If we had slowed down a little, and tightened up the tension a bit, we could have added a couple hundred more feet? What do you think about the "Payout Winch"?
http://www.youtube.com/watch?v=f5WDiHHgua8 Boggs |
I think I want one!
Here's the payout launch from the glider end. The launch starts at about 3 minutes in.
http://www.youtube.com/watch?v=M3ga-XJ_cdw Boggs |
On Monday, May 6, 2013 10:46:40 PM UTC-6, Waveguru wrote:
If we had slowed down a little, and tightened up the tension a bit, we could have added a couple hundred more feet? What do you think about the "Payout Winch"? http://www.youtube.com/watch?v=f5WDiHHgua8 Boggs I think if you had a real winch and learned how to use it safely, you'd get a lot higher. |
At 14:07 07 May 2013, Bill D wrote:
On Monday, May 6, 2013 10:46:40 PM UTC-6, Waveguru wrote: If we had slowed down a little, and tightened up the tension a bit, we could have added a couple hundred more feet? What do you think about the "Payout Winch"? http://www.youtube.com/watch?v=f5WDiHHgua8 Boggs I think if you had a real winch and learned how to use it safely, you'd get a lot higher. I think that is the most complicated and potentially dangerous method of winch launching that I have ever seen. I am completely sold on winching, having made over 10000 launches on many types of winch over the years. I have to say that some of the winches I have used, including a converted Rover car have been less than ideal, and perhaps a little unwise, but this has to be the most foolhardy version I have ever come across. I would be the first to admit that there are several potential hazards in winch launching but a system as complex as that is an accident just waiting to happen. Please stop it guys, get a proper conventional winch if that is the way you want to go, or go to a straight forward auto tow. |
On Tuesday, May 7, 2013 11:02:14 AM UTC-5, Don Johnstone wrote:
At 14:07 07 May 2013, Bill D wrote: On Monday, May 6, 2013 10:46:40 PM UTC-6, Waveguru wrote: If we had slowed down a little, and tightened up the tension a bit, we could have added a couple hundred more feet? What do you think about the "Payout Winch"? http://www.youtube.com/watch?v=f5WDiHHgua8 Boggs I think if you had a real winch and learned how to use it safely, you'd get a lot higher. I think that is the most complicated and potentially dangerous method of winch launching that I have ever seen. I am completely sold on winching, having made over 10000 launches on many types of winch over the years. I have to say that some of the winches I have used, including a converted Rover car have been less than ideal, and perhaps a little unwise, but this has to be the most foolhardy version I have ever come across. I would be the first to admit that there are several potential hazards in winch launching but a system as complex as that is an accident just waiting to happen. Please stop it guys, get a proper conventional winch if that is the way you want to go, or go to a straight forward auto tow. i'm interested to hear more about your opinion. Gary's payout winch basically has built in tension control in that if, say, the glider hits a thermal on the climb, instead of the line loading up and breaking, it just lets out more line so you get to use that thermal to climb higher. hang glider guys use payout winches a lot to launch in the flat lands. |
On 5/7/2013 9:23 AM, Tony wrote:
On Tuesday, May 7, 2013 11:02:14 AM UTC-5, Don Johnstone wrote: At 14:07 07 May 2013, Bill D wrote: On Monday, May 6, 2013 10:46:40 PM UTC-6, Waveguru wrote: If we had slowed down a little, and tightened up the tension a bit, we could have added a couple hundred more feet? What do you think about the "Payout Winch"? http://www.youtube.com/watch?v=f5WDiHHgua8 Boggs I think if you had a real winch and learned how to use it safely, you'd get a lot higher. I think that is the most complicated and potentially dangerous method of winch launching that I have ever seen. I am completely sold on winching, having made over 10000 launches on many types of winch over the years. I have to say that some of the winches I have used, including a converted Rover car have been less than ideal, and perhaps a little unwise, but this has to be the most foolhardy version I have ever come across. I would be the first to admit that there are several potential hazards in winch launching but a system as complex as that is an accident ju st waiting to happen. Please stop it guys, get a proper conventional winch if that is the way you want to go, or go to a straight forward auto tow. i'm interested to hear more about your opinion. Gary's payout winch basically has built in tension control in that if, say, the glider hits a thermal on the climb, instead of the line loading up and breaking, it just lets out more line so you get to use that thermal to climb higher. hang glider guys use payout winches a lot to launch in the flat lands. Their stall speed is a lot slower. I am not sure that I understand how you could use a payout winch with a glider unless the truck is driving at a tremendous speed. |
Don, I can respect that you have reservations about the method in
question. But it would be a lot more constructive if you'd provide specific examples of why the method in question is inadvisable, and are prepared to tell us how it can go wrong. Otherwise, when you call people "foolhardy" and tell them flat out to "stop it," you mostly just come across as a disagreeable curmudgeon. Furthermore, I think that anybody who has used a winch but decries the "complexity" of other ground launch methods does not really understand how complex a good winch is, and how many points of failure there really are. Thanks, Bob K. On May 7, 9:02*am, Don Johnstone wrote: I think that is the most complicated and potentially dangerous method of winch launching that I have ever seen. I am completely sold on winching, having made over 10000 launches on many types of winch over the years. I have to say that some of the winches I have used, including a converted Rover car have been less than ideal, and perhaps a little unwise, but this has to be the most foolhardy version I have ever come across. I would be the first to admit that there are several potential hazards in winch launching but a system as complex as that is an accident just waiting to happen. Please stop it guys, get a proper conventional winch if that is the way you want to go, or go to a straight forward auto tow. |
At 02:45 10 May 2013, Bob Kuykendall wrote:
Don, I can respect that you have reservations about the method in question. But it would be a lot more constructive if you'd provide specific examples of why the method in question is inadvisable, and are prepared to tell us how it can go wrong. Otherwise, when you call people "foolhardy" and tell them flat out to "stop it," you mostly just come across as a disagreeable curmudgeon. Furthermore, I think that anybody who has used a winch but decries the "complexity" of other ground launch methods does not really understand how complex a good winch is, and how many points of failure there really are. Thanks, Bob K. Fair point Bob If we consider the simplest winch where the engine is connected to a transmission via a gearbox of some kind. In this type of winch the driver is seated and controls the throttle to control the speed of cable retrieval. What can go wrong? Three basic things as regards the operation of the winch. 1. A break in the cable 2. A mechanical failure of the winch 3. Winch driver error or incapitation. All of these eventualities are dealt with by practising launch failures or launch abandonment. As far as mechanical failure of the winch is concerned there are only two main components to fail, the engine (Uncommon but not unknown) and the transmission. In all cases the winch driver is seated with a good view of what is going on and can react to problems as they arise, in particular using the guillotine if required in a timely manner. The first winch I drove was of this time, a 3 litre petrol engine driving a winch drum through a conventional 4 speed gearbox. The most complex winch I have driven was a Munster Van Gelder winch with a ginormous turbo diesel engine providing power for 6 seperate drums through a torque converter. The engine control, transmission and drum select functions were complex but once the transmission was connected to the power module the principle was the same as for the simple Eagle winch described above. Failure of either winch by mechanical failure of the engine/transmission during launching was very rare. The MVG winch was however less reliable in that faults within the more complex system meant that it was U/s far more often than the simple winch, and took longer to fix. Having said that the components making up the MVG winch were of top quality and specifcally designed or adapted to provide the proper function, it was just that there were more components to go wrong. In both cases the winch was fixed, the driver had control and could see the glider at all times and take the appropriate action. The payout winch provides an additional level of complexity and reduces the ability of the operator to control the launch. Some aspects of the launch rely totally on unsupervised mechanical/electrical operations, the payout part of the operation. The system is really a combination of two launch methods, an auto tow and a winch launch and is just one level of complexity too much when the proven technology already exists to provide a good launch without introducing more complex procedures, especially ones which rely totally on a mechanical/electrical function with no human input or control. During an auto tow the driver is facing the wrong way or is peering over his shoulder so his ability to offer proper control or reaction to an emergency is compromised, add to that the fact that cable payout is taking place while the vehicle is moving in the opposite direction and while the glider is on the cable and the things that can go wrong increases exponentially. Winch launching has hazards, no denying that, some of them completely outside the control of the winch operator. A fixed winch with the operator in a good position to observe the launch provides the best and safest solution. I have of course assumed that the launch is contolled by one person, the implications of having two people controlling a launch (or not) are too horrible to consider. I cannot see that anyone would be daft enough to do that. I can see that the payout winch launch is dangerous, I have said so. I may or may not be believed. Like all human activity it will continue until something goes wrong. If god forbid someone is killed then many people will pipe up saying they knew it was dangerous, I am just saying it in the vain hope that people will look at what they are doing and see that however attractive it might seem it is not woth the risks, before it ends in tears. Bottom line, a vehicle driving down a runway with a glider on tow and a winch paying out cable while the launch is taking place is not something that I would ever be involved in. Been gliding and winching for 50 years and would like to continue for a few more years. |
Ground launch payout winch systems...Are they suitable for gliders? | [email protected] | Soaring | 13 | August 13th 14 04:30 PM |
Winch Launch Fatality | Ed Gaddy[_2_] | Soaring | 3 | June 23rd 09 11:15 PM |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
