Experience with Flarm "Stealth" and Competition modes
Old May 24th 13, 01:08 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default Experience with Flarm "Stealth" and Competition modes
I flew the Sports Class Nats with Powerflarm Brick (v 3.0), Butterfly 57mm display (v 3.1).
My experience last season was that flarm was a bit of a nuisance: in large gaggles the darned thing made more noise than my audio vario. As well, I found the "radar" tracking feature a useless distraction. So I thought I would fly a contest with Stealth mode enabled by default as well as Competition mode (higher alarm thresholds, enabled using the cflags command in the configuration file, see the dataport specification for details).
It all worked as intended. Warning threshold is "just right" for competition use and overall distraction level is happily low.
The fraction of pilots at this contest using Flarm was happily high. I heard "Thanks Flarm!" and similar on the radio many times.
Evan Ludeman / T8
Old May 24th 13, 06:15 PM posted to rec.aviation.soaring
Jim[_31_]
Evan Ludeman / T8
I flew this contest too but had Flarm in the standard mode. I thought it worked GREAT! It really didn't distract any. If I already knew someone was there I ignored it; if it was an unexpected alert it made me even more vigilant. I can't say it was a life saver...but maybe it was. I especially like how well integrated the FLARM is with my ClearNav!
-PC
Old May 24th 13, 06:41 PM posted to rec.aviation.soaring
Sean F (F2)
I agree with Jim. Virtually no distractions and excellent info when needed in normal mode.
Somebody is lobbying!
Old May 24th 13, 07:27 PM posted to rec.aviation.soaring
Dave Nadler
for details).
Evan, most likely the reason you had a high alert last season
was a number of gliders did not configure PowerFLARM as aircraft
type GLIDER, but left it at the default POWERPLANE. This gives a
different expectation of required separation and likely trajectories,
and consequently LOTS of alarms.
We still have one or two out there. If you always get an alert around
a specific glider (whose flying is shall we say not a problem), this
is likely the problem. Try to track these down and get it corrected !
Stealth: NOT RECOMMENDED.
Competition Mode: Should not be required unless pilots are flying
pretty aggressively. YMMV.
Hope that helps,
Best Regards, Dave
Old May 24th 13, 08:01 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
for details).
Hope that helps,
Best Regards, Dave
No, definitely not "power plane" -- that would have been much worse and limited to specific gliders. This was was endemic at 15s last year and similar though less intense at New Castle. Looking ahead 25 seconds with a reasonable envelope in a packed thermal will result in a lot of overlap and nuisance alarms. I get that. I decided to experiment with available options to deal with the specific issue of contest flying, I report that they work well.
Stealth mode appears to work great if all you want is anti-collision warning. Guess what? All I want from flarm in contest flying is anti-collision warning. Again, it works well. You've said several times 'not recommended' in all caps, but you've never stated a reason. If there is an engineering or safety related reason, please state it. I'm tempted by context to presume the real reason is marketing (the ability to track other pilots....).
T8
Old May 26th 13, 07:01 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
warnin=
anti-collision
recommended=
engineerin=
pre=
pilots....).
T8
From the Flarm website @
http://www.flarm.com/support/Flarm_Competitions.pdf
Stealth mode inherently reduces some of the benefits of situation awareness
for yourself and surrounding aircraft. Wedo not recommend the use of
Stealth mode, but it is better than turning FLARM® off for tactical
reasons.
The aim of FLARM is to assist you in maintaining good situation awareness.
If you choose deliberately to degrade the information available to you then
you must inevitably reduce your situational awaremess AND just as important
reduce the situational awareness of another pilot, who may not even be
flying your competition, with respect for your. That is why Stealth mode is
not recommended. Like all recomendations it can be ignored but at your own
peril.
Old May 24th 13, 10:59 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Evan Ludeman / T8
Grrrrrrrummmmble. I've just been informed that my "stealth mode" flarm was routinely trackable at 6 miles at Mifflin. And yes, I'm certain I had stealth engaged (it's in the log files). Guess I won't be doing any more of that.
T8
Old May 25th 13, 05:36 AM posted to rec.aviation.soaring
FLARM
Evan,
We have had no complaints about 'Stealth' not doing what it is supposed to do, so far.
Please send your log file to info@flarm with above comment.
Yes, Stealth Mode is silly and should not be used, but it's a lot better to use it than to unplug FLARM for fear of being followed...
Thanks
FLARM
Old May 25th 13, 06:33 AM posted to rec.aviation.soaring
Rtr
New to soaring.
The fear is that others will follow you to good lift?
Old May 25th 13, 12:56 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
On Saturday, May 25, 2013 1:33:27 AM UTC-4, Rtr wrote:
New to soaring.
Some of us simply feel that tracking competitors via radio isn't really in the spirit of the game, that's all. In practice it's probably moot. Looking out the window generally yields better information.
T8
Soaring Cafe ".net" | A new online site for competition news Bill Elliott Soaring 0 March 11th 11 04:20 PM
Flarm and stealth John Cochrane[_2_] Soaring 47 November 3rd 10 06:19 AM
"Stealth" Secret Service aircraft No Name Piloting 10 August 21st 08 12:12 AM
help me remember a book about stealth aircraft and a fictional bomber called "Blackmagic" Scaler Naval Aviation 9 September 22nd 07 09:43 PM
"Eight more F-22 stealth fighters arrive in Japan" Mike[_1_] Naval Aviation 1 February 18th 07 11:56 PM
