Crash site of missing plane found (North Las Vegas to San Diego)
Old March 4th 04, 07:26 AM
C J Campbell
Default Crash site of missing plane found (North Las Vegas to San Diego)
"R. Hubbell" wrote in message
news:20040303194733.3b99a3f5@fstop...
An unfortunate end to a plane gone missing:
http://www.reviewjournal.com/lvrj_ho.../23314333.html
Interesting that they used radar signals to find the crash site.
I thought they would always do that.
It is extremely difficult to sort out the all those planes squawking 1200;
even harder to pick out traces of airplanes with no transponders. They are
analyzing the radar tracks to find an airplane that went missing in this
area recently. It will probably take several days, if not weeks, with a poor
chance of success.
There are still large areas of the country without radar coverage of any
kind, especially in the West in the mountain regions.
Old March 4th 04, 07:42 AM
John Clear
In article 20040303194733.3b99a3f5@fstop,
Doing a radar analysis to find a crash site isn't as easy as it
sounds. It isn't just replaying the tapes until a plane disappears.
The usual way to do it is to determine when the plane took off,
and start tracking it from the departure airport. Even in the
local area, there will be multiple radars tracking the plane. Over
a longer distance, there are many more radar tapes to to synchronize,
and there isn't 100% radar coverage.
Determining the departure time is sometimes real detective work.
I remember one search ~5years ago. A pilot flying from California
to OSH wasn't reported missing until he didn't return from OSH.
The folks in California thought he was having a good time at OSH,
and his friends at OSH thought he decided not to go. IIRC, he
didn't use credit cards, and refueled at non-towered airports.
After a bunch of interviews with FBOs along the way, he was finally
able to be tracked. The radar tracks showed the plane flying at
11,500ft, and ended at a 12,000ft mountain.
The NTSB number for this accident is SEA98FA161 or follow the link
http://www.ntsb.gov/ntsb/brief.asp?e...11X10951&key=1
I'm not involved in CAP any more, but the best ways to be found are
in order of chance of success (IMHO):
1. IFR flight plan
2. VFR flight plan with flight following
3. flight following w/o flight plan
4. VFR flight plan
5. informal flight plan with friends/family (indicate route of flight/etc)
6. airband radio in survival gear
7. cell phone
8. land in someone's backyard
9. 406mhz ELT w/ GPS
A 406mhz ELT is much better then 121.5 only ELTs, but is still not
that reliable a way to find a plane. After countless false alarm
searches for 121.5 signals, I consider 121.5 ELTs only to be useful
as expensive ballast. ELTs have a 99%+ false alarm rate (of the
times they go off, over 99% are false alarms), and have a 95%+
failure rate in actual crashes. A sizeable number of the crashes
they do activate in are crashes were no search is needed (land in
someone's field). I don't have current stats, so the numbers above
are a few years old, but have been in that range for years. ELTs
work in such a small number of crashes that it hard to get
statistically significant numbers.
John
John Clear - http://www.panix.com/~jac
Old March 12th 04, 12:55 AM
PJ Hunt
It would be interesting if they would have mentioned what his altimeter was
indicating.
PJ
"John Clear" wrote in message ...
Old March 12th 04, 02:00 AM
Peter Duniho
"PJ Hunt" wrote in message
was
indicating.
How would they know?
Old March 12th 04, 02:36 AM
Maule Driver
"Peter Duniho"
was
indicating.
I think they can usually determine where the needle was at impact because it
makes some sort of mark on the face. G-force and all. I guess that assumes
that it didn't all burn and melt. Always an interesting question.
Old March 12th 04, 02:41 AM
PJ Hunt
Peter,
I've spent almost 16 years in mountain rescue and have done literally 100's
of rescues and body recoveries from plane crashes. It has been my
experience that in the vast majority of those, most if not all of the
instruments are readable. The glass is often broken, the gauges may or may
not be bent, but the needles are there, stuck in posision they were at upon
impact.
This would indicate the altitude that the pilot 'thought' he was at just
prior to impact.
PJ
was
indicating.
Old March 4th 04, 08:47 AM
Jeff
ya this was not to far from my house.
I saw it on the news the other night.
I am surprised no one saw the plane, lots of training flights go out that way. the
jean dry lake bed is the main training area the area around primm is a good over
flow area.
R. Hubbell
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
