Airplane turns
Old April 17th 04, 12:28 AM
Dave
Default Airplane turns
I'm curious as to how an airplane behaves during turns. It is my
understanding that once you put the plane into a turn and return the
yoke to a level position, the plane will stay in a turn but will
straighten itself out slowly. Does the rate at which the airplane
straightens out vary by model? For instance, a Cessna 152 vs. a
Boeing 747? Does it vary among jetliners, i.e. a 757 vs. a 777?
Old April 17th 04, 12:47 AM
Robert Moore
From the FAA Flight Training Handbook:
TURNS
A turn is a basic flight maneuver used to change or return to a
desired heading. It involves close coordination of all three flight
controls: aileron, rudder, and elevator. Since turns are a part
of most other flight maneuvers, it is important to thoroughly
understand the factors involved.
For purposes of this discussion, turns are divided into three
classes: shallow turns, medium turns, and steep turns.
• Shallow turns are those in which the bank (less than approximately
20°) is so shallow that the inherent lateral stability of the airplane
is acting to level the wings unless some aileron is applied to maintain
the bank.
• Medium turns are those resulting from a degree of bank (approximately
20° to 45°) at which the airplane remains at a constant bank.
• Steep turns are those resulting from a degree of bank (45° or more)
at which the “overbanking tendency” of an airplane overcomes stability,
and the bank increases unless aileron is applied to prevent it.
Bob Moore
Flight Instructor
Old April 17th 04, 12:58 AM
Teacherjh
To add to this answer (about how an airplane behavs during turns), most
airplanes are designed with dihedral. This means that the wings point up a
little bit. If you looked at a plane from in front of the nose, the wings will
form a slight V shape. This makes the "lift" that each wing produces point a
little bit inward, towards the center of the plane, rather than straight up.
Now, if the plane goes into a shallow bank, the wing that is lowered will
become more level, and the lift will point straight up, while the wing that is
raised will become more tilted, and the lift will point more towards the center
of the plane. More of the lift on this "tilted" wing is "wasted" (in the sense
of not holding the airplane up). So, since the other wing exerts more upwards
force, it causes the plane to return to level flight. This is one of the
things that makes an airplane inherently stable in flight.
Separate from this, when an airplane is banked in coordinated flight and
turning, the outer wing (which is the one that is raised to bank the plane to
make the turn) is actually travelling faster than the inner wing. It has to,
because that wing is further from the center of the turn. (to see this,
imagine the plane turning so sharply that it's just about pivoting on one
wingtip) The faster wing will produce more lift, and cause the airplane to
bank in the direction of the turn. This is called "overbanking tendency".
So, there are two opposite tendencies. Dihedral is more important with shallow
banks (and gentle turns), and the overbanking tendency is more important with
steeper turns and banks. Somewhere in the middle, they cancel out.
Jose
(for Email, make the obvious changes in my address)
Old April 17th 04, 01:29 AM
William W. Plummer
"Teacherjh" wrote in message
a
will
point a
up.
that is
center
sense
upwards
to
to,
to
shallow
with
Looking at the nose of the plane, we see the V-shape of the wings, the
dihedral angle. Lift is always perpendicular to the wings. So in flight,
the two lift vectors tilt in and "cross" over the plane itself. In level
flight the horizontal components of the two lift vectors are equal and
opposite. Thus, they cancel and the plane flies straight. Now, if you
bank the plane so that one wing is horizontal, that wing will have no
horizonal lift vector component. But, the other wing will have double. The
result is a big, net horizontal force on the plane. This forces the plane
to the center of the turn the way the force in a string swinging a rock
keeps the rock in a circle. That's what makes a plane able to go in a
circle, not the rudder.
Old April 17th 04, 02:45 AM
Teacherjh
Now, if you
Not quite. This does not change the direction of the nose, which is essential
for turning. By itself, what you post would lead to a slip. The plane would
travel in a straight line, at some angle to the nose.
Jose
Old April 17th 04, 03:59 AM
Peter Gottlieb
Now, if you
The
essential
would
I guess this confuses me a bit. Maybe I'm tired and my brain confuses
easily.
Isn't it the case, in an earth-centric reference frame, that an object
moving in a straight line, when subjected to a horizontal force
perpendicular to that motion, will move in a circle?
Old April 17th 04, 03:23 AM
Greg Esres
will become more level,
This is NOT how dihedral works.
Dihedral depends on sideslip. No sideslip, no stabilizing force.
Old April 17th 04, 01:26 PM
Teacherjh
Huh? I don't believe that is true, but explan further.
Jose
Old April 17th 04, 03:37 PM
Greg Esres
First, understand that for an airplane to right itself from a bank,
there must be a moment that rotates the aircraft around the
longitudinal axis. Therefore, the total lift on one wing must be
greater than the other. This extra force, times the moment arm,
creates the necessary moment.
The orientation of the wing lift to gravity is irrelevant.
When the aircraft sideslips in one direction or the other, there is a
component of the relative wind that moves parallel to the lateral axis
of the airplane. Due to dihedral, parallel to the lateral axis is not
parallel to the wing. When you resolve the vectors, you can see that
the sideslip creates a component of the relative wind perpendicular to
the surface of the wing, which increases its angle of attack. The
reverse happens on the other wing.
Most aerodynamics books contain detailed vector diagrams of this. The
FAA's material get this wrong, as does most aviation training
material. The point is, all dihedral effects depend on sideslip. In
theory, an aircraft in a coordinated turn should experience no
righting tendencies.
Old April 17th 04, 12:49 AM
Peter Duniho
"Dave" wrote in message
It depends on the airplane and the bank angle. Most airplanes have a narrow
range of bank angle at which the turn is stable, and the airplane will
continue indefinitely in the turn. At bank angles less than that, the
airplane will eventually return back to level flight. At bank angles
greater than that, the airplane will actually steepen the bank, which left
uncorrected would result in loss of control of the airplane.
The rates at which the bank changes does vary quite a bit from airplane to
airplane, as it depends on a variety of aerodynamic factors in the airplane
design. There are a few airplanes that won't return to level flight at all
without pilot input, as they've been designed as unstable airplanes (some
intentionally, some not).
Pete
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
