Piper Pathfinder Article
Old March 10th 04, 05:06 PM
john smith
Default Piper Pathfinder Article
The April 2004 PLANE&PILOT has a review of the 1974 Piper Pathfinder.
A table at the end of the article compares the 74 Pathfinder to the 74
Skylane.
I don't think Jay is going to be flying over Pike's Peak (14,110 feet)
unless he gets a Cessna. :-)
Service Ceiling PA28-235 ... 13,550
Service Ceiling C182.........17,700
Some other interesting numbers stand out in the comparison.
Old March 10th 04, 07:38 PM
Larry Dighera
On Wed, 10 Mar 2004 17:06:16 GMT, john smith wrote in
Message-Id: :
He should be glad he didn't purchase a Charger:
http://www.trade-a-plane.com/unprote...erf_1475B.html
Cessna doesn't reveal the Skylane's useful load:
http://skylane.cessna.com/spec_perf.chtml
Is the Piper or Cessna able to carry the most payload with full tanks?
Old March 10th 04, 08:40 PM
john smith
Message-Id: :
keeping in mind that these are 1974 models...
Pathfinder 182
average equipped new list price $36,490 $30,475
current values $63,000 $79,000
price appreciation factor 172% 259%
gross weight (lbs) 3,000 2,950
empth weight (lbs) 1,550 1,645
useful load (lbs) 1,450 1,305
horsepower 235 230
power loading (lbs/hp) 12.8 12.8
wing loading (lbs/sqft) 17.6 16.9
total fuel capacity (gal) 82 79
payload, max fuel (lbs) 958 831
cruise speed, 75% (kts) 133 139
best rate of climb SL (fpm) 800 890
Vso 52 50
takeoff run (ft) 850 705
landing run (ft) 1,040 590
Old March 10th 04, 09:25 PM
Jay Honeck
We've never had any reason to fly higher than 12,500 -- even when we flew to
the Grand Canyon. But we were still climbing pretty smartly when we leveled
off, so I wonder about that ceiling. (Doubt I'll be finding out anytime
soon, however. I don't have an oxygen system.)
Pfffft! What year are these prices from? I haven't seen a decent
Pathfinder go for less than $80K since we bought ours in 2002. There are
several for sale in T-A-P for $95K+.
Yep, that's what makes the Pathfinder such an awesome plane. To be able to
haul four 200 pounders, full tanks, AND baggage is a wonderful thing.
Totally bogus. We routinely see 1000+ fpm. Although, to be fair, our
Pathfinder has every speed mod ever made for it, so I don't know what a
stock bird would do.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 10th 04, 11:36 PM
Larry Dighera
On Wed, 10 Mar 2004 21:25:11 GMT, "Jay Honeck"
wrote in Message-Id:
XIL3c.100119$PR3.1812564@attbi_s03:
You don't need one below 14,500'.
Old March 10th 04, 11:42 PM
Larry Dighera
On Wed, 10 Mar 2004 23:36:31 GMT, Larry Dighera
wrote in Message-Id: :
.... for 30 minutes.
Old March 10th 04, 11:30 PM
Larry Dighera
On Wed, 10 Mar 2004 20:40:26 GMT, john smith wrote in
Message-Id: :
Message-Id: :
Pathfinder 182
horsepower 235 230
Service Ceiling (ft) 13,550 17,700
Vso 52 50
The Skylane carries about 150 pounds less, at 4-1/2% greater speed, to
a 3,150' higher altitude, with a substantially shorter landing run due
to the Pathfinder's more pronounced ground-effect, and it has two
doors. If the Pathfinder were loaded 150 pounds lighter, it would
reduce the difference between it and the Skylane. If the performance
numbers were the sole criteria in selecting between the two, who could
argue against the Skylane? It even has better sagebrush clearance and
a rain porch, and for photography and pipeline work, ...
Have you got any cabin dimensions?
Old March 11th 04, 01:18 AM
Mike Rapoport
I suspect that the 182's shorter landing performance has more to do with its
better flaps and consequent lower approach speed than with ground effect.
Mike
MU-2
"Larry Dighera" wrote in message
Message-Id: :
Message-Id: :
Pathfinder 182
horsepower 235 230
Vso 52 50
Old March 14th 04, 01:04 AM
Larry Dighera
On Thu, 11 Mar 2004 01:18:12 GMT, "Mike Rapoport"
.net:
The PA28's flaps are considerably closer to the pavement than the
Cessna's. That might increase ground effect. I agree, that a heaver
load at a higher speed is a significant contributor to the PA28's
longer landing run also.
Perhaps there are errors in the specifications posted:
john smith wrote in Message-Id:
Pathfinder 182
empty weight (lbs) 1,550 1,645
horsepower 235 230
Vso 52 50
TAP proffers these considerably different numbers:
PIPER PA28-235 PATHFINDER
Engine: LYC O-540-B4B5 75% Cruise: 133 kts Wingspan: 32.00 ft
Horsepower: 235 Stall: 52 kts Length: 24.08 ft
Rec'md TBO: 2000 hrs Range: 915 nm Height: 7.25 ft
Srv Ceiling: 14500 ft Empty Wt: 1435 lbs
Std Fuel: 50 gal Gross Wt: 2900 lbs
Max Fuel: 84 gal
Takeoff (over 50 ft obstacle): 1040 ft
Landing (over 50 ft obstacle): 1060 ft
Takeoff: 600 ft
Landing: 550 ft
Here are Plane and Pilot magazine's numbers:
http://www.planeandpilotmag.com/cont...essna182s.html
2000 Cessna 182S
SPECIFICATIONS
Base Price: $227,900
Engine make/model: Lycoming IO-540-AB1A5
Horsepower@rpm@altitude: 230@2400@SL
Horsepower For Takeoff: 230
TBO hours: 2000
Fuel Type: 100/100LL
Propeller type/diameter (in.): McCauley CS three-blade/79 in.
Landing gear type: Tri/Fixed
Max ramp weight (lbs.): 3110
Gross weight (lbs): 3100
Landing weight (lbs.): 2950
Std. empty weight (lbs.): 1928
Useful load - std. (lbs.): 1182
Payload - full std. fuel (lbs.): 654
Usable fuel - std. (gals.): 88
Oil capacity (qts.): 9
Wingspan (ft.-in) 36
Overall length (ft.): 29
Height (ft.-in): 9 ft. 4 in.
Wing area (sq. ft.): 174
Wing loading (lbs./sq. ft.): 17.8
Power loading (lbs./hp.): 13.5
Wheel track (ft.): 9
Wheel size: 6.00 x 6
Seating capacity: 4
Cabin doors: 2
Cabin width (in.): 42
Cabin height (in.): 48.5
Baggage capacity (lbs.): 200
PERFORMANCE
Cruise speed (knots):
Altitude Speed
80% power: 6000 140
65% power: 8000 130
55% power: 10,000 121
Max range (with IFR reserve) (nm):
75% power: 6000 820
65% power: 10,000 910
55% power: 10,000 968
Fuel consumption (gph):
75% power @ 6000 ft.: 12.5
65% power @ 8000 ft.: 11.1
55% power @ 10,000 ft.: 9.5
Estimated endurance (65%) (hrs.): 7.0
Stall speed (gear, flaps up) (kts.): 56
Stall speed (gear, flaps down) (kts.): 50
Best rate of climb (fpm): 924
Best rate of climb (@8,000 ft.) (fpm): 565 (est.)
Service ceiling (ft.): 18,100
Takeoff ground roll (ft.): 795
Takeoff over 50-ft. obstacle (ft.): 1514
Landing ground roll (ft.): 590
Landing over 50-ft. obstacle (ft.): 1350
1968 PIPER CHEROKEE 235C (N9474W)
SPECIFICATIONS
Engine make/model: Lycoming O-540-B4B5
Horsepower@altitude: 235@SL
Horsepower for takeoff: 235
TBO hours: 2000
Fuel type: 100/100LL
Propeller type: Hartzell CS
Max ramp weight (lbs.): 2900
Gross weight (lbs.): 2900
Landing weight (lbs.): 2900
Std. empty weight (lbs.): 1467
Useful load - std. (lbs.): 1433
Payload - full std. fuel (lbs.): 929
Usable fuel - std. (gals.): 84
Oil capacity (qts.): 12
Wingspan (ft.): 32
Overall length: 23 ft. 9 in.
Height: 7 ft. 1 in.
Wing area (sq. ft.): 171.6
Power loading (lbs./hp): 12.4
Wheel size (in.): 6.00 x 6
Seating capacity: 4
Cabin doors: 1
Cabin width (in.): 44
Cabin height (in.): 47
PERFORMANCE
ALTITUDE SPEED
75% power: 8000 136
65% power: 8000 130
55% power: 8000 122
Max range (with reserve) (nm):
75% power: 813*
65% power: 879*
55% power: 949*
Fuel consumption (@.42lbs./hp/hr.)(gph):
75% power: 12.3*
65% power: 10.7*
55% power: 9.0*
Estimated endurance- 65% (hrs.): 6.5*
Stall speed - flaps up (kts.): 57
Stall speed - flaps down (kts.): 52
Best rate of climb SL(fpm): 825
Best rate of climb, 8000 ft. (fpm): 500*
Service ceiling (ft.) 14,500
Takeoff ground roll (ft.): 800
Takeoff over 50-ft. obstacle (ft.): 1360
Landing ground roll (ft.): 680
Landing over 50-ft. obstacle (ft.): 1300
* calculated
Have you any idea of the correct figures? Plane and Pilot only shows
a 1 knot difference in Vs.
Old March 11th 04, 01:34 AM
john smith
Message-Id: :
Message-Id: :
Pathfinder 182
horsepower 235 230
Vso 52 50
with a substantially shorter landing run due to the Pathfinder's
If you are floating in ground effect, your approach speed is too fast
for your landing weight!
Cabin dimensions found in the PIM's I have for each aircraft do not
include baggage compartment volumes for either aircraft.
Piper Technical Publications List Jim Burns Owning 7 January 21st 05 03:27 AM
Anti collision light mod for Piper Arrow 1968 model? Frode Berg Owning 4 May 20th 04 05:16 AM
Piper Aztec and/or Apache owner groups? Ronnie D. Hughes Owning 3 April 1st 04 07:00 PM
Piper 6.00x6 Nose wheel and fork? mikem Owning 2 March 6th 04 07:23 PM
The Piper Cubs That Weren't Veeduber Home Built 5 August 28th 03 04:38 AM
