can one log PIC if another person is flying
Old May 17th 04, 06:42 PM
Baron Man
Default can one log PIC if another person is flying
can one log PIC if another person is flying.
what if you're an instructor.
same for twins - if i have a ME instructor rating, can i
log PIC time in an airplane that i do not have formal
training in - but is similar cat/class - piston twin etc.
thanks
Old May 17th 04, 07:18 PM
Todd Pattist
Yes - 61.51 if "acting as pilot in command of an
aircraft on which more than one pilot is required under the
type certification of the aircraft or the regulations under
which the flight is conducted"
That too allows it
Yes if the SAME cat/class and a type cert is not required.
I'm not sure what you would consider to be a "similar"
cat/class. It's either the same cat/class or it's not, and
if it's not, the answer is no. As to whether it's a good
idea to instruct in an aircraft you have no familiarity
with, or what the insurance will say, I'll leave that to
others, but you're not required to have logged any formal
training in the models you instruct in before giving
instruction.
Todd Pattist
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
Old May 18th 04, 01:16 AM
BTIZ
Todd.. remember the make and model requirement for instructing in twins..
61.195
BT
"Todd Pattist" wrote in message
That too allows it
instruction.
Todd Pattist
___
Old May 20th 04, 01:52 AM
Richard Kaplan
"BTIZ" wrote in message
news:FBcqc.57800$iy5.38950@okepread05...
61.195
That only applies for instruction toward a certificate or rating.
Richard Kaplan, CFII
www.flyimc.com
Old May 18th 04, 01:46 AM
Dave
Todd Pattist wrote in message . ..
To add to the prior post, a safety pilot may also log PIC time while
assisting another pilot doing simulated IFR. In that case, both
pilots are logging PIC. This has been hotly debated where some have
vehemently argued that the safety pilot is not acting as PIC, and thus
can't log it. Then someone actually wrote the FAA and got a written
response from FAA councel that yes, the safety pilot is a required
crewmember under the conditions (simulated IFR) and therefore may log
it.
The safety pilot need not be an instructor - they only need to hold at
least private rating and be signed off in category/class.
Old May 18th 04, 03:58 AM
Teacherjh
And just to add to that, the safety pilot may only log PIC if he and the
pilot flying have agreed that the safety pilot will be the PIC per the
definition in 1.1.
And to add to =that=, if the safety pilot is not acting as PIC, he can log SiC
time.
Jose
Old May 18th 04, 11:09 AM
Ron Rosenfeld
Old May 20th 04, 01:19 PM
Bob Martin
time.
Jose
I've never quite understood what qualified for SiC time... if I go up
with a friend, and both of us have the ratings and such applicable to
the aircraft, does one person go PIC and the other SIC? Or can I only
do that if the aircraft is required to have 2 pilots?
Also, I've been logging the time I fly with my dad, even though I'm
not technically able to be PIC (no tailwheel signoff). I made up a
category I called "second pilot", since I figured that I was gaining
experience and all but I couldn't put it down as SIC. Could I have?
Old May 17th 04, 09:27 PM
Bob Moore
Yes....but 61.195 is applicable:
(f) Training received in a multiengine airplane, a helicopter, or a
powered-lift. A flight instructor may not give training required for the
issuance of a certificate or rating in a multiengine airplane, a
helicopter, or a powered-lift unless that flight instructor has at least 5
flight hours of pilot-in-command time in the specific make and model of
multiengine airplane, helicopter, or powered-lift, as appropriate.
Bob Moore
Northern NJ Flying Club Accepting New Members Andrew Gideon Aviation Marketplace 1 June 12th 04 03:03 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
the thrill of flying interview is here! Dudley Henriques Piloting 0 October 21st 03 07:41 PM
the thrill of flying interview is here! Larry Dighera Piloting 2 October 20th 03 04:38 PM
Wife agrees to go flying Corky Scott Piloting 29 October 2nd 03 06:55 PM
