I wonder how other pilots of flapped ships are using their flaps. I don't use any flap till I am aligned with the runway on final approach. Don't like the sluggish aileron control and the forward stick pressure required on the dreaded base to final turn. I switch to positive flap on final. Any comments ?
Dan G |
For an ASW20:
Thermal flap on downwind. Landing flap on final. What does the manual recommend for your glider? |
On Sunday, October 13, 2013 10:22:16 AM UTC-4, chuck wrote:
For an ASW20: Thermal flap on downwind. Landing flap on final. What does the manual recommend for your glider? OOPs Ship is a Ventus C and the manual talks only about approach flap position which I take to be on Final. It recommends Landing flap or thermal flap. I Wonder why do you use thermal flaps on downwind ? Dan G |
On Sunday, October 13, 2013 3:22:16 PM UTC+1, chuck wrote:
For an ASW20: Thermal flap on downwind. Landing flap on final. Why would you want thermal flap downwind in a 20? You're probably flying at 55 kts - so neutral flap gives better performance and handling. Thermal flap or landing flap on final, sure, depending on the conditions and desired approach speed. Personally I almost never use full landing flap - but position 5 instead. Having said that, I fly a 20F, and I think later versions of the 20 had less flap in the landing flap position. Paul |
On Sunday, October 13, 2013 12:27:30 PM UTC-4, wrote:
Thank you Bob for the detailed post. I am flying a Ventus C with airbrake and flap combination. Dan G The answer to your original question varies immensely depending on type of glider. For your glider, first consult the manual... Then, it depends on the type of wingtips fitted. With the original tips you may find roll control 'uncomfortable' in landing configuration and rough conditions, in which case don't use 'L'. With winglets fitted (or short tips) this is less of a problem in your glider... Hope that helps ! Best Regards, Dave "YO electric" |
At 16:55 13 October 2013, Dave Nadler wrote:
I completely agree with Dave's comments; on the PIK20E ( and maybe D) the L position (16deg) degrades the roll control so much that I never use it; landing sequence on downwind is gear down, flaps to +12, trim for approach speed required. JMF On Sunday, October 13, 2013 12:27:30 PM UTC-4, wrote: Thank you Bob for the detailed post. I am flying a Ventus C with airbrake and flap combination. Dan G The answer to your original question varies immensely depending on type of glider. For your glider, first consult the manual... Then, it depends on the type of wingtips fitted. With the original tips you may find roll control 'uncomfortable' in landing configuration and rough conditions, in which case don't use 'L'. With winglets fitted (or short tips) this is less of a problem in your glider... Hope that helps ! Best Regards, Dave "YO electric" |
Dave, I wonder about the use of positive flaps in my Ventus C during downwind and base legs. Dan On Sunday, October 13, 2013 12:55:19 PM UTC-4, Dave Nadler wrote: On Sunday, October 13, 2013 12:27:30 PM UTC-4, wrote: Thank you Bob for the detailed post. I am flying a Ventus C with airbrake and flap combination. Dan G The answer to your original question varies immensely depending on type of glider. For your glider, first consult the manual... Then, it depends on the type of wingtips fitted. With the original tips you may find roll control 'uncomfortable' in landing configuration and rough conditions, in which case don't use 'L'. With winglets fitted (or short tips) this is less of a problem in your glider... Hope that helps ! Best Regards, Dave "YO electric" |
| Pattern for IFR | Mxsmanic | Instrument Flight Rules | 8 | September 9th 08 04:37 PM |
| Teaching Incremental Flaps in the Pattern | [email protected] | Piloting | 30 | March 7th 08 02:01 AM |
| flaps again | Kobra | Owning | 84 | January 5th 08 05:32 AM |
| C-182 pattern help | SilkB | Piloting | 16 | September 15th 06 11:55 PM |
| Right of Way in the pattern? | Kingfish | Piloting | 12 | August 11th 06 11:52 AM |
