Gordon Boettger Downwind Wave Record Attempt - Mon 02/17/2014
Old February 17th 14, 01:51 AM posted to rec.aviation.soaring
WaltWX[_2_]
Default Gordon Boettger Downwind Wave Record Attempt - Mon 02/17/2014
At sunrise on 17 February, we are planning on launching in the Duo Discus glider from Minden at sunrise and aiming for Rapid City, SD as our goal, a distance of over 933 miles. Below is a link to the map with our position updates every 5 minutes. If you'd like to see the details of our position, you can click on the blue dots on the map to see our speed, altitude, time, and position. Please do not send text messages to the InReach as I will be extremely busy. Walt Rogers will be assisting in weather and communications with us throughout the flight. We just have to hope that the weather lines up properly for this to happen. It should be fun to watch as a lot can happen flying without a motor.
Gordon Boettger is sharing their location at the MapShare web site: https://share.delorme.com/GordonBoettger
Follow on twitter: https://twitter.com/wrogerswx
Walt's Blog: http://scriptogr.am/wrogerswx/archive
NOTE: Due to the large (70+) cc: address on Gordon's past flights, we must significantly cut back entries on that list. Please, monitor the flight either on my twitter feed @wrogerswx or my blog. Last time, Google shut down my email account late in the afternoon.
Old February 17th 14, 02:11 AM posted to rec.aviation.soaring
Tony[_5_]
Woohoo GO MAN GO!
Old February 17th 14, 04:17 AM posted to rec.aviation.soaring
WaltWX[_2_]
Gordo's Flight Plan...
https://dl.dropbox.com/s/8abn83d7v2f...140217_sml.jpg
Old February 17th 14, 05:09 PM posted to rec.aviation.soaring
Dave Nadler
Thanks Walt - Is Hugh with Gordo on this attempt?
Old February 17th 14, 06:40 PM posted to rec.aviation.soaring
Dave Nadler
Gordo looks kinda stuck a bit past Fallon.
Looks like he's trying to climb back up but
hasn't gained 2000 feet in the last half hour?
Hope he gets up and going again...
Old February 17th 14, 07:51 PM posted to rec.aviation.soaring
Kevin Christner
My best guess is he's gone about 180mi so far...
Old February 17th 14, 08:18 PM posted to rec.aviation.soaring
The satellite loop is interestingly blue. Gorgeous lennies all over Oregon. Was this forecast?
John Cochrane
Old February 17th 14, 08:50 PM posted to rec.aviation.soaring
JS
It'll be slower going without confidence the wave is working ahead.
Currently working the Rubys, S of Secret Pass at 18.
In that area you're low below about 12, even on thermal days. The nearest airport Wells Harriet is at 5770'.
Old February 17th 14, 09:32 PM posted to rec.aviation.soaring
Kevin Christner
Climb up to 27k just west of Salt Lake. With a ~75kt tailwind that should give him a gliding range of 350mi+ added to about 250 done so far.
Old February 17th 14, 11:17 PM posted to rec.aviation.soaring
Tim Taylor
He just passed Logan, but low near Bear Lake. Hopefully he can get up near Meade Peak and then on to the Salt River Range. He should at least get to Afton Wy.
Gordon Boettger 1000 mile attempt going on right now Bob Soaring 11 April 16th 13 04:16 AM
Long Wave Attempt christine anderson Soaring 0 May 3rd 12 10:52 PM
Boettger & Bennett in wave again 4/28 Soaring NV[_2_] Soaring 7 April 29th 11 12:39 AM
Boettger-Bennett 2,200 KM record flight from Minden Mitch Polinsky[_2_] Soaring 13 April 26th 11 08:57 PM
MSC podcast with Gordon Boettger - Preparing for the Wave [email protected] Soaring 9 February 2nd 06 04:20 PM
