I've seen a few homebuilts with part of the fuselage panel that are flat
aluminum that are quite wrinkly and tend to "oil can" and make noise in various flight attitudes. I haven't seen cross breaks used to stop this, although it is used in duct work to stiffen flat panels. (cross breaks are slight bends in the metal, done diagonally from corner to corner) Another thought to reduce this noise is to spray urethane foam on the panels. I know that this foam is combustable, but I figure for it to get on fire would mean the pilot and passenger cabin is already engulfed, so it wouldn't really matter. What do you think? thanks, tom pettit |
Howdy All,
Thanks for your thoutful replies. They seem to fall into three main ideas: Thicker panels: yeah. This will work, but for exterior fuselage panels, it would be prohibitively heavy. I'll pass. Building in some kind of "upset": This will work. Breaks, as I described will make the panels stiffer. Another poster suggested rolling in ridges that would stiffen the panel. These would look kind of goofy, and have a small drag effect. I think I'll pass. Spraying a urethane foam on the inside: This will stiffen the panel and improve the noise level inside the aircraft. It would require a fire rated foam such as "gator skin". Other are available. I'm leaning this way. Thanks to all, tom pettit |
Howdy All, Building in some kind of "upset": This will work. Breaks, as I described will make the panels stiffer. Another poster suggested rolling in ridges that would stiffen the panel. These would look kind of goofy, and have a small drag effect. I think I'll pass. tom pettit Tom, your plane, and you'll do as you please, but I don't think it would have to add a measurable amount of drag or look goofy. I'm thinking of a WW2 Japanese rising sun motif, starting at the center or the front edge and expanding toward the back. Aaah, if there were only time to build every iteration of airplane that I could dream up. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
In article , Richard Lamb wrote:
Spraying a urethane foam on the inside: This will stiffen the panel and improve the noise level inside the aircraft. It would require a fire rated foam such as "gator skin". Other are available. I'm leaning this way. Thanks to all, tom pettit Lean back the other way some, Tom. You are about to fall off of something here... Filling large cavities with foam may be great for boats, but don't do it to a metal airplane. The lightest mix you'll get will be at least 3 pounds per cubic foot, minimum. Richard Sorry I wasn't clearer on my intention. I'd only spray about an inch on the panels. Not much weight, and still get significant damping. tom |
ala TriMotor - corrugations
-- Dan D. .. wrote in message ... Howdy All, Thanks for your thoutful replies. They seem to fall into three main ideas: Thicker panels: yeah. This will work, but for exterior fuselage panels, it would be prohibitively heavy. I'll pass. Building in some kind of "upset": This will work. Breaks, as I described will make the panels stiffer. Another poster suggested rolling in ridges that would stiffen the panel. These would look kind of goofy, and have a small drag effect. I think I'll pass. Spraying a urethane foam on the inside: This will stiffen the panel and improve the noise level inside the aircraft. It would require a fire rated foam such as "gator skin". Other are available. I'm leaning this way. Thanks to all, tom pettit |
Blueskies wrote:
ala TriMotor - corrugations -- Dan D. Absolutely. MUCH thicker skins ![]() Rihcard |
In article , "Blueskies" wrote:
ala TriMotor - corrugations I kind of like the idea of corregations. Any ideas on how to accomplish them? thanks, tom |
