A friend of mine is curious:
1. If a runway is closed by NOTAM at a non-towered airport, does that mean that the adjacent *taxiway* can't be used to legally take-off and land? (I know the insurance company would have an opinion about this, also, but let's ignore that aspect for the moment.) 2. We all know about the minimum fuel requirement for take-off. If one were to land with less fuel in the tanks than the required reserve (and without a good reason for using part of the reserve), can the FAA violate you for negligence? Please post in the groups (the email address I'm using here is primarily a spam-trap) and, no, I'm not in trouble. :-) -Dave Russell 8KCAB |
"Dave Russell" wrote in message m... A friend of mine is curious: 1. If a runway is closed by NOTAM at a non-towered airport, does that mean that the adjacent *taxiway* can't be used to legally take-off and land? (I know the insurance company would have an opinion about this, also, but let's ignore that aspect for the moment.) Show me an FAR that requires you to use a runway for taking off and landing. 2. We all know about the minimum fuel requirement for take-off. If one were to land with less fuel in the tanks than the required reserve (and without a good reason for using part of the reserve), can the FAA violate you for negligence? If you are not allowed to use the reserve, what is it for? The reserve is in case of unforseen delays. The FAA might do almost anything, of course, but it is unlikely that they would violate you for negligence if you used part of your reserve due to unforeseen delays. |
"Dave Russell" wrote in message 1. If a runway is closed by NOTAM at a
non-towered airport, does that mean that the adjacent *taxiway* can't be used to legally take-off and land? Helicopters do it routinely. The antiques land in the grass along-side the runway routinely. Keep in mind that if you screw up, it will be much harder to plead your case. 2. We all know about the minimum fuel requirement for take-off. If one were to land with less fuel in the tanks than the required reserve (and without a good reason for using part of the reserve), can the FAA violate you for negligence? NTSB case law has demonstrated that if you burned some reserves in spite of doing proper fuel calculations during pre-flight planning, but otherwise landed safely, you won't be convicted. D. |
Capt.Doug wrote:
NTSB case law has demonstrated that if you burned some reserves in spite of doing proper fuel calculations during pre-flight planning, but otherwise landed safely, you won't be convicted. Is this a joke? When does the NTSB get involved post-safe-landing? Jack |
"Jack" wrote in message
... When does the NTSB get involved post-safe-landing? They are the first line of appeal for any FAA enforcement action. The FAA has been known to issue a violation against a pilot, even if the landing itself was safe. Most pilots would appeal a negative outcome, so the NTSB would get involved practically every time. That's when. Pete |
On Sun, 18 Jul 2004 23:10:54 -0700, "BTIZ"
wrote: when ASH was non towered.. the use of the old grass strip to the east of the runway was a normal occurrence.. and even more so when the runway was closed for resurfacing.. and then the heavy twins would use the taxiway.. with lots of radio calls... but way back then.. there was nothing north of the ASH tower.. NOTHING but the taxi way to the north end.. That resurfacing must have taken place prior to '76. But even now, the grass on the NE side of the runway still gets used from time to time. But they don't keep it up they way they used to. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
yes... actually that resurfacing would have been about that time..
I left ASH in 1982 and the new tower was not open then.. I was at NEAI/DWC from 1974-1977, earned my Private ASEL through NEAI in 1974 BT "Ron Rosenfeld" wrote in message ... On Sun, 18 Jul 2004 23:10:54 -0700, "BTIZ" wrote: when ASH was non towered.. the use of the old grass strip to the east of the runway was a normal occurrence.. and even more so when the runway was closed for resurfacing.. and then the heavy twins would use the taxiway.. with lots of radio calls... but way back then.. there was nothing north of the ASH tower.. NOTHING but the taxi way to the north end.. That resurfacing must have taken place prior to '76. But even now, the grass on the NE side of the runway still gets used from time to time. But they don't keep it up they way they used to. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
| FAA won't fine erratic drunk pilot - Philadelphia | Jeff | Piloting | 0 | April 1st 04 02:14 AM |
| Fine example of Tarver Engineering release for service | running with scissors | Military Aviation | 79 | March 3rd 04 02:48 PM |
| Fine example of Tarver Engineering release for service | running with scissors | Military Aviation | 7 | February 28th 04 06:07 PM |
| Piper Cub: "A Reflection in Time"... fine art print | highdesertexplorer | Aviation Marketplace | 0 | January 13th 04 04:47 AM |
| FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 09:32 PM |
