Wax
Old May 25th 13, 10:52 PM posted to rec.aviation.soaring
Boise Pilot
Default Wax
I know this has been discussed before, would like to know what wax to use on a sailplane finished in acrylic paint. Would prefer to use one that does not require a buffer.
One Idaho
Old May 25th 13, 11:33 PM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
Default Wax
One Idaho
WX Seal and WX Block. Wings and Wheels has it in stock. Hand applying the wax is fine, but the first part is a compound of sorts, and I use little Port Cable Random Orbital buffer and a medium cut foam pad.
Old May 26th 13, 02:39 AM posted to rec.aviation.soaring
Andrzej Kobus
Default Wax
I know this has been discussed before, would like to know what wax to use on a sailplane finished in acrylic paint. *Would prefer to use one that does not require a buffer.
One Idaho
WX Seal and WX Block. *Wings and Wheels has it in stock. Hand applying the wax is fine, but the first part is a compound of sorts, and I use little Port Cable Random Orbital buffer and a medium cut foam pad.
Probably the best product out there is German Klasse wax and sealant.
Old May 26th 13, 01:06 PM posted to rec.aviation.soaring
Default Wax
One Idaho
The excellent but expensive Wx Seal and Wx Block system is really designed for gelcoat, for which I can highly recommend it, although it can be used on acrylic finishes.
http://www.wingsandwheels.com/Weathe...ock%20Tech.htm
A good quality modern motor vehicle polish (like the Klasse that Andrej mentioned) is all you need for PU/acrylic finishes.
Old May 27th 13, 01:13 AM
Eurofighter Eurofighter is offline
Junior Member
First recorded activity by AviationBanter: Oct 2011
What do you think about this stuff?
http://www.aeroplane24.com/img/angeb...1297686589.jpg
DG recommends it
Click image for larger version
Old May 27th 13, 05:41 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
Default Wax
DG recommends it
|Filename: 1363_0_1297686589.jpg |
|Download: http://www.aviationbanter.com/attachment.php?attachmentid=63525|
Poly-Lack is widely used here in Germany, easy to apply, excellent
results, long-lasting protection.
Adding a cap full to the washing water makes the protection even last
longer.
Peter Scholz
ASW24 JE
Old May 27th 13, 05:42 PM posted to rec.aviation.soaring
Dan Marotta
Default Wax
Gee, I don't know... Sure, it says, "Nano Technology" on the package, but
nowhere did I see either, "Mega" or "Turbo". How good could it be?
"Eurofighter" wrote in message
DG recommends it
|Download:
Eurofighter
Old May 26th 13, 08:01 PM posted to rec.aviation.soaring
son_of_flubber
Default Wax
If you have a PU/acrylic finish, here is a good application guide for Klasse:
http://www.autogeek.net/klasse-usa.html
From what Google tells me you have to go to W&W for "the good stuff" WX/Block. Nice franchise. I wonder what Germans use on their gel coats?
I wonder if plastidip would be a good way to protect a trailer top? https://www.dipyourcar.com/home.php
Old May 27th 13, 12:29 AM posted to rec.aviation.soaring
Boise Pilot
Default Wax
One Idaho
Old May 27th 13, 12:33 AM posted to rec.aviation.soaring
Boise Pilot
Default Wax
THANKS FOR ALL THE INFO I KNOW WHAT I WILL DO
