On our PW-5 the main tire (aft of the CG) is labeled 0.35MPa (mega pascals). The POH says the same thing.
This converts to 50.8 PSI which seems really high to us. The tire is a 400x4 TOST Aero. Thanks, John PS The Nose Wheel is |
On Saturday, June 22, 2013 12:58:18 PM UTC-5, JohnDeRosa wrote:
On our PW-5 the main tire (aft of the CG) is labeled 0.35MPa (mega pascals). The POH says the same thing. This converts to 50.8 PSI which seems really high to us. The tire is a 400x4 TOST Aero. Thanks, John PS The Nose Wheel is My 1967 SHK uses the same 400X4 tire and has a POH tire pressure of 49 PSI. By the way, the tire only looks properly inflated with that pressure. less looks "flat" SHK max gross 820 lbs or so. Scott W |
Completing my transient thought....
PS The nose wheel is to be inflated to 0.2 MPa = 29.0 PSI. |
Discus 2a has a TOST Aero 400x4. Manual says 73psi, and that's what I keep it at.
-matthew On Sunday, June 23, 2013 3:28:18 AM UTC+9:30, JohnDeRosa wrote: On our PW-5 the main tire (aft of the CG) is labeled 0.35MPa (mega pascals). The POH says the same thing. This converts to 50.8 PSI which seems really high to us. The tire is a 400x4 TOST Aero. Thanks, John PS The Nose Wheel is |
| Accurate tire pressure gage? | Kurt Thams | Soaring | 6 | September 26th 12 12:17 AM |
| Trailer tire pressure remote monitoring systems | Eric Greenwell | Soaring | 11 | August 9th 08 07:03 AM |
| Tire tread wear vs inflation pressure | Ben Jackson | Owning | 22 | October 6th 06 05:35 AM |
| High Oil Pressure (was: Low oil pressure, high oil temp?) | Thomas Ploch | Owning | 4 | October 5th 04 05:34 AM |
| Tire inflation pressure | Paul Lee | Home Built | 80 | November 19th 03 08:56 AM |
