Everest Gliding Gimbal Project
Old November 23rd 13, 02:08 PM posted to rec.aviation.soaring
Jacek Witalinski
Default Everest Gliding Gimbal Project
Hi,
I designed gimbal for Sebastian Kawa for the Everest Gliding event. I think it might be interesting and I would like to share the info on this webpage.. The Link to the video: http://www.youtube.com/watch?v=__78nRjidUs
http://i.imgur.com/KT0Q4QT.jpg
description:
Are the gimbals limited to drones, handy or those that are close to the ground? I would say no.
This topic, which now I briefly describe, took me about two Months. The most important thing is that our glider pilot Sebastian Kawa, a multiple world champion in gliding, on Nov 16th he went with a Team to the Himalayas Mountains to make the world's first glider flight over Mount Everest. The glider has its own drive rotary engine for stand-alone start to a ceiling of 2000 m. The rest of the height he will have to reach by sail and thermal climbing. Project was prepared for couple years, they had a lack of proper camera stabilization, which I’ve designed and handmade. This Gimbal is designed for gliders and difficult high mountains environments:
Gimbal rotates 340 degrees and 170 in Yaw Pitch.
After analyzing all the factors that prevail during the flight at an altitude of about 8000 m reached new criteria:
1 Temperature -60C
2 Jet Stream blowing 200 to 350 km / h
3 Aerodynamics gimbal adapted to such speed
4 Battery disabilities and their resistance to low temperatures
And many others result from the above.
I’ve designed aero dynamical gimbal shape for GoPro 3+ on the board. Gimbal position is adjusted from remote panel equipped with LCD and controll sticks. 2.4Ghz provides Video streaming and 800MHz RC.
Whole devices and GoPro are charged from the main LiJon battery located in the device. There was no question of pulling cables, so everything acts autonomously.
The first tests in the air we did at the beginning of October, we found that Yaw power was too small. After increasing motors power, we could operate with gimbal at 120km/h, after next tests and appending additional gear we reached 150km/h with full operational it’s 20km/h more than average cruise speed.
Batteries, I found LiJon currently working at temperatures from -60 to +60 , 4000mAh . To simplify the process of charging I put protection against overcharge and discharge for each cells below targets. This is not a balancer, but enough not to damage the battery during a long flight when the batteries become depleted below a critical voltage.
All electronic controller components were chosen at a range up to +/-50C . Powered by Yaw I’ve set higher power to treat the coil of the Yaw motor it as a heater. The stabilization temperature lacked the time, but I think that's enough.
All of the structures are made from CF to reduce weight with maximum strength.
Here is a short video of the flight test. Keep your fingers crossed for flight over the Himalayas our most known glider world champion.
Best Regards
Jacek Witalinski
Old November 23rd 13, 03:24 PM posted to rec.aviation.soaring
Matt Herron Jr.
On Saturday, November 23, 2013 6:08:21 AM UTC-8, Jacek Witalinski wrote:
Hi,
I designed gimbal for Sebastian Kawa for the Everest Gliding event. I think it might be interesting and I would like to share the info on this webpage. The Link to the video: http://www.youtube.com/watch?v=__78nRjidUs
description:
1 Temperature -60C
All electronic controller components were chosen at a range up to +/-50C .. Powered by Yaw I’ve set higher power to treat the coil of the Yaw motor it as a heater. The stabilization temperature lacked the time, but I think that's enough.
Best Regards
Jacek Witalinski
Very cool Jacek. Looks like you put a lot of work into it. I want one that can sit out on the wing and look where I look.
Matt
Old November 24th 13, 09:24 AM posted to rec.aviation.soaring
Jacek Witalinski
Hi,
description:
1 Temperature -60C
Best Regards
Jacek Witalinski
Matt
Yes it took almost two months withe this project. I hope that Sebastian will collect all of the approval from local government and will fly over Mount Everest. I wish him good luck.
Old November 23rd 13, 09:29 PM
Brad Alston Brad Alston is offline
Member
First recorded activity by AviationBanter: Jun 2011
Quote:
Originally Posted by Jacek Witalinski View Post
Hi,
Best Regards
Jacek Witalinski
Very nice. Congratulations Jacek on a the successful development of the gimbal. Looking forward to seeing more video produced using this sort of device. It sure takes soaring video to another level!
All the best!
Brad.
Old November 24th 13, 04:22 AM posted to rec.aviation.soaring
Paul Remde
Hi Jacek,
Very interesting! The video you posted from the new mount is very nice.
Best Regards,
Paul Remde
__________________________
"Brad Alston" wrote in message
Jacek Witalinski;847002 Wrote:
Hi,
Best Regards
Jacek Witalinski
All the best!
Brad.
Brad Alston
Mt Everest Gliding with Sebastian Kawa Wolf Aviator[_2_] Soaring 8 October 23rd 13 08:20 AM
NASA Project Mercury Pics.part12.rar (05/35) - NASA Project Mercury Pics.part12.rar (07/35) - NASA Project Mercury Pics.part12.rar (18/35) - NASA Project Mercury Pics.part12.rar (01/35) - NASA Project Mercury Pics.part12.rar (01/35) - NASA Projec The Old Bloke[_9_] Aviation Photos 5 August 18th 08 07:37 AM
Glider Altitude (Record?) over Mt. Everest [email protected] Soaring 2 January 19th 06 02:26 PM
First helicopter landing on Mt Everest Peter Duniho Piloting 13 June 6th 05 02:08 AM
AS350 B3 lands on top of Everest Guy Alcala Rotorcraft 0 May 26th 05 11:36 AM
