3 blade prop position on 6cyl engine.
Old February 19th 04, 03:25 PM
Paul Lee
Default 3 blade prop position on 6cyl engine.
Whats the best 3 blade prop position on a 6 Cyl Franklin?
The Ivo prop instructions only give an example for a 4 cyl
IO-360 to place one blade on TDC position. That's where
I placed it for the 6 cyl Franklin for now.
Paul Lee, SQ2000 canard project: www.abri.com/sq2000
Old February 20th 04, 05:28 AM
Jerry Wass
Then, on a 6 cyl, the other blades are properly positioned also--neat
ain't it..
Old February 20th 04, 03:14 PM
Paul Lee
Thats interesting now that you mention it. 3 blade prop is exactly
symmetrical in power pulses on a 6 cylinder engine.
Jerry Wass wrote in message ...
ain't it..
Old February 26th 04, 12:47 AM
Dan Thomas
Some old guys are aware that rotating a three-blade prop 180 degrees
(so that one blade is straight up as opposed to straight down at #1
TDC or whatever) can make a difference. The IO-520 had a habit of
throwing alternator belts, cured by rotating the prop. Changes
resonant vibration modes somehow.
Dan
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Pitch and Diameter of 3 blade prop for IO-360 200HP Bart D. Hull Home Built 1 December 11th 03 11:42 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
