Engine for home built
Old September 15th 04, 03:58 PM
Chris Gumm
Default Engine for home built
I'm putting together some numbers for a homebuilt kit. I'm looking at the
RV-7a, Glasair SII RG and Glasair III. Both of the web sites mention
Lycoming engines but from going though the AOPA Pilot mag, there seams to be
a lot more choices. Are the other engine manufactures any good? Is Lycoming
the only way to go? All the aircraft that I've flown have had Lycoming
engines.
Old September 15th 04, 04:02 PM
john smith
Should be lots of available engines coming out of Florida now or very soon.
engines.
Old September 16th 04, 12:52 AM
Kyle Boatright
"Chris Gumm" wrote in message
be a lot more choices. Are the other engine manufactures any good? Is
Lycoming the only way to go? All the aircraft that I've flown have had
Lycoming engines.
I'm sure you'll get varying opinions on the quality of "other" engines. The
real question you need to ask is whether the kit you're interested in
supports engines other than Lycoming. As an RV builder, I can tell you that
if you substitute anything other than a Lycoming, it'll add hundreds of
hours to your project. Instead of buying off the shelf cables, exhausts,
cowlings, engine mounts, etc., you'll need to build your own. Some of that
stuff is beyond the ability of most homebuilders, and even if you have the
skill to fabricate those items from scratch, it will still add a serious
amount of effort to your project. Beyond that, your airplane will be
somewhat of a freak and probably won't have the resale value that a "normal"
example would have.
KB
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Emergency Procedures RD Piloting 13 April 11th 04 08:25 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
