Slow News Day
Old May 23rd 13, 06:04 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default Slow News Day
the Examiner is at it, again, this time reprinted in Co. Springs Gazette.
http://gazette.com/faa-should-adopt-...rticle/1501137
Especially liked the "lighter than air glider" bit. I'd have liked to be lighter than air a couple of times last week....
T8
Old May 23rd 13, 06:31 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
More slow news, this is hilarious.
http://framework.latimes.com/2013/05...hed-sailplane/
This has to be a hoax. Fun though.
T8
Old May 23rd 13, 07:36 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Thursday, May 23, 2013 12:31:22 PM UTC-5, Evan Ludeman wrote:
More slow news, this is hilarious. http://framework.latimes.com/2013/05...hed-sailplane/ This has to be a hoax. Fun though. T8
Nope, it is real, Evan. Been done more than once. Look back through SOARING, and you will find a picture of a Bowlus being pulled, in flight, across the ramp at some airport, by one or two men. Wind was blowing, plane is airborne and hooked to a rope, one in the plane, two or so on the ground.
I have also seen a Cessna 175 being pulled in the air by a Honda Goldwing.
Steve
Old May 23rd 13, 08:47 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
What Steve said. I'd estimate the rope tension at around 25 pounds.
On Thu, 23 May 2013 10:31:22 -0700 (PDT), Evan Ludeman
T8
Old May 23rd 13, 09:02 PM posted to rec.aviation.soaring
Bill D
T8
Maybe 25 pounds for level flight at best L/D but in the photo the glider is climbing. If the Baby's GW is 550 lbs and it's climbing at 1fps, that that alone equals one HP. (1 HP = 550 ft-lb-sec) Most likely, it's climbing at 5fps. For winch launch, rope tension is typically equal to the glider's flying weight.
Old May 23rd 13, 08:48 PM posted to rec.aviation.soaring
Bill D
T8
The LA Times wire service photo is definitely a fake. The 'rope' from the glider to the rider is simply a drawn-in line. The real tow cable is visible just over the rider's heads. The dust AHEAD of the rider on the right is probably from the tow car.
There are other similar fake photos around. The riders just cut in ahead of the glider for a few seconds while the cameraman takes the picture - then a touch-up artist draws in the fake rope.
Is it possible it could be done for real? Yes - if there's enough wind. If you had a 45kt wind, all you'd need is a big stake.
Old May 23rd 13, 08:56 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Yes, and there's even a video:
https://www.youtube.com/watch?v=86rOfjhsIIM
However, the glider is a ULW 1 homebuilt ultralite, not a Bowlus.
The horse tow is successful, but you wouldn't exactly call it a high
launch. Maybe if there was a bit more wind...
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old May 23rd 13, 09:48 PM posted to rec.aviation.soaring
Steve Koerner
The white horse is likely galloping but the black horse is slacking. The black horse is definitely in a trot -- typically 8-10 mph.
Old May 24th 13, 12:28 AM posted to rec.aviation.soaring
Dan Marotta
Yes, funny, but it's those same unknowing people who will be making the
rules. How much fun will it be then?
"Evan Ludeman" wrote in message
T8
Too fast vs too slow Ramy Soaring 15 May 9th 13 10:47 PM
Slow Flight w3n-a Rotorcraft 0 December 4th 08 03:00 PM
Slow Flight Ol Shy & Bashful Piloting 43 September 28th 07 02:52 AM
why so slow??!! Heino & Deanne Weisberg Home Built 6 November 6th 05 06:22 PM
Flying Slow [email protected] Piloting 61 January 17th 05 05:23 PM
