Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
turbo video
Old August 11th 04, 04:23 PM
Peter Holm
Default turbo video
Hi,
I donīt know much about aerobatics, but I would love to see a video of
an aerobatic airplane with turboprop engine doing the vertical climb
and the torque roll. A search with the Google machine for "turboprop,
video" on this forum didnīt give me any results. Does anyone here know
about such a video and where I can see it?
Thanks!
Peter
Old August 17th 04, 05:12 AM
John Clear
Do a search on 'Turbo Raven'. Wayne Handley's site doesn't appear
to have video, but there is probably some out there. Unfortunately,
the Turbo Raven was only flown for one season.
http://www.waynehandley.com/archive.html
John
John Clear - http://www.panix.com/~jac
Old September 17th 04, 04:07 AM
Peter Holm
Itīs been a while and I have been rather busy, but I nevertheless
didnīt want to let pass the deadline for responding.
(John Clear) wrote in message ...
(cut)
John
Besides you, there has been one other person answering to my mailbox.
And that answer referred itself to the Turbo Raven as well. But I
havenīt yet found any video of that aircraft. In fact, it seems to me
as if that aircraft has been the only dedicated turboprop aerobatic
aircraft that was ever flown. And that there is nothing today. Am I
wrong on that?
Just in case that I am right:
I know that a turboprop airplane can easily cost twice as much as a
piston plane of the same size. But this fact could only explain a
relative rareness of turboprop airplanes among aerobatic planes. What
it cannot explain is their (next to?) absence, since experience shows
that if there is a will there is a way, and some or another team of
people should always be able to adquire one of these planes.
If I extrapolate by scale from what I have frequently seen with model
aircraft (which tend to have a much higher power to weight ratio than
full scale aircraft), an aerobatic turboprop plane should be able to
execute a sustained torque roll at 10 or 15 feet above ground. And
that ought to be an absolutely awsome sight! Has anybody ever done
that?
But now I think that - sadly - I will never get to see that, and I am
starting to wonder why.
I know that piston engines can have certain advantages under certain
conditions: For example, when it comes to propulsion on a solid
surface (greater range of rpmīs), or when it comes to the
transportation of large amounts of goods at a minimal price on a
liquid medium (fuel eficiency). But when it comes to airplanes, I can
see that turbo engines are employed either next to exclusively
(commercial/military airplanes) or at least frequently
(private/business airplanes), exept in the case of crop dusters - and
aerobatic airplanes. Now I can understand that turbo crop dusters make
little sense, but how about in the case aerobatic airplanes?
Therefore, my question is (always assuming that my basic assumption
above is correct):
Is there a rational reason for the next to absence of turboprop planes
among aerobatic aircraft, or is this absence perhaps due to some sort
of stubborn romanticism?
Peter
Old September 17th 04, 11:06 AM
Byron J. Covey
Peter:
"Peter Holm" wrote in message
om...
(cut)
John
wrong on that?
The first that I saw was a turbo Great Lakes, sponsored by Mennen (the
aftershave company.) It used smoke that smelled like the aftershave, and
did a vertical S ontakeoff. That was in the eaarly 1970's as best as I
remember.
The Turbo Raven flew for a short time before the crash.
There is a turbo Sukohi that Ihave seen photos of, but I haven's seen it
live.
Just a SWAG, but I would think that the Turbo Raven cost about 6 times what
a good Edge 540 would cost. Sponsorship before construction would be
important.
that?
Doins so would be betting one's life and airplane on no wind gusts,
absolutely no pilot miscalculation, and no aircraft / engine problem.
I have seen the Turbo Raven hover, descend vertically, then ascend
vertically. Scary to watch.
Rich and foolish is not a combination that survives long.
Turb crop dusters make lots of sense for large scale application, are
numerous, ane are profittable.
above is correct):
Cost is a rational reason. Turbine engines are not allowed in international
aerobatic competition.
Peter
BJC
Old September 17th 04, 07:38 PM
Peter Ashwood-Smith C-GZRO
There are actually a number of tubro powered aerobatic planes, think
for example of the PT-6 trainers.
For competition aerobatics however which includes lots of gyroscopic
forces, there are I believe concerns about the long shafts in those
engines and the huge gyroscopic forces at work. That would limit them
to sportsman stuff .. which is quite a restriction for a $1,000,000 +
airplane.
I suspect also the time required to spool up/down the power is an
issue.
Peter
Old September 17th 04, 10:12 PM
nametab
Power reaction is not such an issue for a single-shaft engine. My engine can
go from 10-90% torque in one second, no problem.
However, you did hit on the larger problem: Very high gyroscopic forces.
Although the spinning mass is not very large, my engine turns at 43,500rpm.
That's loads of gyro. I have to be very careful not to snap against the
engine or I might just loose it.
BTY, I fly aerobatic helicopters, so there's a larger gyroscope to deal
with, but it "flies"...
"Peter Ashwood-Smith C-GZRO" wrote in message
om...
airplane.
issue.
Peter
Old September 19th 04, 07:40 AM
John Clear
important.
Larry Ellison, CEO of Oracle, and owner of many big boy toys, is
also a fan of aviation. The story goes that he was talking with
Wayne Handley and Sean Tucker after some airshow, and they hatched
the idea of the Turbo Raven. Cost isn't much of an issue for Larry
Ellison, since he is way up there on the various 'richest people'
lists.
Another post mentioned the difference between aerobatics and
competition aerobatics. The T-6A and various other trainers are
aerobatic turboprops, but they don't have to worry about staying
in the competition aerobatic box, which is quite tiny. The cost of
a turboprop, and the size of the box are probably the main reasons
they aren't used on competition planes. The maintenance requirements
on the turboprop would probably also be an issue.
The Turbo Raven was just a show plane, in the same category as the
jet powered Waco. Fun to watch, but totally ridiculous.
John
Old September 19th 04, 04:19 PM
nametab
Turbines are not more difficult to maintain. In fact the maintenance is much
lower on a turbine (on a per-hour basis). The cost of the overhaul is quite
different though! However, the TBO is much better for a turbine. Overhaul on
my turbine is about US$235,000 but I get 3000 hours out of it. It's quite a
bit more expensive than other turbines, but you still are in the US$100,000
zone for an overhaul of a 600hp+ engine.
How much would a 600hp piston engine cost to overhaul?
"John Clear" wrote in message
what
important.
lists.
John
Old September 26th 04, 04:40 PM
Peter Holm
(cut)
lists.
As you concede yourself, when it comes to aerobatic airplanes there
exists a source of financing which generallty doesnīt exist for
private airplanes: Sponsoring. Therefore, the cost argument in itself
can only explain the relative scarcity of turboprop engines in private
aircraft, but not the near absence of turboprop engines in aerobatic
aircraft.
If the competition aerobatic box tends to be too small for turboprop
planes, then it is inconceivable why they do not install a greater
competition box for turboprop planes.
John
Well now, this jet powered Whacko is nothing but a piston biplane
with a turbojet strapped to its belly. And this turbojet engine has a
bent exhaust pipe - kind of like a turboprop. As long as I havenīt
seen more data on this plane or seen it fly, I wonīt believe that this
setup has much more than decorative value.
And now you come and compare this thing with .... a classical
turboprop plane? Sorry, but thatīs what I would call ridiculous. You
know as well as I do, that turbomachinery rules the airwaves - exept
for a relative scarcity among private airplanes and a next to absence
among aerobatic aircraft. And this is clearly a non trivial fact which
requires a cogent explanation.
Peter H.
RIAT and Video Patrouilles du Monde Aerobatics 0 July 10th 04 06:18 PM
Copyright Đ2004-2025 AviationBanter.
