Cross Country Logging time
Old April 21st 04, 04:14 AM
Default Cross Country Logging time
I flew from Airport A to Airport B (did 1 touch-and-go) to Airport C
(did 1 touch and go) to airport D (did 3 touch and goes), then returned
to Airport A and landed. Airports A & D are greater than 50 nm apart.
Airports A&B, B&C, and C&D are less than 50 nm apart, respectively.
Should I log the entire flight as a 50nm Cross Country flight, or just
a portion? Should I delete the time spent doing touch and goes at
Airport D from the Cross Country time?
Old April 21st 04, 04:38 AM
Andrew Sarangan
Jim wrote in :
You can log the whole flight as cross country because you went farther
than 50NM from your home airport. However, a more practical question is,
does this flight really build your cross country experience? My guess is
no. So it really depends on what you are logging for.
Old April 21st 04, 04:49 AM
Mike O'Malley
"Andrew Sarangan" wrote in message
. 158...
Jim wrote in :
Are you planning on using the time for a certificate or rating? If so, none
of it is loggable, as each leg was 50 nm. BUT, for any other purpose,
(part 135 or 121 experience, insurence) it IS cross country, as defined
elsewhere in the regs, as any point to point flight.
Old April 21st 04, 05:05 AM
BTIZ
none
B***S***... by defintion of Part 61, and also FAQ file for Part 61, the
entire time can be counted towards a rating... he went more than 50nm from
airport A.. to D.. it does not matter how many airports he touched in
between. "the farthest point from the declared start of the cross country
counts." granted.. a prudent person might only log the time not spent doing
multiple T&Gs.
BT
Old April 21st 04, 06:15 AM
Marty
"BTIZ" wrote in message
news:Mpmhc.18180$432.6521@fed1read01...
none
doing
multiple T&Gs.
BT
I interpret this as it states, for a PPL applicant,
§ 61.109 Aeronautical experience.
(other requirements snipped)
(ii) One solo cross-country flight of at least 150 nautical miles total
distance, with full-stop landings at a minimum of three points, and one
segment of the flight consisting of a straight-line distance of at least 50
nautical miles between the takeoff and landing locations
Loggable as a X-country time for a student? Yes, provided the CFI signed off
on it.
But not valid for the one "long X-country" required for the PP rating.
MG
Old April 21st 04, 08:22 AM
Peter Duniho
"Marty" wrote in message
Nobody said it was.
Old April 21st 04, 02:23 PM
Mike O'Malley
none
doing
multiple T&Gs.
D'oh! Looks like I'm the confused one. I too confused the student x-c
requirement with a single leg over 50, with the 50nm requirement for
commercial and IR requirements.
I really need to start re-reading my regs again...
Thanks,
Mike
Old April 21st 04, 05:17 AM
Lisa
. 158...
Jim wrote in :
Probably just logging to have an accurate record of the flight. How would a
cross country flight not build one's x-country experience? Sounds like a
pretty good flight, lots of navigation, finding airports, and landing practice
too.
Huh? The OP stated that Airports A&D are greater than 50 nm apart. Based on
this, the leg from Airport D to Airport A was greater than 50 miles.
Therefore, the entire flight may be logged as a cross country for the purposes
of satisfying any requirement for cross country flight of greater than 50
nautical miles.
You are correct that any point to point flight may be considered "cross country"
but the OP was clear about logging for the purpose of a 50 nm cross country.
Old April 21st 04, 04:47 AM
G.R. Patterson III
a portion?
Log the whole thing.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 21st 04, 04:52 AM
Hilton
Jim,
Log it all as XC time.
Hilton
"Jim" wrote in message ...
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 10:46 PM
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 09:45 PM
Canadian cross country -- got any old WAC charts? Duane MacInnis Piloting 2 February 26th 04 01:34 AM
US cross country flight S Narayan Piloting 0 January 7th 04 02:58 PM
