Anyone try prop Balance Master?
Old June 23rd 13, 06:40 PM posted to rec.aviation.soaring
Soartech
Default Anyone try prop Balance Master?
Wondering if anyone here has experience with a mercury auto-balancing accessory for prop vibration reduction on their self-launcher, ultralight, etc.
www.balancemasters.com/ultralights
Old June 23rd 13, 10:28 PM posted to rec.aviation.soaring
John Firth[_4_]
ultralight,
etc.
I achieved a considerable improvement in vibration after using
a double straight edge and a central spindle.
The prop overhauled by a prop shop was 4 gm (at the tip)
out of balance.
JMF
Old June 24th 13, 05:37 PM posted to rec.aviation.soaring
Thanks. Can you please email me with details of "double straight edge" and
which prop shop you used?
(I am not liking this new Google Groups interface.)
out of balance.
JMF
Old June 24th 13, 05:35 PM posted to rec.aviation.soaring
Old July 4th 13, 12:58 AM posted to rec.aviation.soaring
bumper[_4_]
On Sunday, June 23, 2013 10:40:15 AM UTC-7, Soartech wrote:
Wondering if anyone here has experience with a mercury auto-balancing accessory for prop vibration reduction on their self-launcher, ultralight, etc..
I don't know how or if the "self-adjusting" centrifugal balancers work. It defies whatever logic I might have, as I'd think the weight would migrate to the heavy side (g).
Dynamic computer balancers work very well and are pretty much the industry standard for prop, turbine, and rotor blade balancing. They have the advantage of balancing the entire rotating mass at speed.
Static balancers usually require prop removal, but they do okay for blade imbalance. I think they'd have a harder time correcting for an imbalance at 90 degrees to the blade axis. My 26E had such a lateral imbalance when delivered and it took a fair amount of weight to correct (partly because the weights had to go on the prop mounting bolts).
"Double straight edge" I believe refers to setting up two lever straight edges. A close fitting bushing is used through the prop hub and to mount the prop with a small diameter center pin that spans between the two straight edges. When mounted such, the prop should stay horizontal, as a heavy blade will rotate downward. Works similar to a motorcycle wheel balancer.
bumper
Old July 4th 13, 01:55 AM posted to rec.aviation.soaring
jfitch
bumper
Bumper,
Self adjusting balancers do work, though the physics is not very intuitive. Think of an imbalanced wheel spinning in space: it will rotate about its center of gravity, that is, the axle center will describe a circle opposite the heavy side since the CG is displaced towards the heavy side. It is therefore the light side rim making the largest radius, not the heavy side as is commonly thought. The weights migrate towards the largest radius until balance is achieved relative to the balance weight track (which is concentric with the axle by design). Constraining the wheel to rotate about the axle does not change the physics - unless the axle and its mountings are infinitely rigid, in which case you would feel no vibration. The vibration felt is the extent to which the axle orbits just as the wheel would in free space, limited only by the stiffness of its mountings.
Old July 5th 13, 07:37 PM posted to rec.aviation.soaring
bumper[_4_]
Jon,
Got it! Clearly I wasn't thinking that one through well (grin).
bumper
Prop Balance and Murphy Denny Owning 18 April 8th 08 04:05 PM
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Propeller Balance Master Casey Curtis Home Built 10 January 22nd 06 05:11 AM
Wierd vibration -- Prop or engine, balance or not??? Chuck Owning 17 December 1st 04 02:12 PM
Dynamic prop balance Ben Jackson Owning 18 June 27th 04 01:45 AM
