Motor-glider talks at SSA convention in Reno
Old February 22nd 14, 07:36 PM posted to rec.aviation.soaring
Dave Nadler
Default Motor-glider talks at SSA convention in Reno
Hi Guys - For those of you interested in what
motor-gliders can and cannot do, safety, trade-offs
between types, etc, we have a couple talks in Reno
next week. Stephen Dee is speaking on Saturday, and
I'm speaking Thursday. Should clear up some of the
"interesting thoughts" on RAS recently ;-)
Hope to see some of you there !
Best Regards, Dave "YO electric"
Old February 24th 14, 08:56 PM posted to rec.aviation.soaring
Key Dismukes
On Saturday, February 22, 2014 2:36:17 PM UTC-5, Dave Nadler wrote:
Dave
For those us who can't make it out there, are you planning on making your slides or notes available?
thanks,
Key
Old February 24th 14, 09:21 PM posted to rec.aviation.soaring
Dave Nadler
thanks,
Key
I'll post this after the convention - usually I have a few
updates prompted by questions!
Sorry you can't make it to Reno,
Old April 16th 14, 01:21 PM posted to rec.aviation.soaring
Dave Nadler
Dave
thanks,
Key
Some bizarre ideas on RAS about motor-gliders!
I did post this, if anyone is interested in,
ya know, facts and experience, as opposed to
Random Aviation Speculation...
Sane motor-glider pilots DO NOT try an air-start
until they have a pattern planned and are in
position for landing after a worst-case failure,
which takes more altitude than landing an
un-powered glider...
Enjoy,
Best Regards, Dave
http://www.nadler.com/papers/2014_So...aker_notes.pdf
http://www.nadler.com/public/NadlerSoaringIndex.html
Old April 16th 14, 07:45 PM posted to rec.aviation.soaring
jfitch
Dave
thanks,
Key
Enjoy,
Best Regards, Dave
Interesting talk. I have two comments:
You recommend not beginning the engine start (attempt) until on downwind leg in the pattern. This adds all of the engine start workload in the middle of a pattern, a pattern that will need to be altered perhaps radically depending on the result of the start attempt. For this reason I always attempt to start the engine above a landable field and well above pattern altitude. It if fails to start, I can now set up a pattern appropriate to the configuration of the glider and concentrate on its execution. This requires the discipline to know when to quite fiddling with the engine. With the electric, it probably makes more sense because it either works or not, but with gas there are quite a lot of things to fiddle with, if it doesn't catch immediately.
Second, while you mention the addition to pilot workload while trying to start the engine, I believe there is a significant addition to pilot workload anytime you are near the glideslope to safety. Perhaps I overthink things, but when I get near the glideslope, I begin to think: Should I start the engine now? If it doesn't start will I still have options with my now 20:1 glide? Should I give up on the engine and concentrate on my straight in approach? Should I have started the engine 5 minutes ago? How cold is it from my last 3 hours at 17,000? Etc.
These things are running though my mind when I really ought to be thinking about flying the glider as a glider, and distract me well before the decision to start the motor has been made.
Old April 17th 14, 03:48 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dave Nadler wrote, On 4/16/2014 5:21 AM:
Dave
thanks,
Key
Enjoy,
Best Regards, Dave
It's a decent presentation, but I do think "plummet mode" grossly
exaggerates the situation: my ASH 26 E does not have a "plummet mode",
nor do similar gliders like the DG 800, Ventus self-launchers, etc.
My ASH 26 E thermals almost as well with the mast in the cooling
position as fully retracted, and landing with the mast extended only
means using a bit less spoiler than with it retracted. I'd reserve the
term "plummet mode" to sustainers that require diving to start the engine.
For a thorough discussion of self-launching sailplane operation, I
suggest you read my 60 page "Guide", available free from the ASA
(Auxiliary-powered Sailplane Association) website:
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old April 17th 14, 11:08 AM posted to rec.aviation.soaring
Dave Nadler
As was discussed in the talk, had you bothered to attend...
Wrong...
... I'd reserve the
If you had flown some of the planes I have, you would
have a rather different opinion.
You are losing the plot. The sink rate of many of these
planes with motor out and not running is much, much,
higher than what glider pilots are used to. Not planning
for this has led to many, many accidents...
Be careful out there,
Best Regards, Dave
Old April 16th 14, 12:29 PM posted to rec.aviation.soaring
Dave Nadler
Dave
thanks,
Key
Sane motor-glider pilots do not do an air-start
until they have a pattern planned and are in position
for landing after a worst-case failure...
Enjoy,
Best Regards, Dave
SSA Convention at Reno, February 26 thru March 1 Burt Compton - Marfa Gliders, west Texas Soaring 0 February 22nd 14 04:39 AM
SSA Convention at Reno, February 26 thru March 1 Burt Compton - Marfa Gliders, west Texas Soaring 0 January 14th 14 03:54 PM
Reno Convention attendee's [email protected] Soaring 0 January 25th 12 09:31 PM
2006 Tailhook Convention - Reno, NV 7-10 September Mike Kanze Naval Aviation 0 June 7th 06 01:21 AM
2005 Tailhook Convention - Reno, NV, USA - 8-11 September Mike Kanze Naval Aviation 2 June 13th 05 07:41 PM
