Cross country question? How is it done today?
Old September 11th 13, 04:22 PM posted to rec.aviation.soaring
flgliderpilot[_2_]
Default Cross country question? How is it done today?
I am fairly green had my PGL for about 3 years now.
Been venturing into cross country, have done my first flight out to another airport, and last weekend, an out to that airport and return, about 30 miles round trip (in a 1-26, no ridges, it's all flat Florida). No it's not very far, but at least I am not just circling the airport for hours, and my enjoyment of soaring has been taken to a new level.
However, I was told recently by an older experienced pilot that using a GPS is "not the correct way to do it". Instead I should be thinking "can I get there... now can I get there... can I get there...". I understand this ideology, but I am pretty sure nearly everyone is using GPS these days.
So, does this mean I should not use modern navigation technology? I know how to plot a cross country flight on paper of course, and required altitudes to the next safe landing area.
Does this mean I should I actually be drawing circles on charts, carrying a slide ruler to calculate arrival height at various distances, and mechanically doing everything my GPS is doing for me? This means I am not looking for traffic, or thermalling but instead flipping through charts and playing with a slide ruler or E6B, and my eyes are not outside the canopy.
Anyway, please enlighten a new pilot, I am listening intently. if I should not be using a GPS at this point I'll go without.
Thanks
Tom
Old September 11th 13, 05:20 PM posted to rec.aviation.soaring
Scott Calvert[_2_]
to
another=
about 30
mil=
not
v=
and my
enjoyment of soaring has been taken to a new level. =20
using a
GPS=
"can I
ge=
understand this
i=
these days.
technology? I know
ho=
required
altitudes=
charts, carrying
a=
mechanic=
am not looking
f=
playing
canopy.=20
I
should=
Thanks
Tom
What happens if your GPS dies?
Old September 11th 13, 05:54 PM posted to rec.aviation.soaring
flgliderpilot[_2_]
Same things that happens if my ruler ends up behind my seat, or I make a gross error in the slide rule calculations. I fly field to field, until I realize I am not going to make it to the next field (kinda easy to see, the field is rising in my canbopy). I pick one of the 3 fields I have selected as a possible landout for this scenario, and I land in it.
Old September 11th 13, 06:53 PM posted to rec.aviation.soaring
Soartech
Same things that happens if my ruler ends up behind my seat, or I make a gross error in the slide rule calculations. I fly field to field, until I realize I am not going to make it to the next field (kinda easy to see, the field is rising in my canopy). I pick one of the 3 fields I have selected as a possible landout for this scenario, and I land in it.
Exactly. You already knew the answer to your question.
Make sure your batteries are good and use the GPS. It is far easier and faster to use than the old methods. I can't even imagine unfolding a map in the confines of my sailplane. If the GPS fails, just fly conservatively, stay as high as possible and choose a good field if you can't make it to your goal.
Old September 11th 13, 07:02 PM posted to rec.aviation.soaring
flgliderpilot[_2_]
Thanks, I really appreciate your opinion on this.
Tom
Old September 11th 13, 11:48 PM posted to rec.aviation.soaring
BobW
On 9/11/2013 10:53 AM, Soartech wrote:
Snip... I can't even imagine unfolding a map in the confines of my
sailplane.
Not to be contentious, but why would anyone seriously consider "unfolding a
map" in the confines of a sailplane? I certainly never did. I simply
pre-folded my sectional to place my launch site more or less in the middle of
a flat rectangle of map, folded wisely (as in, if I flew off the pre-selected
area, the next en-route area was no more than a fold away [sometimes two, if I
wished to keep my map rectangle the same size]), and occasionally hauled it
out as necessary (usually to double-check a town or distance). In less
familiar to me areas, I sometimes used my non-stick thumb to keep my place on
the sectional.
It's not as if glider XC speed-made-good is fast enough to warrant constant
refolding. Point being if refolding really is a problem, something needs to be
rethought...
Kinda-sorta related to the original question, try not and overthink XC issues.
Priority One is always to soar - as in, remain aloft. All the other stuff
merely tags along...navigation, can I get "there," O2 altitude (I know, not
generally a concern in FL), communication, speed made good, etc., etc.
Priority Two is to always be prepared (mentally and physically - as in you can
actually GET to your chosen field) to safely land along the way, because if
you fly XC you ARE going to make off-field landings, regardless of ship type.
To think otherwise is to make a serious mental error.
How you accomplish "priorities 3 through infinity" should reflect how you
think and interact with "all your soaring accoutrements." KISS is good, IMHO.
For example, I've never found it difficult/onerous to perform mental glide
calculations while on course. "X miles per thousand feet" and a decent
awareness of where I am (no cheating; you're AT wherever it is you're directly
above, NOT what you can see at some slight angle!) was/is dirt simple for me.
Where I can get from "there" sorts of "glider calculations" aren't
fundamentally different than is estimating where I plan to gas up the vehicle
when driving through western boonies...merely the view is distinctly more
pleasurable!
Bob - simple is good - W.
P.S. It would be fascinating to know the rates of airspace violations by
glider guiders, pre- and post-GPS. Even a cursory reading of contest reports
and scores on the SSA website quickly reveals a continuing litany of "airspace
violation penalties." GPS = "complete navigational precision?" Not!
Old September 11th 13, 11:54 PM posted to rec.aviation.soaring
Tony[_5_]
sailplane.
the sectional.
rethought...
pleasurable!
The GPS just makes the airspace violation much easier to prove.
I started off without a GPS but that was only because I couldn't afford one.. Now I don't leave home without it. In a 1-26 though, it's not too hard to tell whether or not you can glide to the next field. You don't need an advanced glide computer. If you can't see it you can't make it and if you can see it you might be able to make it. The only exception is if you can't see it because the nose is in the way, in which case you probably can make it. These same rules apply when I fly the Cherokee XC. Have fun!
Old September 12th 13, 01:18 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
reports and scores on the SSA website quickly reveals a continuing
litany of "airspace violation penalties." GPS = "complete navigational
precision?" Not!
Indeed, but there are different sorts of GPS units. If you ask that
question of a pilot flying with a vanilla device such as a Garmin GPS II+
or eTrex which points at your next waypoint and might tell you your cross
track error if you're lucky, I think the answer is that it doesn't do
anything more to keep you out of airspace than a map does.
However, if you're using even a very cheap satnav that is running LK8000,
XCSoar or equivalent with up to date map and airspace files and you've
set the airspace warnings appropriately, i.e. at least 500 feet vertical
warning and 60 seconds horizontal warning, then its very much easier to
stay clear of airspace.
Both programs will suppress airspace you're not in danger of entering:
this keeps the screen uncluttered. But, if you get within the vertical or
horizontal warning distances the airspace will be shown and an audible
alert is sounded.
In the UK its also possible to download a file containing plottable NOTAMs
for the day and to install that alongside the static airspace file for
use by XCSoar, LK8000, etc. This is excellent for avoiding temporary
NOTAMed airspace around air shows, major sporting events, etc.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 12th 13, 01:46 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
BobW wrote, On 9/11/2013 2:48 PM:
sailplane.
"unfolding a map" in the confines of a sailplane? I certainly never did.
I simply pre-folded my sectional to place my launch site more or less in
the middle of a flat rectangle of map, folded wisely (as in, if I flew
off the pre-selected area, the next en-route area was no more than a
fold away [sometimes two, if I wished to keep my map rectangle the same
size]), and occasionally hauled it out as necessary (usually to
double-check a town or distance). In less familiar to me areas, I
sometimes used my non-stick thumb to keep my place on the sectional.
You must have fly in very different places than I do, and you must fly a
much lower L/d glider. Keeping the map(s) in the right place was
constant struggle for me, even in relatively roomy cockpits like the Std
Cirrus and ASW 20. and a huge pain in the 301 Libelle. Flying in places
like Nevada with a high performance glider means my airport can be 60 or
70 miles away and in reach, but it's on the other side of the fold.
Unfold, you say? Well, then my alternate, which might be behind me,
disappears.
Worst case: fly where four maps come together - super hassle trying keep
track of where I am and what my options are.
glide calculations while on course. "X miles per thousand feet" and a
decent awareness of where I am (no cheating; you're AT wherever it is
you're directly above, NOT what you can see at some slight angle!)
was/is dirt simple for me. Where I can get from "there" sorts of "glider
calculations" aren't fundamentally different than is estimating where I
plan to gas up the vehicle when driving through western boonies...merely
the view is distinctly more pleasurable!
Sure, it's easy in flat lands, but not where there are mountains. I
can't use the distance/elevation of the airport, but have to use the
distance/elevation of somewhere along the mountain ridge that's between
me and the airport. That ups the mental effort a lot.
Agreed! But ... you find GPS complicated and maps simple; I find the
reverse.
precision?" Not!
The rates are much lower now, because now it's easier to avoid
unintentional violations, and pilots are much more motivated to avoid
intentional violations because they know they will be caught.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old September 11th 13, 10:00 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
flgliderpilot wrote, On 9/11/2013 8:54 AM:
and I land in it.
That's one good solution. I currently carry charts as a backup, because
I used them for about 15 years before Loran, then GPS became options, so
I know how to use them well.
Even so, next year I plan to ditch the charts, and carry another,
independent, flight computer. It might be a Butterfly or ClearNav vario
with battery backup, an app on a smartphone/tablet thingy, or maybe a
PNA running XCsoar.
email me)
First solo cross-country flight completed - question Bertie the Bunyip[_25_] Piloting 19 March 13th 08 08:17 PM
Cross country in the 1-34 mat Redsell Soaring 3 October 22nd 04 05:56 PM
a different cross-country time question Arden Prinz Piloting 3 December 29th 03 02:17 AM
A 4,200 NM cross-country Phil Verghese Piloting 0 September 1st 03 11:03 PM
Got my ticket.... now what (the cross-country question) bdl Piloting 6 July 13th 03 03:06 AM
