Can a pilot flying an Experimental airplane use it to fly powerlines for
inspections. Of course he is compensated for that work. Did not find it in the AIM |
Experimental aircraft are restricted from carrying persons or property for
hire. There is no restriction against all commercial operations. Spotters, photographers, and other crewmembers are not persons or property being carried for hire. § 91.319 Aircraft having experimental certificates: Operating limitations. (a) No person may operate an aircraft that has an experimental certificate— (1) For other than the purpose for which the certificate was issued; or (2) Carrying persons or property for compensation or hire. (b) No person may operate an aircraft that has an experimental certificate outside of an area assigned by the Administrator until it is shown that— (1) The aircraft is controllable throughout its normal range of speeds and throughout all the maneuvers to be executed; and (2) The aircraft has no hazardous operating characteristics or design features. (c) Unless otherwise authorized by the Administrator in special operating limitations, no person may operate an aircraft that has an experimental certificate over a densely populated area or in a congested airway. The Administrator may issue special operating limitations for particular aircraft to permit takeoffs and landings to be conducted over a densely populated area or in a congested airway, in accordance with terms and conditions specified in the authorization in the interest of safety in air commerce. (d) Each person operating an aircraft that has an experimental certificate shall— (1) Advise each person carried of the experimental nature of the aircraft; (2) Operate under VFR, day only, unless otherwise specifically authorized by the Administrator; and (3) Notify the control tower of the experimental nature of the aircraft when operating the aircraft into or out of airports with operating control towers. (e) The Administrator may prescribe additional limitations that the Administrator considers necessary, including limitations on the persons that may be carried in the aircraft. |
"C J Campbell" wrote
§ 91.319 Aircraft having experimental certificates: Operating limitations. (a) No person may operate an aircraft that has an experimental certificate— (1) For other than the purpose for which the certificate was issued; And then...... Section 21.191: Experimental certificates. Experimental certificates are issued for the FOLLOWING PURPOSES: (a) Research and development. Testing new aircraft design concepts, new aircraft equipment, new aircraft installations, new aircraft operating techniques, or new uses for aircraft. (b) Showing compliance with regulations. Conducting flight tests and other operations to show compliance with the airworthiness regulations including flights to show compliance for issuance of type and supplemental type certificates, flights to substantiate major design changes, and flights to show compliance with the function and reliability requirements of the regulations. (c) Crew training. Training of the applicant's flight crews. (d) Exhibition. Exhibiting the aircraft's flight capabilities, performance, or unusual characteristics at air shows, motion picture, television, and similar productions, and the maintenance of exhibition flight proficiency, including (for persons exhibiting aircraft) flying to and from such air shows and productions. (e) Air racing. Participating in air races, including (for such participants) practicing for such air races and flying to and from racing events. (f) Market surveys. Use of aircraft for purposes of conducting market surveys, sales demonstrations, and customer crew training only as provided in Sec. 21.195. (g) Operating amateur-built aircraft. Operating an aircraft the major portion of which has been fabricated and assembled by persons who undertook the construction project SOLELY for their own education or recreation. (h) Operating kit-built aircraft. Operating a primary category aircraft that meets the criteria of Sec. 21.24(a)(1) that was assembled by a person from a kit manufactured by the holder of a production certificate for that kit, without the supervision and quality control of the production certificate holder under Sec. 21.184(a). |
You don't look in the AIM for regulations, Hankal. Look at 91.319.
Bob Gardner "Hankal" wrote in message ... Can a pilot flying an Experimental airplane use it to fly powerlines for inspections. Of course he is compensated for that work. Did not find it in the AIM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
PA-32 on Experimental Certificate | Mike Granby | Owning | 3 | July 21st 04 03:04 AM |
Experimental Exhibition Fuel | Robert Bates | Home Built | 7 | March 14th 04 11:48 PM |
Crashing Experimental on America's Funniest Home Videos | Jay | Home Built | 7 | March 10th 04 12:11 AM |
A couple Questions-Ramp Checks and Experimental Operations | Badwater Bill | Home Built | 48 | October 8th 03 09:11 PM |
