Cobra wheel bearing info
Old March 20th 14, 05:03 AM posted to rec.aviation.soaring
Paul Villinski
Default Cobra wheel bearing info
Bearings for the pre-1990 Cobra's are unsealed taper bearings. For the 13", 4-lug wheel, replacement bearings are available at auto parts stores like Autozone.
Large, inner bearing: Timken "Set 8" L45449 - L45410
Seal for this bearing: Timken 224015
Small, outer bearing: Timken "Set 1" LM11710 - LM11449
Wheel drums are available from Eastern Sailplanes for $125.
After recent misadventures with a disintegrating bearing en route to Florida I have added bearings and grease to the spares/tools in the trailer.
Old March 22nd 14, 01:33 PM posted to rec.aviation.soaring
David Cleveland
Thanks Paul. Great info! I just repacked my 1981 Cobra trailer bearings and was thinking about picking up a set of spare bearings for the unfortunate situation you refer to.
David
Old March 22nd 14, 03:11 PM posted to rec.aviation.soaring
Vaughn
FYI, I carry my spare bearings submerged in grease in a small paint can.
The can is fastened to the frame of my trailer with a long hose clamp
where it takes no space, is never in the way, and will never be lost. I
hope to never need them, but they will always be ready.
Old March 22nd 14, 03:51 PM posted to rec.aviation.soaring
s6
Le jeudi 20 mars 2014 00:03:07 UTC-4, Paul Villinski a écrit*:
Hi
I have a 2002 cobra trailer. The owner manual says I have permanently seal bearing. Now I have no idea what this mean. I am totally incompetent in mechanical things. Does it mean I have nothing do maintain.
Regards
Gilles
Old March 22nd 14, 04:11 PM posted to rec.aviation.soaring
GM
Hi
Regards
Gilles
Gilles,
I am not sure what bearing configuration a 2002 Cobra trailer has but 'permanently sealed bearing' means that it has polymer seal rings on either side of the bearing to keep dirt out and the grease in and is filled at the factory with the proper amount and type of grease. They are maintenance-free, like the wheel bearings on modern cars.
Uli
'GM'
Old March 22nd 14, 11:07 PM posted to rec.aviation.soaring
glidergeek
Maintenance free sealed bearings are maintenance free until they fail. Eventually the ring that traps the lubricant in and the dirt out will fail, the lube will throw the bearing will eventually get dry or contaminated or both. The trick is to replace before it goes there.
Old December 21st 14, 11:07 PM posted to rec.aviation.soaring
Hi
Regards
Gilles
Typically it means it's a "cartridge bearing" compared to a "taper roller bearing".
Easiest way to tell (without pulling it all apart) is to remove the dust cap on the center of the hub.
If there is a "castellated nut" and a lock device (like a cotter pin), then it's a pair of taper roller bearings.
These can be removed, cleaned, re-greased & reassembled (assuming they haven't dried out the grease and welded themselves together).
A cartridge bearing is "pre-assembled", can't really be opened/cleaned/greased and has no maintenance until it dies (usually late at night, middle of nowhere, while raining, etc.....).
Some will require a medium hydraulic press to remove the old bearing & install the new bearing.
cobra wheel bearings and brakes [email protected] Soaring 4 August 14th 12 12:21 AM
FS Cobra brake drum w/new bearing Hartley Falbaum[_2_] Soaring 1 December 3rd 11 02:05 PM
Cobra Trailer Replacement Wheel Chip Bearden Soaring 5 September 29th 09 09:35 PM
US source for wheel on the tongue of Cobra trailer? Mark Zivley Soaring 3 January 18th 05 04:51 AM
