I would like to replace the plastic bumper trim around the sides of my Cobra trailer. I did this to a Cobra a number of years ago and remember it being a nightmare. Has anyone done this and, if so, do you have any tips to make it easier. This is a ASH 25 trailer and is two feet longer than standard so will be quite a length to pull through the channel.
Thanks Dale |
Call Rex and Noelle at Williams Soaring Center.
They are Cobra dealers. They have all the parts. They have done this and helped people do it many times. |
It's a tough job, and the extra two feet will make it harder. You will need to do the following:
- Remove any nicks or bumps anywhere on the aluminum extrusion, then clean or polish as necessary to make it as smooth as possible. - Get the instructions from Spindelberger or Williams and use the exact type of dish soap they recommend for lubricating the track. - Trim the leading edge to help it feed in the track. - You'll need at least two good friends - one to spray lubricant in front of you and one to push on the trim and spray more of it where you have been. Also to spot areas where it as popped out of the track. You will need to reward them afterwards. - Will also need some vise grips to grab the trim for pulling. If you have lower back problems don't even think of doing this. It's tough. If it slips out of the track you can use plastic auto trim tools to push it back in. - After it's in, let it sit for a few hours to shrink back to normal shape before trimming the ends. Looks good when it's done, but not sure I'd do it again. Plan B would be remove the glider, park the trailer over flammable materials... Never mind. That's probably illegal. Good luck. |
I tried changing the bumper trim on my new cobra trailer a few years ago due to sun rot. The red has turned a brittle pink. I purchased the replacement Cobra trim from Rex as well. I was too cool to read the instructions and have a big scar on my ankle to prove it. I cleaned up the dried dirt caked on in channel (taking 3-4 hours) as you should but didn't do the main trick...more on that later...
I could pull the trim through 2/3 of the way and then it was impossible to do more. Also thought of the vice grips idea. A few more feet but it was stuck. Got soap...another foot. Still 8 feet short. "Darn!" Keeping it clean since there were children present watching the debacle. I had the brilliant idea to get a come-along and attach to the vice grips. 4 to 5 failed attempts later the channel plastic ripped out and the metal vice grips shot like a slingshot right at me and hit me in the ankle smack dab on the bone that sticks out at your sock line. Oh it felt so good!!! ![]() So. Now what after the bleeding stopped 3 days later? Time to call Rex and ask what I am doing wrong. They asked, "You are soaking it in hot water right before putting on right?" Uhhhh, thanks.... Slid on like butter with no come-along the first try after doing it right. Duh! Sure made the trailer look like it was new. Have fun and yes it is well worth it. ![]() Bruno - B4 |
Thanks everyone for the tips. I won't need to be placed on suicide watch this time around
On Monday, September 2, 2013 10:01:59 PM UTC-5, wrote:
Thanks everyone for the tips. I won't need to be placed on suicide watch this time around And, thanks for asking the question, Dale. I, too, have a Cobra for an ASH-25, but two feet longer than normal. I am stretching it for a 19 meter span, two piece wing plane I have. Why is yours longer than a "normal" 25 trailer? Just made long enough to leave the longer tips on in the trailer? Steve Leonard BSK, N5681 (19 meter stretch and mod of Glasflugel BS1) |
Hi steve. Tell us about your project. It sounds exciting. The previous owner of my 25 (lee Hallerberg) had it lengthened at the factory to make more storage room up front.
Dale |
On Thursday, August 29, 2013 5:27:27 PM UTC-6, wrote:
I would like to replace the plastic bumper trim around the sides of my Cobra trailer. I did this to a Cobra a number of years ago and remember it being a nightmare. Has anyone done this and, if so, do you have any tips to make it easier. This is a ASH 25 trailer and is two feet longer than standard so will be quite a length to pull through the channel. Thanks Dale |
2013 Cobra trailer price list needed for TA trailer sale | [email protected] | Soaring | 0 | June 22nd 13 02:42 PM |
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 02:11 AM |
Cobra trailer trim. | Bob | Soaring | 12 | July 19th 06 05:12 AM |
Help - Cobra Trailer Trim? | WDM | Soaring | 2 | January 12th 05 07:47 PM |
Cobra Trailer | Soaring | 1 | September 28th 03 01:14 PM |
