For some reason the Clearcoat on my Mooney is starting to bubble off
and peal away. I otherwise have a good paint job that I believe was done around '95. Sadly, a hanger is not possible around here. Is it worth it to strip the Clearcoat off and have it reapplied (can that even be done)? Am I looking at a new paint job? Can I put something over the Clearcoat to prevent this? I've waxed my plane every 6 months since I've had it so I'm a bit frustrated now. |
![]() "Robert M. Gary" wrote in message om... For some reason the Clearcoat on my Mooney is starting to bubble off and peal away. I otherwise have a good paint job that I believe was done around '95. Sadly, a hanger is not possible around here. Is it worth it to strip the Clearcoat off and have it reapplied (can that even be done)? Am I looking at a new paint job? Can I put something over the Clearcoat to prevent this? I've waxed my plane every 6 months since I've had it so I'm a bit frustrated now. I had a similar situation with an automobile several years ago. There were two alternatives: 1) Live with it. 2) Totally strip and repaint the damaged areas. Yes, this includes stripping and re-applying the color coat too. It was explained to me that the problem was likely due to either contamination between the paint layers or (more probably) a failure to apply the clear coat during the correct "window" of time after the color coat was applied. Given the age of the auto, I went with option 1. KB |
In rec.aviation.owning Robert M. Gary wrote:
For some reason the Clearcoat on my Mooney is starting to bubble off and peal away. I otherwise have a good paint job that I believe was done around '95. Sadly, a hanger is not possible around here. Is it worth it to strip the Clearcoat off and have it reapplied (can that even be done)? Am I looking at a new paint job? Can I put something over the Clearcoat to prevent this? My plane was painted in '95 and it's clearcoat has been flaking off for some time. I figure I'd live with it for several more years, and then get her painted again. I'm not sure there's anything you can do about it now, other than repainting (including the color coats). --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
![]() "Robert M. Gary" wrote in message om... For some reason the Clearcoat on my Mooney is starting to bubble off and peal away. I otherwise have a good paint job that I believe was done around '95. Sadly, a hanger is not possible around here. Is it worth it to strip the Clearcoat off and have it reapplied (can that even be done)? It can be done. Is it worth it? That's for you to decide. Am I looking at a new paint job? In the affected areas, yes. Can I put something over the Clearcoat to prevent this? I've waxed my plane every 6 months since I've had it so I'm a bit frustrated now. No, the problem is likely from within. A reaction between the clearcoat and the paint result in gasses being released and causing bubbling. There's a possibility it may not be from within. Have you ever seen auto rims where the aluminum is corroding under the clear coat? That's usually the result of cats and/or dogs urinating on the rims. Through a process too long to describe here, the clearcoat separates from the rim and, in the presence of atmospheric gasses and ammonia, occluded by the clearcoat, causes rapid corrosion. I'm not saying cats and/or dogs are urinating on your plane. What I am saying is that there may be compounds coming in contact with the surface which may act in a similar fashion. Maybe the detergent or wax. I would suggest washing it with a mild liquid detergent and not waxing it. The clearcoat is intended to protect the paint. It's considered sacrificial by many professional painters. A friend owns a Bonanza and every few years has a body shop use a mild abrasive to clean and smooth the clearcoat then apply another coat. It's not too expensive and looks great all the time. |
There is a method developed and used by WingWaxers. It really coats
and protects your paint, metal, etc. Seth (Robert M. Gary) wrote in message . com... For some reason the Clearcoat on my Mooney is starting to bubble off and peal away. I otherwise have a good paint job that I believe was done around '95. Sadly, a hanger is not possible around here. Is it worth it to strip the Clearcoat off and have it reapplied (can that even be done)? Am I looking at a new paint job? Can I put something over the Clearcoat to prevent this? I've waxed my plane every 6 months since I've had it so I'm a bit frustrated now. |
clearcoat ... is starting to bubble off and peel away I hate clearcoat. Owners love the shine at first, then it starts to peel and looks like dog****. I wish people wouldn't put that stuff on. -- ATP http://www.pittspecials.com/images/oz_down.jpg |
Kracon at Lincoln are great painters, trust them.
"Robert M. Gary" wrote in message om... (John Galban) wrote in message . com... (Robert M. Gary) wrote in message . com... If you do repaint, don't get the clearcoat. I had my plain repainted in '97 and my paint guy strongly advised against clearcoat for an airplane that is parked outside (even though it would have netted him more $). He said that UV would eventually yellow the clearcoat, then it would start to crack and peel. After talking with several other owners who had exactly that experience, I opted to skip the clearcoat. My plane has been parked outside in AZ for 7 years and the paint still looks great. I'm going to take it to a local painting place in Lincoln, CA. On the phone they said they no longer use the old clearcoat but something else that includes a good amount of UV protection. Of course, the white part of the paint doesn't get anything because they can mix in the poly-something to get teh same results. -Robert |
Diesel aircraft engines and are the light jets pushing out the twins? | [email protected] | Owning | 84 | October 4th 04 06:09 PM |
OT early humour. Losing an Engine | Ghost | Home Built | 7 | September 20th 04 01:48 AM |
Losing my Clearcoat | Robert M. Gary | Owning | 10 | March 3rd 04 07:36 PM |
U.S. is losing the sympathy of the world | John Mullen | Military Aviation | 149 | September 22nd 03 03:42 PM |
