I'll probably need an airport tour to answer this to my satisfaction, but I
thought it merited a discussion here anyway. It seems pretty standard that, after an airplane is refueled, you wait 10-15 minutes and resample the fuel to check for contaminants (water). I recently witnessed a situation where the fuel was checked during preflight, but not after refueling. The reason given was that at this particular airport, the fuel supply is replenished/recycled daily, if not more, and so there isn't time for water, or perhaps *enough* water, to collect in the storage tanks and end up in an aircraft's fuel tanks. I'm not convinced. Work experience with mechanical things tells me that mechanical things malfunction. Could water get into the fuel truck's tank? Could water get into the storage tank? Could water get into the tanker bringing fuel to the airport? Could there be water in the fuel at the depot? Etc... I really don't know enough to answer this. It seems that the most likely causes of water contamination would be condensation in an airplane's fuel tank, or a leak in the airport's fuel storage tank. If the fuel doesn't sit in either for long, then that probably would reduce the risk to near zero. I would imagine that there's some other failsafes in place to prevent water from getting to the aircraft - perhaps the refueling trucks are individually checked before they are sent out. Still, if water gets into the system at ANY point, seems it's going to wind up in SOMEBODY's gas tank, no matter how often the supply is recycled? While we're at it, are these types of fuel checks standard procedure for ALL aircraft, or just the little piston-powered ones? |
Water can get into the system at any point, as you suggest.
As for waiting 10 to 15 minutes before sampling the fuel, why? Try this experiment: put some water and some fuel in a jar. Shake it up, and time how long it takes for the water to settle out. |
"C J Campbell" wrote in message
... Water can get into the system at any point, as you suggest. As for waiting 10 to 15 minutes before sampling the fuel, why? Try this experiment: put some water and some fuel in a jar. Shake it up, and time how long it takes for the water to settle out. 10 to 15 minutes might be overly generous, but your experiment doesn't really duplicate the conditions within an aviation gas tank. Some are lined with rubber bladders, that can get small wrinkles (or sometimes large wrinkles, which is really bad) that hinder the flow of water toward the drains. Others have part of the wing structure inside the tank, with holes drilled at the bottom, that impede that flow. In ALL wing-mounted tanks, water can be quite distant laterally from the drain, and it will take the water a lot longer to flow toward the drain along the bottom than it would for water to be pulled by gravity straight down in a jar. In a jar, water will settle in a matter of tens of seconds, even if shaken vigorously (much quicker if it's not). But in a fuel tank, it can easily take several minutes. So: always test your fuel (besides, you're not just looking for water). Always give the fuel some time to rest before checking (at least a few minutes). If you find ANY water, gently rock the wings to encourage water to get past any obstacles and get it into motion toward the drain, and wait a longer period of time just to make sure, and then check again. Repeat until you have no water. Pete |
![]() "Peter Duniho" wrote in message ... "C J Campbell" wrote in message ... Water can get into the system at any point, as you suggest. As for waiting 10 to 15 minutes before sampling the fuel, why? Try this experiment: put some water and some fuel in a jar. Shake it up, and time how long it takes for the water to settle out. 10 to 15 minutes might be overly generous, but your experiment doesn't really duplicate the conditions within an aviation gas tank. Some are lined with rubber bladders, that can get small wrinkles (or sometimes large wrinkles, which is really bad) that hinder the flow of water toward the drains. Others have part of the wing structure inside the tank, with holes drilled at the bottom, that impede that flow. In ALL wing-mounted tanks, water can be quite distant laterally from the drain, and it will take the water a lot longer to flow toward the drain along the bottom than it would for water to be pulled by gravity straight down in a jar. Then why wouldn't you rock the wings to start out with? Make sure all the water flows to the sump right away. |
... Then why wouldn't you rock the wings to start out with? Make sure all the water flows to the sump right away. I never suggested you wouldn't. Not sure how you got the idea that I had. |
"Chris Hoffmann" wrote in message ...
I'll probably need an airport tour to answer this to my satisfaction, but I thought it merited a discussion here anyway. It seems pretty standard that, after an airplane is refueled, you wait 10-15 minutes and resample the fuel to check for contaminants (water). I recently witnessed a situation where the fuel was checked during preflight, but not after refueling. The reason given was that at this particular airport, the fuel supply is replenished/recycled daily, if not more, and so there isn't time for water, or perhaps *enough* water, to collect in the storage tanks and end up in an aircraft's fuel tanks. It could. The truck's tank should be sampled and checked for water just like the airplane though. It is a good idea to check the fuel after fueling (I usually skip it during the pre-flight if I'm going to go get fuel). -Robert |
during preflight, but not after refueling. How then would one know if the tanks were filled with the wrong type of fuel? |
"John Harlow" wrote in message
... (water). I recently witnessed a situation where the fuel was checked during preflight, but not after refueling. How then would one know if the tanks were filled with the wrong type of fuel? .....Now that's an even better question. Thank you! |
Airport fuel farms are a big variable. At any airport with scheduled
service by a 121 carrier you can be pretty sure of the quality of the fuel and the equipment as the carriers QA Dept. (My job with one of the big 3 US carriers) will perform scheduled audits of the farm as well as the into plane delivery system. For the most part, at least in the US, the farms are held to the ATA Spec 103 standard. The CASE organization has also developed a standard similiar to 103 and is being accepted by the carriers who are CASE members. At a smaller airport I would exercise full caution, waiting a good 15-30 minutes after fueling or aircraft movement to sump the tanks. For what it is worth 30 minutes min. is the standard at my carrier. The FAA has no oversight of fuel farms, there are no FARs addressing them and as they are not "certificated" the FAA has no enforcement power. Any discrepancy noted in fueling procedures or quality will result in a LOI or enforcement action against the operator. So when it comes to fuel the phrase "let the buyer beware" never rrang truer. Seth "Chris Hoffmann" wrote in message ... "John Harlow" wrote in message ... (water). I recently witnessed a situation where the fuel was checked during preflight, but not after refueling. How then would one know if the tanks were filled with the wrong type of fuel? ....Now that's an even better question. Thank you! |
snip Good questions It seems that the most likely causes of water contamination would be condensation in an airplane's fuel tank... Snip Excellent thoughts. I once questioned a tank truck driver who was siphoning the storage tank of an automobile service station. He told me he was removing dirt and water from the bottom of the station's tank before he refilled it. He added that his Brand's reputation was at stake so their trucks were 'clean' but they wanted to be sure the station's tanks were also 'clean', as too often they were not and he had to do it himself, by Brand Company's Policy. One might suspect that such might be the case for some avgas stations, but I have no evidence or testimony that such may occur, currently. Your deduction of a'cft fuel tank condensation, as a major factor, is right on, from my personal experience. FWIW. While stationed on the Mississippi Gulf Coast, between Gulfport {G} and Pasagoula {P}, I had an old Taylor E2 Cub that was primarily flown to keep my coordination sharp when I had no flying duty. It had an A-40-4 single ignition engine equipped with a settling glass, also used on some automobiles. It was easily accessible on the right side of the engine compartment, between the tank and carb. Fuel entered a glass sump where water and dirt particles settled to the bottom of the sump where they were easily seen. Ambient air was always very humid on the coast and the diurnal temps varied enough so that condensation always had to be considered as in the a'cft's fuel tank, at first daily startup. Usually, there was a small amount {less than a teaspoonful} of water in the glass {which would hold about an ounce safely} to be dumped, but it appeared only 'after' initial warm up. No water contamination from refueling tanks at either the P or G airports was ever found but there was always a small amount in the bottom of the tank after the engine had cooled and it had been sitting for several hours or overnight. Ergo, condensation of water, from the amount of humid ambient air in the tank and tank temps, were very important considerations, but all contaminants had to flow from the tank to the settling glass before they were visible and could be dumped. In this a'cft, a preflight inspection fails to detect contaminants that may still be in the tank, unlike those that have drains for each tank that can be sampled or used to purge water/dirt during a preflight. Air contamination of a fuel line sounds ridiculous. I once started a forced landing when the E2's 40HP engine began quitting intermittently with insufficient power output to sustain level flight. There was no place to land except a large orchard with soft ground and insufficient space between the trees for the wings. I had been warned that single ignition systems could cause trouble from a fouled plug, but this engine was not 'missing on one' it was 'quitting' on all four, simultaneously. About fifty feet above the tree tops I thought it sounded more like fuel starvation and started pumping the priming pump, constantly. This small amount of additional fuel kept the engine running more often and was sufficient to mush to the P airport without losing more altitude. Post landing inspection showed the glass sump was not screwed tightly against it's cork gasket. I recalled that the sump had been dumped for me by a buddy. Evidently, he had not torqued it sufficiently to prevent it's loosening, allowing air leakage and a leaner mixture that would not combust. It was obvious that hereafter, I should do it myself or have a qualified person, familar with the E2, do it for me, but only if absolutely necessary. As you know, currently there are more complicated and efficacious water/dirt separators available for both gasoline and diesel engines but they may be too large for some light a'cft's reasonable installation. {Finis} |
Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 10:20 PM |
Cessna 172 with Wild Fuel Gauge Needle | jls | Owning | 26 | February 20th 04 05:56 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 02:50 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
