Does anybody know of any wind-tunnel tests for analysis of tie-down
behaviour? I tried a google search without much success. Having seen the Charley pictures from Orlando Executive and Punta Gorda, I'm wondering if we are doing the right thing. The standard for tricycle gear GA planes seems to be wings and tail. Having been to my own airport, I can see that most of the tail ropes are usually the rattiest you can find. Besides, even if the tail tiedown holds, it does nothing to prevent the A/C rotating on the main gear and bouncing onto the tail and back onto the nose gear until one or the other gives way. I am also wondering that even if the tail tiedown stays tight, do the forces become great enough such that the fuse breaks at its weakest point, somewhere just in front of the tail feathers? Thus I wonder if leaving the tail loose, and tieing down at the nose gear would make more sense. I don't see this as putting more pressure on the wing-tiedowns because I feel that a tied-down tail would have given way anyway, long before the wings reach any sort of critical point. It would be interesting to have wind-tunnel tests (at various directions to the a/c longitudinal axis) to see the effects on different tie-down methods. |
![]() "Icebound" wrote in message news ![]() The standard for tricycle gear GA planes seems to be wings and tail. Having been to my own airport, I can see that most of the tail ropes are usually the rattiest you can find. Besides, even if the tail tiedown holds, it does nothing to prevent the A/C rotating on the main gear and bouncing onto the tail and back onto the nose gear until one or the other gives way. More than that, if the plane is allowed to rotate, the wing can generate enough lift to break a rope or, perhaps worse, cause structural damage to the airframe if the rope holds. Gliders are often tied down with the tail raised just high enough for the wing to present a zero AOA for just this reason. Glider owners often also add a front tiedown rope to the tow hook to ensure that the nose can't raise in a wind. I suppose a tiedown to the nosegear of a trigear plane could serve that same function, but I might talk to an A&P first. I have also seen some innovative strap-on spoilers on parked gliders, and even power planes as large as DC-3s, that are obviously intended to reduce the lift on the airframe and keep the plane on the ground in high winds. I am also wondering that even if the tail tiedown stays tight, do the forces become great enough such that the fuse breaks at its weakest point, somewhere just in front of the tail feathers? Never seen it happen. Thus I wonder if leaving the tail loose, and tieing down at the nose gear would make more sense. Only if you can guarantee that the wind will always be coming from the front of the plane. Vaughn |
![]() "Vaughn" wrote in message ... "Icebound" wrote in message news ![]() I am also wondering that even if the tail tiedown stays tight, do the forces become great enough such that the fuse breaks at its weakest point, somewhere just in front of the tail feathers? Never seen it happen. Neither have I in person, but some of the pictures from Punta Gorda seem to suggest that it might. Thus I wonder if leaving the tail loose, and tieing down at the nose gear would make more sense. Only if you can guarantee that the wind will always be coming from the front of the plane. I am not sure I understand why direction is an issue? In the typical small-GA gust-lock, the tail is set for slight "down elevator". If the wind is from the front, lifting the tail, that forces the nosewheel down and its not going anywhere except into the pavement. If the wind is from the rear, that would force the tail down, and thats why the suggestion of nose-gear tie-down to prevent the A/C from rotating on the mains. I would argue that a *tail* tiedown actually expects wind from the front, and that it is useless when the wind is from the rear...... |
All the Cherokees of the world seem to use the seatbelt as a gust lock,
which ties the yoke back in full up-elevator and about half aileron deflection. Seems like this would be terrible in high winds. "Icebound" wrote in message news ![]() "Vaughn" wrote in message ... "Icebound" wrote in message news ![]() I am also wondering that even if the tail tiedown stays tight, do the forces become great enough such that the fuse breaks at its weakest point, somewhere just in front of the tail feathers? Never seen it happen. Neither have I in person, but some of the pictures from Punta Gorda seem to suggest that it might. Thus I wonder if leaving the tail loose, and tieing down at the nose gear would make more sense. Only if you can guarantee that the wind will always be coming from the front of the plane. I am not sure I understand why direction is an issue? In the typical small-GA gust-lock, the tail is set for slight "down elevator". If the wind is from the front, lifting the tail, that forces the nosewheel down and its not going anywhere except into the pavement. If the wind is from the rear, that would force the tail down, and thats why the suggestion of nose-gear tie-down to prevent the A/C from rotating on the mains. I would argue that a *tail* tiedown actually expects wind from the front, and that it is useless when the wind is from the rear...... |
Like Vaughn said:
" More than that, if the plane is allowed to rotate, the wing can generate enough lift to break a rope or, perhaps worse, cause structural damage to the airframe if the rope holds." Back in 1985, when hurricane Gloria hit Long Island MacArthur APT, we found an Archer that had "flown" into a drainage sump, some 200 feet away from its tiedown spot. The wing tiedown rings had actually broken! One could have used the best ropes/chains in the world, and it wouldn't have mattered. for just this reason. "Vaughn" wrote in message ... "Icebound" wrote in message news ![]() The standard for tricycle gear GA planes seems to be wings and tail. Having been to my own airport, I can see that most of the tail ropes are usually the rattiest you can find. Besides, even if the tail tiedown holds, it does nothing to prevent the A/C rotating on the main gear and bouncing onto the tail and back onto the nose gear until one or the other gives way. More than that, if the plane is allowed to rotate, the wing can generate enough lift to break a rope or, perhaps worse, cause structural damage to the airframe if the rope holds. Gliders are often tied down with the tail raised just high enough for the wing to present a zero AOA for just this reason. Glider owners often also add a front tiedown rope to the tow hook to ensure that the nose can't raise in a wind. I suppose a tiedown to the nosegear of a trigear plane could serve that same function, but I might talk to an A&P first. I have also seen some innovative strap-on spoilers on parked gliders, and even power planes as large as DC-3s, that are obviously intended to reduce the lift on the airframe and keep the plane on the ground in high winds. I am also wondering that even if the tail tiedown stays tight, do the forces become great enough such that the fuse breaks at its weakest point, somewhere just in front of the tail feathers? Never seen it happen. Thus I wonder if leaving the tail loose, and tieing down at the nose gear would make more sense. Only if you can guarantee that the wind will always be coming from the front of the plane. Vaughn |
Why not the "Belt and Suspenders" approach? Tie both ends down.
Stu Fields (Helicopters have problem with just tying down the rear blade) "Icebound" wrote in message news ![]() Does anybody know of any wind-tunnel tests for analysis of tie-down behaviour? I tried a google search without much success. Having seen the Charley pictures from Orlando Executive and Punta Gorda, I'm wondering if we are doing the right thing. The standard for tricycle gear GA planes seems to be wings and tail. Having been to my own airport, I can see that most of the tail ropes are usually the rattiest you can find. Besides, even if the tail tiedown holds, it does nothing to prevent the A/C rotating on the main gear and bouncing onto the tail and back onto the nose gear until one or the other gives way. I am also wondering that even if the tail tiedown stays tight, do the forces become great enough such that the fuse breaks at its weakest point, somewhere just in front of the tail feathers? Thus I wonder if leaving the tail loose, and tieing down at the nose gear would make more sense. I don't see this as putting more pressure on the wing-tiedowns because I feel that a tied-down tail would have given way anyway, long before the wings reach any sort of critical point. It would be interesting to have wind-tunnel tests (at various directions to the a/c longitudinal axis) to see the effects on different tie-down methods. |
Kathryn & Stuart Fields wrote:
Why not the "Belt and Suspenders" approach? Tie both ends down. Stu Fields (Helicopters have problem with just tying down the rear blade) "Icebound" if you expect really bad winds, support the tail, AND tie it down, -- Mark Smith Tri-State Kite Sales http://www.trikite.com 1121 N Locust St Mt Vernon, IN 47620 1-812-838-6351 |
![]() "Mark Smith" wrote in message ... Kathryn & Stuart Fields wrote: Why not the "Belt and Suspenders" approach? Tie both ends down. Stu Fields (Helicopters have problem with just tying down the rear blade) "Icebound" if you expect really bad winds, support the tail, AND tie it down, -- I can see the point, but the support-structure-pylon-whatever would also have to be securely captured to the pavement, or it too may become another piece of 100-mph-horizontal-debris amongst the field of A/C. |
In article , Mark Smith
wrote: Kathryn & Stuart Fields wrote: Why not the "Belt and Suspenders" approach? Tie both ends down. Stu Fields (Helicopters have problem with just tying down the rear blade) "Icebound" if you expect really bad winds, support the tail, AND tie it down, And, ductape some makeshift spoilers to the wings: some 8 ft pieces of 2x2, taped ahead of the spar line, secured with about 8, 2 ft strips of 2" ductape (top surface) will secure it, provided that there is no dirt on the wing. |
Orlando Executive airport after Charley hit | Gilan | Owning | 28 | August 29th 04 05:22 AM |
Orlando Executive airport after Charley hit | Gilan | Piloting | 28 | August 29th 04 05:22 AM |
Yeah! I'm back online..No thanks to Charley. | CFLav8r | Piloting | 10 | August 24th 04 04:14 AM |
Is Charley telling us anything about A/C tie-down? | Icebound | Home Built | 22 | August 23rd 04 07:38 PM |
GA Airport center for Charley relief | Bob Chilcoat | Piloting | 4 | August 19th 04 04:04 PM |
