:14 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
One lesson might be "don't park it with full up elevator". It's strange
to me a camera would be focused on such a small area, unless it was an
intentional event.
email me)
Old March 16th 13, 11:30 PM posted to rec.aviation.soaring
Sean F (F2)
Thats hilarious! thanks for sharing!
Old March 17th 13, 01:54 AM posted to rec.aviation.soaring
Ralph Jones[_3_]
On Sat, 16 Mar 2013 14:14:55 -0700, Eric Greenwell
intentional event.
Intentional indeed. I'd say it's a model.
Old March 17th 13, 03:08 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
but a stiff breeze...lessons to be learned...
intentional event.
Agreed. It doesn't look windy enough, judging from the way the scenery
isn't waving (much), to lift even quite a light GA aircraft. Nothing is
really moving apart from a bit of dust. And what about that wing being
picked up just after it lifted off: natural stability or a crafty twitch
on the sticks?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 17th 13, 03:25 AM posted to rec.aviation.soaring
Jeremy Keeling
but
intentional event.
Actually this business about parking with full elevator is a good one.
Some clubs I know are very good, in my opinion, in that they do up the
pilots harness around the joystick after landing in order to hold it in a
back position (full up elevator) so that as the glider is being towed back
to the launch point the control surfaces don't 'clunk around' etc. I think
this is a good idea, but typically what happened as the aircraft got back
to the launch point is that they would be lined up for launch, into wind
ofcourse, with full elevator still on. It seems to me to be a good point
about not leaving aircraft parked with full elevator, particularly into
wind.
Definetly a lesson to be learned there...
I don't think the aircraft is a model haha, look at the relative size of
everything around it.
It seems to me that the CCTV camera would be looking towards an aircraft
parking area maybe? Or perhaps the other aircraft that were there had
already been tossed over and the person fetched his camera to catch the
last one...I dunno.
Old March 17th 13, 07:42 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
nothing
but
intentional event.
back
think
wind.
last one...I dunno.
Up elevator only matters on a nose-wheel aircraft. Most empty gliders sit
with the tail-wheel or skid on the ground so elevator position is almost
irrelevant.
Old March 17th 13, 07:17 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
last one...I dunno.
irrelevant.
The comparable glider errors I see are leaving the tail dolly attached
to an unattended, unsecured glider; not putting the flaps into full
negative; and not turning the glider perpendicular to the wind.
email me)
Old March 19th 13, 05:16 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
irrelevant.
Oh, how not true, Chris! Elevator position ALWAYS matters. And in fact, nose down is where the elevator should be when the glider is unattended. Why? Wind comes up from the nose, the elevator will raise the tail if the wind is high enough, reducing the angle of attack and making it less likely that the plane will blow away. Wind comes up from behind, it will keep the tail pinned to the ground. Same applies to both nose dragger and tail dragger planes. How many have seen single engine Cessnas blown over by a wind from behind because the tail was not secured and the control wheel was held back? I have seen quite a number.
And depending on the tail wheel, nose up elevator can help compress a tailwheel leaf spring increasing the angle of attack and make the plane more likely to blow away. Think 2-33s and the long, slender single leaf springs.
Steve Leonard
Old March 19th 13, 01:02 AM posted to rec.aviation.soaring
Nah, this looks like the real thing to me. Most every model will not have the protrusions like pitot and antenna you see here underneath unless they are the very top end scale ($$$) jobs which are rare. ARF manufacturers wont supply these details since they'll break off right away when you remove the wings for transport.
Win Pilot Wind readout RDC Soaring 0 June 9th 09 04:47 AM
Another great olde aircraft takes to the air Marine Airdale Naval Aviation 0 April 17th 09 12:33 AM
X-48B Blended Wing Body Research Aircraft Takes First Flight [1 attachment] §qu@re Wheels[_4_] Aviation Photos 5 July 30th 07 07:17 AM
Wind limits - small single engine aircraft [email protected] Piloting 30 February 7th 07 08:36 AM
See if you have what it takes to be a pilot !!! Dave Kearton Aviation Photos 24 January 7th 07 10:59 AM
