Well, I seem to have one. The polarization looks like it's about 45 degrees
off horizontal and, since I bought Eagle Eyes sunglasses specifically for soaring, I'm disappointed that I can't see the 302 with the glasses on. So I hit on a crazy scheme... Since Cambridge is no longer with us, I'm thinking of simply drilling new screw holes in my panel rotated by the required amount, which I'll measure with the instrument out of the panel. It'll look a little strange, but I'm pretty sure it won't take long for my feeble brain to accomodate to the rotation. Of course, before I start drilling, I'd gladly consider any other ideas. The glasses are terrific for soaring, but I'm not terribly fond of them outside the cockpit. Don't like the brown tint to everything. |
Surely there is someone out there, maybe who ever is servicing 302's these days, can rotate your lens 90 degrees!
Regards, -DW On Monday, September 16, 2013 4:01:37 PM UTC-4, Dan Marotta wrote: Well, I seem to have one. The polarization looks like it's about 45 degrees off horizontal and, since I bought Eagle Eyes sunglasses specifically for soaring, I'm disappointed that I can't see the 302 with the glasses on. So I hit on a crazy scheme... Since Cambridge is no longer with us, I'm thinking of simply drilling new screw holes in my panel rotated by the required amount, which I'll measure with the instrument out of the panel. It'll look a little strange, but I'm pretty sure it won't take long for my feeble brain to accomodate to the rotation. Of course, before I start drilling, I'd gladly consider any other ideas. The glasses are terrific for soaring, but I'm not terribly fond of them outside the cockpit. Don't like the brown tint to everything. |
Dan how difficult is it to take the case apart and rotate the
glass 90 degrees? That is all that is necessary. D |
On Monday, September 16, 2013 1:01:37 PM UTC-7, Dan Marotta wrote:
Well, I seem to have one. The polarization looks like it's about 45 degrees off horizontal and, since I bought Eagle Eyes sunglasses specifically for soaring, I'm disappointed that I can't see the 302 with the glasses on. So I hit on a crazy scheme... Since Cambridge is no longer with us, I'm thinking of simply drilling new screw holes in my panel rotated by the required amount, which I'll measure with the instrument out of the panel. It'll look a little strange, but I'm pretty sure it won't take long for my feeble brain to accomodate to the rotation. Of course, before I start drilling, I'd gladly consider any other ideas. The glasses are terrific for soaring, but I'm not terribly fond of them outside the cockpit. Don't like the brown tint to everything. A friend got his 302 repaired just few weeks ago by Gary Kammerer. Ramy |
Well, calling Gary *would* be the elegant solution but I thought he wasn't
working on CAI instruments any more. I can call... As to simply rotating the glass - that was my initial thought so I asked Paul at Cumulus Soaring. He thought the problem was with the actual LCD and not the front glass. So I started thinking about it... Having no direct knowledge of LCD construction other than at the highest level, I believe there's a back layer which contains the electronics, a layer of the liquid crystal, probably a transparent layer in front of that with whatever circuitry is necessary to complete the electric fields to change the state of the crystal, and a front layer, which may be polarized. There may be other layers which I don't think matter to this discussion. If it's the front layer of the sandwich, then it was incorrectly applied during manufacture and there's no fixing it. If, on the other hand, my imaginings are wrong and it *is* the front glass, then that should be easily rotated. Then the only problem is the possible violation of the electronic seal. Isn't this fun? "KiloKilo" wrote in message ... http://clearnav.net/main/cn-service.html |
Are you sure height and width of the display are the same? If not, no dice for taking it apart and rotating the glass.
I'll look again, but I believe the instrument face (that protrudes through
the panel) is round. At least, the hole is... "Steve Leonard" wrote in message ... Are you sure height and width of the display are the same? If not, no dice for taking it apart and rotating the glass. |
On Wednesday, September 18, 2013 9:17:15 AM UTC-5, Dan Marotta wrote:
I'll look again, but I believe the instrument face (that protrudes through the panel) is round. At least, the hole is... My bad, Dan. My first read thought you were talking about the nav display, not the vario display. |
| InReach: does it have a "daily" track display? | Eric Greenwell[_4_] | Soaring | 6 | March 3rd 13 05:57 PM |
| Raptors are the worlds most advanced ground display "aircraft" | Dan[_15_] | Piloting | 2 | October 24th 11 02:02 AM |
| CAI302 altitude in NMEA.. | PCool | Soaring | 6 | October 23rd 09 08:25 PM |
| "Helmet system replaces heads-up display on F-35s" | Mike[_1_] | Naval Aviation | 19 | May 11th 07 02:45 PM |
| Which would draw more juice? A glass display Dynon Efis-D100 or regular style "Steam Gauges" that are electric. | [email protected] | Home Built | 3 | September 30th 06 09:36 PM |
