Mythbusters and explosive decompression
Old July 7th 04, 05:37 PM
Casey Wilson
Default Mythbusters and explosive decompression
Hi all,
I don't know if it was a rerun and has been thoroughly done over here,
but last nights episode of The Mythbusters 'busted' the explosive
decompression myth surrounding bullet holes in aircraft.
The guys sealed up a junked out cabin, pressurized it, then fired 9mm
bullets through first the skin and then a window. Nothing exciting happened.
Pretty interesting stuff.
They ended the episode by blowing a large hole in the fuselage. I was
out of the room when they set the charge so I don't know the size, shape,
etc. I did a bang up job of opening a hole.
My conviction of the miniscule damage to be caused by a sky marshall or
pilot popping off a few caps at a terrorists has been reinforced. The
diameter difference between a 9mm (.38") and a .44 Mag wouldn't make any
difference. Let's give the good guys the bigger cannon.
Old July 7th 04, 06:13 PM
C J Campbell
"Casey Wilson" wrote in message
Hi all,
here,
It was a re-run. And it sure does show how ridiculous the debate over arming
pilots and sky marshals can be.
Old July 7th 04, 06:30 PM
Luke Scharf
happened. Pretty interesting stuff.
One factor that they neglected to account for is that many airliners fly
at speeds approaching Mach 0.85. I'd have to see a section of aluminum
skin with a bullet-hole in it staying intact in a transonic wind-tunnel
that was running about that speed before I put much stock in their
results.
-Luke
Old July 7th 04, 06:37 PM
Earl Grieda
"Luke Scharf" wrote in message
news
results.
Also, if the test was done on the ground then of course nothing would
happen. It needs to done in a wind tunnel that is depressurized to simulate
30K feet.
Earl G
Old July 7th 04, 06:55 PM
Jack
30K feet.
"Of course", "Needs", and "Simulate" is it?
The only necessity arising out of your post is that it be ignored. Your
simulation of comprehension of the subject won't fly.
The subject has been done to death here on a regular basis. Those who
are convinced they are in great danger from the presence of fire arms in
their world will never admit that the threat to the integrity of the
aircraft from gunfire in an airline cabin is minuscule, especially when
compared to the aftermath of a successful hijacking.
Read the archives of this discussion and allow the rest of us to
consider more interesting topics.
Jack
Mike Rapoport
What difference would that make?
Mike
MU-2
"Earl Grieda" wrote in message
ink.net...
news
results.
simulate
30K feet.
Earl G
Old July 7th 04, 09:19 PM
Bob Martin
simulate
30K feet.
Or, you can just do what they did, and pressurize it on the ground to get
the same pressure differential.
A small bullet hole will not cause much of a structural problem--you aren't
going to see an entire fuselage section ripping off because of aerodynamic
forces. What they did with the shaped charge might cause some problems, but
otherwise the slipstream wouldn't be much of an issue (structure-wise).
Old July 10th 04, 03:38 AM
Jack Davis
On Thu, 08 Jul 2004 19:03:35 +0000, Mackfly wrote:
Gads are we thinking here??? 8.5 PSID(or whatever) is the same at any
altitude----Mac
Thanks for the laugh, I needed that!
-Jack Davis
B737
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old July 7th 04, 06:54 PM
Mike Rapoport
Gee what do you think the indicated airspeed is at M.85 at FL350?
Mike
MU-2
news
results.
-Luke
Mythbusters Explosive Decompression Experiment C J Campbell Piloting 49 January 16th 04 07:12 AM
More Explosive Decompression John Galban Piloting 5 January 7th 04 09:34 PM
