I was leafing through the C172N POH for some flap settings yesterday and a
thought occured to me: there was a post here about some verions of the 172 having different full flap angles - some have 40 and 38 degrees. So i wonder, how do they determine these angles for all flap settings when the plane's still on the drawing board? Or is it an airfoil design thing? I've noted that for example the Learjet 45 has first setting at 8 degrees. How do they determine what is the right angle for each setting? Triple Delta |
"DeltaDeltaDelta" wrote in message
... I was leafing through the C172N POH for some flap settings yesterday and a If you read Russian (who knows, you might ![]() http://www.sla.ru/aviamaster/zipfiles/mexan_wing.pdf it pretty much answers all your questions and more. HECTOP PP-ASEL-IA http://www.maxho.com maxho_at_maxho.com |
Another option is to look for an aerodynamics course at a college
near you. |
They don't write the POH (AFM) until they've performance tested the
prototypes. -- John T Lowry, PhD Flight Physics 5217 Old Spicewood Springs Rd, #312 Austin, Texas 78731 (512) 231-9391 "DeltaDeltaDelta" wrote in message ... I was leafing through the C172N POH for some flap settings yesterday and a thought occured to me: there was a post here about some verions of the 172 having different full flap angles - some have 40 and 38 degrees. So i wonder, how do they determine these angles for all flap settings when the plane's still on the drawing board? Or is it an airfoil design thing? I've noted that for example the Learjet 45 has first setting at 8 degrees. How do they determine what is the right angle for each setting? Triple Delta |
"John T Lowry" wrote in message link.net...
They don't write the POH (AFM) until they've performance tested the prototypes. I think he's asking why manufacturers designate the flap settings as they do (not which setting should be used when). For example, the G550 has flap settings of 0, 10, 20, and 39; his question is something like "why 39 and not 40?" or "why do some 172's have 40 degrees of flap avalible and others only have 38?" Or "why are flap settings not evenly spaced?" Basically, how do they determine what flap intervals should be available? |
![]() "why do some 172's have 40 degrees of flap avalible and others only have 38?" Dunno about 38, but the newer ones have 30, because full 40 degree flaps were causing problems (which I can't recall) due to poor technique of some sort. Might have something to do with slips with flaps, IIRC. Jose -- (for Email, make the obvious changes in my address) |
"Teacherjh" wrote in message
... Dunno about 38, but the newer ones have 30, because full 40 degree flaps were causing problems (which I can't recall) due to poor technique of some sort. at 40 deg they sucked for crosswinds and that probably ruined a student or two complete with cross-control flutter, but were great for "carrier-deck" landings HECTOP PP-ASEL-IA http://www.maxho.com maxho_at_maxho.com |
zatatime wrote in message . ..
On 16 May 2004 02:06:53 GMT, (Teacherjh) wrote: "why do some 172's have 40 degrees of flap avalible and others only have 38?" Dunno about 38, but the newer ones have 30, because full 40 degree flaps were causing problems (which I can't recall) due to poor technique of some sort. Might have something to do with slips with flaps, IIRC. Jose Yep, slips with flaps was part of it, but a nose high attitude with full flaps on go-around is what bit most of the people before they changed to 30. z This month's edition of Flying has a good article by Richard Collins about landings and a lot of the article is devoted to the use (or when appropriate, the non-use) of flaps Blue Skies John |
Jose,
"why do some 172's have 40 degrees of flap avalible and others only have 38?" Dunno about 38, but the newer ones have 30, because full 40 degree flaps were causing problems (which I can't recall) due to poor technique of some sort. Might have something to do with slips with flaps, IIRC. I'm always amazed at the amount of misinformation running around here. Cessna switched to 30 degrees of flap deflection maximum on a heavier model of the 172 because of rate of climb requirements during a balked landing under the FARs. The earlier airplanes could meet the rate of climb with 40 degrees, the newer ones could not, so flap travel was limited to 30 degrees. There is no problem with slips with full flaps on a 172, it's another of aviation's old wives tales. For an interesting descent rate, fly a Cessna O-1/L-19 (Model 305) Bird Dog. It had 60 degrees of flaps available. All the best, Rick |
Flap Hinge Moment Calc | Bo | Home Built | 2 | February 2nd 05 10:26 AM |
Flap Hinge Moment Calc | Bo | Home Built | 0 | February 2nd 05 06:01 AM |
TAS vs. flap reflex angle | ELIPPSE | Home Built | 3 | January 13th 05 06:00 AM |
Duluth - Blue Angles this weekend | Montblack | Piloting | 18 | September 23rd 03 03:00 AM |
What should the flap postions be while taking off? | Shi Jin | Military Aviation | 2 | September 10th 03 01:22 AM |
