turn point
Old May 24th 13, 03:59 AM posted to rec.aviation.soaring
glen
Default turn point
What size radius is used for a badge or record turn point and start
cylinder? 1 mile is used for contest turn point.
Thanks
Glen
Old May 25th 13, 06:14 AM posted to rec.aviation.soaring
Bruce Friesen
Default turn point
Thanks
Glen
Glen,
Adding one thing to the good advice above: "Wait for the beep."
What I mean is, most loggers - certainly the Colibri - beep when the turnpoint is reached. No beep: you're not there yet. There could be any number of reasons, including the frequency of data points recorded, or a difference between what you see on the ground and what is in the recorder, etc. But the beep is certain evidence.
If your logger beeps, or flashes a confirmation, or whatever it does, be sure you get that in the bag before charging off to the next point. The logger making the flight log you intend to submit is the sole and awful authority.
Hope that makes sense. I myself fly with a Colibri that counts down the distance to the turnpoint; I have it where I can see it; and even after the distance to the turnpoint goes to zero and then negative I wait for the beep..
Good luck!
Bruce
Turn point Files Zaphod Beeblebrox Soaring 1 March 25th 12 02:26 PM
CUBI POINT - "CBUBI POINT.jpg" 90.4 KBytes [email protected] Aviation Photos 7 April 9th 08 10:11 AM
Turn point website and flight logs Udo Soaring 2 December 5th 06 10:03 PM
Look at the dew point Montblack Piloting 2 July 7th 06 12:09 AM
Look at the dew point Ross Piloting 18 July 6th 06 06:56 AM
