I put this into a new topic in order not to SPAM other topics where this question came up.
I thought that a vario needed to use the 3-D inertial sensor to sort out the horizontal and vertical components of "gusts", and I thought that nobody was doing that just yet. Or does the inertial sensor just make the filtering better? Well, actually a vario is an energy difference indicator. Many people (at least here in europe) want to know if total energy changes, even if the energy addition is due to a gust rather than thermal updraft. The vario needle in Butterfly Vario remains the "energy difference indicator" just as you are used to (inertial sensors are used here to e.g. acceleration induced errors etc..) We have another indicator (blue round indicator) that indicates vertical airmass movement (kind of a that what was called netto vario in the past, but determined differently). The vertical airmass indicator is based on the inertial reference system and therefore will not show horizontal gust-induced energy changes (this can be mixed with conventional netto and tuned by many factors taking installation etc. into account). This way you get both. Precise energy difference indication and indication of vertical airmass. Both indicators together give you a good situational overview. You know where the energy change comes from. Knowing if its worth slowing down to thermal or if the energy addition you just experienced is due to a gust is a very cool thing, especially when flying heavy gliders. |
The airmass indicator looks interesting. I have a couple questions
Can one set the audio to reflect the airmass indicator instead of the vario indicator, and would one even want to? Is the airmass indicator useful when thermalling or only in cruise? Thanks |
On Saturday, 25 May 2013 03:02:54 UTC+3, wrote:
The airmass indicator looks interesting. I have a couple questions Can one set the audio to reflect the airmass indicator instead of the vario indicator, and would one even want to? Actually that would be interesting, currently audioscheme uses only TE vario/sc (I like the audioscheme, you can set the sc-audio to automatically change to vario-audio when hitting lift mc/2). Also, configuring inertial netto to be normal variometer would be only a matter of subtracting polar sink from netto value. Is the airmass indicator useful when thermalling or only in cruise? Definitely both. krasw |
Marc,
Is it possible to create a "dead band" for the audio in cruise when at or near the correct speed. Dale. |
On Monday, May 27, 2013 10:47:45 PM UTC+2, wrote:
Marc, Is it possible to create a "dead band" for the audio in cruise when at or near the correct speed. Dale. Yep this is possible. You can set individual deadbands for cruise-mode and climb-mode and also asymmetrical (e.g. +0.4 to -0.1). Cheers Marc |
Where on the menu do you find the settings for dead band?
Thanks, Dale |
| Thread Tools | |
| Display Modes | |
| Where are you Butterfly vario? | [email protected] | Soaring | 17 | May 25th 14 06:49 AM |
| Butterfly Vario IGC | Richard[_9_] | Soaring | 3 | April 3rd 13 04:24 PM |
| Butterfly vario review | [email protected] | Soaring | 3 | October 10th 12 09:50 PM |
| Butterfly vario info | [email protected] | Soaring | 1 | August 7th 12 11:08 PM |
| New Butterfly Vario | Paul Remde | Soaring | 238 | February 20th 12 05:05 AM |
