Zenith CH 601 vs. CH 701, better?
Old February 20th 04, 08:01 PM
DL152279546231
Default Zenith CH 601 vs. CH 701, better?
I am thinking about building either a Zenith CH 601 or CH 701.Initially I was
only looking at the 701 because of looks, its STOL capability, its high wing,
because of its squared off design I believe it should be easier to build.
Drawbacks of the 701 range and fuel consumption, increased drag. Anyone out
there have any experience with having to choose between these two? I am
thinking the CH 701 would be fun to fly around in but it looks as if it might
be as slow as a car on the interstate flying cross-country
Old February 20th 04, 09:39 PM
Dave Covert
Best to decide what kind of flying you really want to do... aircraft design
is a big ball of compromises. Huge lift means huge drag, huge drag means
slower top speed or a bigger engine, bigger engine means short legs or huge
tanks, etc etc There is no such thing as a home-built design that takes off
in 100ft and then cruises at 135mph on 4 gal/hr. (unless you have a design
that changes its shape based on the phase of flight it is in, the
ever-popular 'morpho-kit').
Dave
"DL152279546231" wrote in message
was
wing,
out
might
Old February 20th 04, 09:56 PM
Gig Giacona
was
wing,
out
might
I'm building a 601XL and have seen 701s under construction. There is not
that much difference in building complexity.
What you need to decide is how you are going to use it. If you need the
short field and aren't planning a lot of cross country trips go with the
701. If you plan to use it as I do, which is a pretty even mix of local and
cross country go with the 601XL.
No mater which one you pick, go to the builders workshop at the factory. It
will be the best money you spend on the thing.
You can see photos of my construction at www.peoamerica.net/N601WR
Old February 21st 04, 06:37 AM
The other posters are right on about knowing what you want to do with plane.
One option not mentioned, though, is to use the Dedalius wing designed for the
701 that does "morph". It is a kit that you can build instead of the Zenith
wing. It has passive retractable slats, so it cleans up somewhat in normal
flight, and according to Dedalius, it will cruise 20% faster than the stock
Zenith, while maintaining the STOL characteristics. The cost to build this
wing over the Zenith is about $2000. The Dedalius site is:
http://www.dedaliusaviation.com/newdedalius/anglais.htm
Happy trails,
tom pettit
Old February 27th 04, 03:10 AM
Scrappman
Both are pretty close built to factory specs, want more speed,,, go
tail dragger on the 601XL,,, 20 more mph....easy,
Scrappman
There will be a new design at sun'n fun, gotta be there to see it,,, no
I not going to tell,,,,,,,,
Happy trails,
tom pettit
Old February 24th 04, 04:35 PM
Ken Finney
was
wing,
out
might
Are you aware that the January 2004 issue of Kitplanes compared the two?
Old February 28th 04, 07:01 AM
DL152279546231
Thanks, I will check into getting the back issue
EAA flyin census info, actively flying homebuilt #'s?? DL152279546231 Home Built 4 February 17th 04 09:05 PM
Zenith CH 300 kit DougK Home Built 1 February 16th 04 11:40 PM
FAA/NTSB accident data base?? DL152279546231 Home Built 7 February 16th 04 05:21 PM
Zenith Ch 701 Builder's info and websites?? DL152279546231 Home Built 1 February 10th 04 09:21 PM
Zenith Zodiac XL question Mick Home Built 4 January 14th 04 06:47 PM
