If see you mobile was registered to someone else and they are letting you borrow their PDA for a badge flight, the name attached to the registration is what gets declared to any other devices linked up (Cambridge 302 for example).
I can enter a separate pilot in the Cambridge 302/303 but I don't want a task declared through to the 302/303 with a different name from see you mobile. Does anyone know a good solution to this one? Thanks Wade |
Buy your own copy of See You Mobile!
At 05:58 07 May 2013, Wade wrote: If see you mobile was registered to someone else and they are letting you borrow their PDA for a badge flight, the name attached to the registration is what gets declared to any other devices linked up (Cambridge 302 for example). I can enter a separate pilot in the Cambridge 302/303 but I don't want a task declared through to the 302/303 with a different name from see you mobile. Does anyone know a good solution to this one? Thanks Wade |
Użytkownik Wade napisał:
I can enter a separate pilot in the Cambridge 302/303 but I don't want a task declared through to the 302/303 with a different name from see you mobile. Does anyone know a good solution to this one? Use ConnectMe. -- WojtuÅ› |
For the flights that matter? - hand written declaration every time. Would
you trust your diamonds to gadgets? At 05:58 07 May 2013, Wade wrote: If see you mobile was registered to someone else and they are letting you borrow their PDA for a badge flight, the name attached to the registration is what gets declared to any other devices linked up (Cambridge 302 for example). I can enter a separate pilot in the Cambridge 302/303 but I don't want a task declared through to the 302/303 with a different name from see you mobile. Does anyone know a good solution to this one? Thanks Wade |
Hi Pete,
I don't use written declarations. I've never had a problem in 15 years with electronic declarations for many badge and record flights. If it is done correctly it is extremely reliable. Best Regards, Paul Remde ________________________________ "Pete Startup" wrote in message ... For the flights that matter? - hand written declaration every time. Would you trust your diamonds to gadgets? At 05:58 07 May 2013, Wade wrote: If see you mobile was registered to someone else and they are letting you borrow their PDA for a badge flight, the name attached to the registration is what gets declared to any other devices linked up (Cambridge 302 for example). I can enter a separate pilot in the Cambridge 302/303 but I don't want a task declared through to the 302/303 with a different name from see you mobile. Does anyone know a good solution to this one? Thanks Wade |
If see you mobile was registered to someone else and they are letting you borrow their PDA for a badge flight, the name attached to the registration is what gets declared to any other devices linked up (Cambridge 302 for example). I can enter a separate pilot in the Cambridge 302/303 but I don't want a task declared through to the 302/303 with a different name from see you mobile. Does anyone know a good solution to this one? Thanks Wade I'm going to stick my neck out and say that your initial premise that it is the registered SYM name that is sent to the logger with the declaration is wrong. Copied and pasted from the SYM manual section on task declaration: "After the communication is established, the following data is transferred automatically to the flight recorder: Declared task in SeeYou Mobile which you have entered in Menu Task Glider information which is entered in Menu Settings Polar (glider type) and Menu Settings Log (glider registration) Pilot name as entered in Menu Settings Log" So, if the manual is correct, all you should have to do is alter the pilot details to your own in Menu/Settings/Log for your badge flight and remember to change them back to the owner's when you return the PDA. John Galloway |
At 16:20 07 May 2013, John Galloway wrote:
At 05:58 07 May 2013, Wade wrote: If see you mobile was registered to someone else and they are letting you borrow their PDA for a badge flight, the name attached to the registration is what gets declared to any other devices linked up (Cambridge 302 for example). I can enter a separate pilot in the Cambridge 302/303 but I don't want a task declared through to the 302/303 with a different name from see you mobile. Does anyone know a good solution to this one? Thanks Wade My previous posting got truncated as it crossed the Atlantic so here is the complete version. I'm going to stick my neck out and say that your initial premise that it is the registered SYM name that is sent to the logger with the declaration is wrong. Copied and pasted from the SYM manual section on task declaration: "After the communication is established, the following data is transfered automatically to the flight recorder: Declared task in SeeYou Mobile which you have entered in Menu/Task Glider information which is entered in Menu/Settings/Polar (glider type) and Menu/Settings/Log (glider registration) Pilot name as entered in Menu Settings Log" So all you should need to do is enter your own information as described before declaring the task and remember to change it back to the owner's before returning the PDA to him. John Galloway |
As far as I know you cannot change the pilot name from the name that see you mobile is registered to. I will eventually buy my own copy of see you mobile but for right now I am a youngster who is very fortunate to have someone who is willing to let me borrow their airplane and instruments in that airplane to chase my first badge.
Thanks Wade On Tuesday, May 7, 2013 9:20:23 AM UTC-7, John Galloway wrote: At 05:58 07 May 2013, Wade wrote: If see you mobile was registered to someone else and they are letting you borrow their PDA for a badge flight, the name attached to the registration is what gets declared to any other devices linked up (Cambridge 302 for example). I can enter a separate pilot in the Cambridge 302/303 but I don't want a task declared through to the 302/303 with a different name from see you mobile. Does anyone know a good solution to this one? Thanks Wade I'm going to stick my neck out and say that your initial premise that it is the registered SYM name that is sent to the logger with the declaration is wrong. Copied and pasted from the SYM manual section on task declaration: "After the communication is established, the following data is transferred automatically to the flight recorder: Declared task in SeeYou Mobile which you have entered in Menu Task Glider information which is entered in Menu Settings Polar (glider type) and Menu Settings Log (glider registration) Pilot name as entered in Menu Settings Log" So, if the manual is correct, all you should have to do is alter the pilot details to your own in Menu/Settings/Log for your badge flight and remember to change them back to the owner's when you return the PDA. John Galloway |
On 09/05/2013 06:03, Wade wrote:
As far as I know you cannot change the pilot name from the name that see you mobile is registered to. I will eventually buy my own copy of see you mobile but for right now I am a youngster who is very fortunate to have someone who is willing to let me borrow their airplane and instruments in that airplane to chase my first badge. Thanks Wade If you use ConnectMe I believe you can change the name. It uses the same files as SYM on the PDA, just a few more steps to do it this way. -- Nick Hill |
Have you tried following the instructions in the manual to
change the pilot name, glider details and polar - then exit and save the profile? My registered SYM is happy to accept Mickey Mouse being named as the pilot - it just adds another name to the drop down list in Menu/Settings/Log. At 05:03 09 May 2013, Wade wrote: As far as I know you cannot change the pilot name from the name that see yo= u mobile is registered to. I will eventually buy my own copy of see you mob= ile but for right now I am a youngster who is very fortunate to have someon= e who is willing to let me borrow their airplane and instruments in that ai= rplane to chase my first badge. Thanks Wade On Tuesday, May 7, 2013 9:20:23 AM UTC-7, John Galloway wrote: At 05:58 07 May 2013, Wade wrote: =20 If see you mobile was registered to someone else and they=20 =20 are letting you =20 borrow their PDA for a badge flight, the name attached to=20 =20 the =20 registration =20 is what gets declared to any other devices linked up=20 =20 (Cambridge 302 for =20 example). =20 =20 I can enter a separate pilot in the Cambridge 302/303 but I=20 =20 don't want a =20 task declared through to the 302/303 with a different name=20 =20 from see you =20 mobile. Does anyone know a good solution to this one? =20 =20 Thanks =20 Wade =20 =20 =20 =20 I'm going to stick my neck out and say that your initial premise=20 =20 that it is the registered SYM name that is sent to the logger with=20 =20 the declaration is wrong. Copied and pasted from the SYM=20 =20 manual section on task declaration: =20 =20 =20 "After the communication is established, the following data is=20 =20 transferred automatically =20 to the flight recorder: =20 Declared task in SeeYou Mobile which you have entered in=20 =20 Menu Task =20 Glider information which is entered in Menu Settings Polar=20 =20 (glider type) and Menu Settings Log =20 (glider registration) =20 Pilot name as entered in Menu Settings Log" =20 =20 =20 So, if the manual is correct, all you should have to do is alter=20 =20 the pilot details to your own in Menu/Settings/Log for your=20 =20 badge flight and remember to change them back to the owner's=20 =20 when you return the PDA. =20 =20 =20 John Galloway |
Declared first emergency last week | EventHorizon | Piloting | 39 | October 28th 09 05:04 PM |
New iphone Mobile Nokia Mobile | [email protected] | Soaring | 0 | January 14th 09 06:29 AM |
More Evidence Bush Was Actually Declared a Deserter | WalterM140 | Military Aviation | 9 | August 23rd 04 11:36 PM |
Declared "minimum fuel" | O. Sami Saydjari | Instrument Flight Rules | 14 | April 4th 04 02:43 AM |
A record: 1 in 73 US households declared bankruptcy in '03 | Krztalizer | Military Aviation | 7 | March 15th 04 09:27 PM |
