Power settings for 182RG
Old March 1st 04, 04:14 AM
Andrew Gideon
Default Power settings for 182RG
I've been going over the POH, remembering the various procedures and
settings. But something I've taken for granted in the 172s I've been
flying up until now is missing: power settings for the pattern.
You know: 1800 RPM and 10 on the flaps for midfield downwind, 1500 and 85
kts and descending past the numbers, etc.
So...anyone have numbers to share for a 182 retract? I know that they're
just a framework, but I'm at the point where a framework would be helpful.
- Andrew
Old March 1st 04, 06:09 AM
john smith
85 KNOTS OVER THE NUMBERS!!!
How far down the runway do you float before the wheels contact?
I would use 65 knots, 70 knots max, over the numbers and throttle fully
closed.
In a straight leg 182(Q/R/S), I try to be at 55 kts over the numbers at
gross (3100 lbs), reducing appropriately for lower weights.
Old March 1st 04, 06:46 AM
Craig Prouse
In article , john smith
closed.
Andrew never said "over" the numbers. He said "descending past" the
numbers, which if you interpret that as "abeam" the numbers, what he
said makes perfect sense. Choosing a power setting for short final is
not very interesting, after all, and the final approach speed is right
there on the checklist. I think it's the rest of the traffic pattern
that he's asking about.
I like to keep my speed down in the pattern so as to fit in nicely with
all the Warriors and Citabrias. I'd think that a C182 RG would fly
about the same as my C182S once the gear is down; if so, a starting
place might be this:
downwind, 90 kts
gear down, flaps 10, 17-18" MP, 2100 RPM
abeam the numbers
reduce power to 13-14" MP
turning base
flaps 20, 80 kts
turning final
flaps 30, 70 kts, mixture/prop
Andrew, a hint that helped me a lot... Once you get the chance to go
work out your power settings for instrument approaches at 90 and 100
kts, you can just use the same configurations and power settings in the
pattern that you would use when flying an approach. After all, flying
downwind is just like flying level at MDA, and that power reduction
abeam the numbers is just the same as initiating a nonprecision descent.
Close enough anyway. No point in memorizing more different procedures
and sets of numbers than necessary.
Old March 1st 04, 03:15 PM
Those are just about the numbers I use, and they work well for the RG.
17-18" @ 2100 rpms, 100 entering downwind, drop the gear, and 10 degrees of
flaps. If you do them both at once, no need to re trim and it will slow you
to 90, GUMPS, remember, you can look out the window and see at least one
wheel down
abeam reduce power, 14"-15", as it slows the prop can come in all the way
1500 rpms on base should give you about 80kts, flaps go to 20, GUMPS
30 degrees of flaps and 70 on final, 40 degrees if you need to drop in
steep, GUMPS
55-60 over the numbers works well
If heavy, add just a little power to arrest your sink rate as you level over
the runway, keep pulling the yoke back until it's burried in your stomach,
it's nose is a lot heavier than a 172's and as your speed slows, you really
loose elevator if you don't keep pulling.
There is NO NEED to try to land this plane fast!!! Read the POH and do some
slow flight with an instructor, you'll see it will fly with everything
hanging out at 37 knots!!!! THIRTY SEVEN!! Don't try to land it at 80
Jim Burns III
Remove "nospam" to reply
downwind, 90 kts
abeam the numbers
turning base
flaps 20, 80 kts
turning final
Old March 1st 04, 03:29 PM
Andrew Gideon
Well, I don't get a discount on the fee if I use less runway, so I figure
that I should be getting the maximum runway for my landing fee dollar.
Laugh
Sorry I wasn't clear, but Craig had it right. I was speaking of being in
downwind past the point of abeam the numbers.
closed.
I know the speeds I want. I'm looking for suggestions of the power settings
that'll get me there. One of the "difficulties" I found when flying the
182 the first time was the lack of an idea of what settings will yield what
speed. I don't even think about this in the 172 any more, so it's
interesting to be "starting fresh". I learned the feel of the 172 before I
was a pilot, so to speak, so this is different.
I think one's first transition must be something like one's first foreign
language (as an adult). There's actually a skill to acquiring the new
skill.
That seems slow to me. According to the POH, final for a short field is
63kts. There's room between there and the stall, of course, but that'll
make for an even steeper final, and therefore a more abrupt flair.
It's doable, I assume...I've done this in the 172 when I've been too lazy to
slip, but the 182 already seems to be "heavy" in the flair to me.
- Andrew
P.S. Anyone know why rotate speed on the 182RG is 50 while the rotate
speed on a 172 is 55? I'd have assumed the heavier plane would
have the higher speed.
Old March 1st 04, 04:12 PM
Power to weight ratio.
172 has a smaller wing and a smaller engine
Jim Burns III
Old March 1st 04, 08:50 PM
Scott Skylane
Jim,
Not quite. The 172 and 182 share the same wing area, a factor that has
nothing to do with power-to-weight.
Happy Flying!
Scott Skylane
Old March 1st 04, 04:36 PM
John Harper
55 seemed awful low to me too (I fly a TR182). It is only
1.1 Vs0 - doable of course if you need to get into 800'
but close to the edge. I aim for 70 on short final and
65 over the threshold, using 15" and full flaps (and the gear!)
on final.
Before I get flamed... yes, I know Vs0 is 39... IAS, not
CAS. CAS is 49. And the wings don't know about IAS,
only CAS.
My settings are 18" for the pattern, with gear and 10 deg
flaps, and 15" on final. I cruise at 25"/2200, which is OK by the
POH and both quieter and cheaper than a "squarer" figure
of 24"/2300. Climb at 25"/2400. Cruise descent at 23"/2500 which
keeps things just below yellow line. 15" for an ILS final.
John
"Andrew Gideon" wrote in message
online.com...
Laugh
closed.
settings
what
I
skill.
to
- Andrew
Old March 1st 04, 04:45 PM
Michael 182
I have the same plane, and I fly the same numbers, maybe a little closer to
square in cruise. Just out of curiousity, what are you getting for fuel
burn? I seem to be getting around 14.5 - 15 gph at 10,000 ft during cruise,
75 degrees rich of peak.
Michael
"John Harper" wrote in message
news:1078159138.642961@sj-nntpcache-3...
John
Old March 1st 04, 07:52 PM
John Harper
I get around 13.8-14 gph in cruise. I lean using the
TIT, I generally run at 25"/2200/1400 on the TIT.
Any higher gives me rough running. No doubt (as
people have told me) there is a tiny induction leak
somewhere, but my mechanic hasn't found anything.
By the way for people who are interested in the
finer points of flying 182s (or any other Cessna) this
kind of discussion goes on all the time in the Cessna
Pilots Association groups - www.cessna.org . If you
fly a Cessna you should probably think about joining.
John
"Michael 182" wrote in message
news:XMJ0c.15846$PR3.412249@attbi_s03...
to
cruise,
Michael
John
eScrew zen story [email protected] Owning 0 December 20th 04 07:19 AM
Funny story about naval [email protected] Naval Aviation 0 December 20th 04 03:37 AM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 03:29 PM
