I need to replace the oil seal (06A19956 or STD208) in the vacuum pump
adapter (61098) on my Lycoming IO320. How can I remove the existing seal without a special Lycoming removal tool? The oil seal is .875" ID x 1.5" OD x .3" thick. ALL suggestions taken seriously Thanks |
The usual way. Drive a sheet metal screw into the metal part, grab the
head of the screw with a pair of vice grips, and yank. Ron wrote: I need to replace the oil seal (06A19956 or STD208) in the vacuum pump adapter (61098) on my Lycoming IO320. How can I remove the existing seal without a special Lycoming removal tool? The oil seal is .875" ID x 1.5" OD x .3" thick. ALL suggestions taken seriously Thanks |
![]() don't have one to look at, but if the metal back is bottomed in a recess, and you can get access to the back side, drill a couple of 1/8" holes from the back side, 180 deg apart & punch out , alternating between holes to keep it straight,( as possible ) rip wrote: The usual way. Drive a sheet metal screw into the metal part, grab the head of the screw with a pair of vice grips, and yank. Ron wrote: I need to replace the oil seal (06A19956 or STD208) in the vacuum pump adapter (61098) on my Lycoming IO320. How can I remove the existing seal without a special Lycoming removal tool? The oil seal is .875" ID x 1.5" OD x .3" thick. ALL suggestions taken seriously Thanks |
Tiny vacuum pump | Jim Weir | Home Built | 41 | January 24th 04 05:42 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
