Distortion in headset - advice wanted
Old August 20th 04, 02:05 AM
Andrew Sarangan
Default Distortion in headset - advice wanted
The audio from the overhead speakers are fine, but the audio from the
headset is very weak. I have to turn the volume to max, but then I get
a lot of distortion and can hardly understand the transmission. The
results are the same from both radios. The problem is not with the
headset, because the results are the same on two different headsets.
The outgoing transmissions seem to be fine also.
Before I take the airplane to an avionics shop, I wanted to ask the
group if I am overlooking something obvious.
Old August 20th 04, 05:18 PM
Jon Kraus
Is the problem the same switching from COM1 to COM2 on the same
frequency? If so I would think that that would rule out the audio panel
and maybe narrow it to the radio itself. Just guessing though.
Jon Kraus
PP-ASEL-IA
(Student aircraft purchaser)
Old August 20th 04, 07:30 PM
Bill Denton
You may have already done this, but what you need to do is test your headset
without any other headsets plugged in.
Try the same thing with your other headset.
If both headsets work OK when they are plugged in separately, your problem
may be an impedance mismatch.
Try to borrow another headset exactly like your primary headset, and plug
both of them in at the same time. If that works OK, it probably is an
impedance mismatch problem.
If you do find an impedance mismatch, the simplest solution is to just make
sure all of your headsets are identical. Or, you can check the manufacturers
spec sheets and make sure whatever you buy is close in impedance to what you
have.
"Andrew Sarangan" wrote in message
om...
Old August 21st 04, 02:15 PM
Andrew Sarangan
The audio got so bad that I could not make out any incoming
transmissions. I annoyed a I took it to an avionics ship, and it
turned out to be a bad capacitor behind the audio panel. It got fixed,
but it cost me $300.
"Bill Denton" wrote in message ...
have.
om...
WANTED! David Clark Headset [email protected] General Aviation 0 December 29th 04 05:24 PM
WANTED! David Clark Headset [email protected] Aviation Marketplace 0 December 29th 04 05:23 PM
WANTED! David Clark Headset [email protected] Owning 0 December 29th 04 05:23 PM
Headset wanted - prefer David Clark Marty from Sunny Florida Aviation Marketplace 0 October 5th 04 02:54 PM
Headset wanted Mike Cunningham Aviation Marketplace 0 August 25th 03 01:26 AM
