Anyone done a mount application for the Avier/Vertica Sports V2 in a Libelle?
If you have would, please forward pictures? I'm thinking either a flexible rod mounted to the instrument panel or using the seat adjustment rail as the source for mounting a rig. Any input/photos would be appreciated. r/Jim 9XL |
On Sun, 08 Sep 2013 12:02:17 -0700, thermalrider1 wrote:
Anyone done a mount application for the Avier/Vertica Sports V2 in a Libelle? If you have would, please forward pictures? I'm thinking either a flexible rod mounted to the instrument panel or using the seat adjustment rail as the source for mounting a rig. Any input/photos would be appreciated. I mounted a smaller PNA (Binatone B.350) on my Libelle's panel by attaching the clip mount that came with it to a standard RAM flexible mount. This ended in a flat-faced diamond shaped piece of plastic. It was easy to make an adapter from a stack of 1.5mm epoxy-glass plate [1]. The bottom plate matches the RAM mount's end fitting screw holes and the top plate has holes to match those in the clip mount. Put one or two smaller plates between the two end plates as spacers so the bottom plate screws don't foul the top plate and vice versa. IIRC I used two spacer plates. [1] available from most good hobby shops and easily glued together with 5 minute epoxy from the same source. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Avier with LK8000 | Guy B | Soaring | 5 | July 23rd 13 11:04 AM |
External power for the Vertica V2 | [email protected] | Soaring | 8 | June 5th 13 11:07 PM |
Vertica V3? | son_of_flubber | Soaring | 28 | January 10th 13 08:44 PM |
Notes on the Vertica 2, Gliderguider PNA | Tom Kelley #711 | Soaring | 19 | November 1st 12 07:19 PM |
