A question for the future
Old September 15th 04, 05:03 AM
B25flyer
Default A question for the future
Over a period of time aviation seems to make changes due to technical advances.
As such in the past certain "basics" of aviation that were once written in
stone have gone by the wayside.
So here is one for ya. Last week I started a student on the ground school
basics of cross country planing. Draw the line on the sectional from airport to
airport. Discuss all the wind, magnetic and other variables etc. After about 20
minutes into the discussion the students 13 year old daughter who was intently
watching asked the question. "Why do all that when I can do the same thing in
30 seconds on the handheld GPS and enroute it will take care of the wind
correction"
Got me to thinking. So question is, what is the opinion of the troops as to
when the system will change and as part of the written/PTS for any rating there
will no longer be the requirment to draw the line and figure out all the other
stuff for the X-C portion of the test. Just put in airports/waypoints and go
for it.
Five years? Ten years? Or will it stick around forever?
Walt
Forty+ years as a CFI and still drawing lines on sectionals.
Old September 15th 04, 05:42 AM
Brien K. Meehan
wind
correction"
Troll.
Walt
Yeah, right.
Old September 16th 04, 04:10 AM
Morgans
"Brien K. Meehan" wrote
Troll.
You need to stick around for a bit longer, before you jump with a post like
this. I can assure you that the poster has been around for years, and is
not a troll.
Are you a troll?
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.762 / Virus Database: 510 - Release Date: 9/13/2004
Old September 15th 04, 05:50 AM
G. Burkhart
"B25flyer" wrote in message
to
there
other
go
for it.
Good question. Personally, I don't think that all planes will ever be GPS
equipped just as all the current flying planes don't have nav radios,
transponders or even electrical systems.
My aircraft doesn't have a transponder or a nav radio, haven't needed them,
yet. I do use a GPS for some of the navigation but mostly rely on dead
reckoning.
Keep drawing those lines on the sectionals and teaching it that way. GPS's
can go Tango Uniform and then where are you...
Old September 15th 04, 02:27 PM
Marco Leon
My guess is that it will be well on its way of change when the new Cessna
172's and Piper Warriors coming out next year with the glass cockpits become
the standard "used aircraft" on the common market. Let's say, oh 20-30 years
or so. We are starting to see it with the TAA initiative and I suspect it
will gradually creep into the FAA mindset. We will also see training for
absolete navigational systems fall off the PTS one by one (the next probably
being NDB/ADF).
Marco Leon
advances.
airport to
about 20
intently
in
correction"
to
there
other
go
for it.
Walt
Old September 15th 04, 03:37 PM
C J Campbell
to
there
other
Where is this requirement to draw a line or use an E6-B in the practical
test standards? It appears to me that the applicant could use FliteStar or
Cirrus or any other computer based flight planner. The applicant is required
to compute headings, fuel flow, etc. Nothing in the standard requires the
use of a whiz wheel or plotter. The FAA does not appear to care if the
applicant uses the E6-B, his Cray supercomputer, or a Ouija board. Now, that
said, I don't think it is necessarily true that using computer based flight
planning is any easier or less time consuming than doing it manually. The
answers had better be right. Anyway, here is the standard:
D. TASK: CROSS-COUNTRY FLIGHT PLANNING (ASEL and ASES)
REFERENCES: 14 CFR part 91; AC 61-23/FAA-H-8083-25, AC 61-84;
Navigation Charts; A/FD; AIM.
Objective. To determine that the applicant:
1. Exhibits knowledge of the elements related to cross-country flight
planning by presenting and explaining a pre-planned VFR crosscountry
flight, as previously assigned by the examiner. On the day of
the practical test, the final flight plan shall be to the first fuel stop,
based on maximum allowable passengers, baggage, and/or cargo
loads using real-time weather.
2. Uses appropriate and current aeronautical charts.
3. Properly identifies airspace, obstructions, and terrain features.
4. Selects easily identifiable en route checkpoints.
5. Selects most favorable altitudes considering weather conditions and
equipment capabilities.
6. Computes headings, flight time, and fuel requirements.
7. Selects appropriate navigation system/facilities and communication
frequencies.
8. Applies pertinent information from NOTAMs, AF/D, and other flight
publications.
9. Completes a navigation log and simulates filing a VFR flight plan.
Old September 15th 04, 03:46 PM
Neil Gould
Recently, B25flyer posted:
(mostly snipped for brevity)
advances. As such in the past certain "basics" of aviation that were
once written in stone have gone by the wayside.
as to when the system will change and as part of the written/PTS for
any rating there will no longer be the requirment to draw the line
and figure out all the other stuff for the X-C portion of the test.
Just put in airports/waypoints and go for it.
IMO, this misses the point entirely. There are several important lessons
imbedded in the apparently simple task of X-C planning.
-- The basic idea of planning. Every aspect of the flight has to be taken
into consideration. For the instructor, I'd imagine that it would provide
some good insights into how the student is approaching aviation. Those
that would forego planning and rely on short-cuts can probably benefit
from *more* instruction, not less.
-- Tracking your progress on a chart is still a good practice. The
simplified GPS view is not all you need to know during an X-C. Even if the
GPS has terrain info, it's unlikely to include all of the details on a VFR
chart.
-- Bottom-line safety. Why teach "engine out" routines, when the
likelihood of an engine failure is fairly remote (I'd argue that an
electrical failure that would take out the GPS is more likely)?
I think that it's for good reason that the GPS is considered an addendum,
and not a replacement for other nav aids. There may be some point in the
future when this has changed, but it isn't here yet.
Regards,
Neil
Old September 15th 04, 03:57 PM
C J Campbell
"Neil Gould" wrote in message
ink.net...
There are no nav aids required for VFR other than a compass. You can use
your handheld GPS if you want and nothing else. GPS alone may not be used
for IFR flight, but WAAS is a stand-alone replacement for all other
navigation aids for IFR.
Old September 15th 04, 05:32 PM
Neil Gould
Recently, C J Campbell posted:
addendum, and not a replacement for other nav aids. There may be
some point in the future when this has changed, but it isn't here
yet.
That is pretty much my point. But, the only way the compass is useful
during VFR X-C is if you can do the rest of the planning. Wind, magnetic
variation, etc. can affect whether you'll get to where you want to go. The
X-C planning skill set is not just busy-work.
Neil
Old September 15th 04, 04:30 PM
C J Campbell
in
correction"
Answering this question separately:
You can't pick up fuel enroute.
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Future military fighters and guns - yes or no ? championsleeper Military Aviation 77 March 3rd 04 04:11 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
