I will be flying a C-340 IFR into PHX from the Los Angeles area via Blythe
and out of PHX to Sedona. Can anyone provide any likely arrival and departure routings? Norman Schwartz www.nsapc.com .. |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 NS wrote: I will be flying a C-340 IFR into PHX from the Los Angeles area via Blythe and out of PHX to Sedona. Can anyone provide any likely arrival and departure routings? Norman Schwartz www.nsapc.com Lessee... Depending on from where in the LA Area you're leaving, You're looking at TRM-BLH-BLH4 or TRM-BLH-ARLIN3 into PHX. This is the perferred route into the Sun Valley area, so you'll be flying along with every other major carrier with a Los Angeles area flight to PHX. You could avoid this, by going the southern route, via OCN-JLI-IPL-BZA-MOHAK.ARLIN3. However, depending on how high you fly, you'll need the proper route (FL230 and lower will use BLH4; FL240 and higher will use ARLIN3). My suggestion, is to avoid the traffic as much as possible, take the southern route to avoid the mountains/density, and fly the ARLIN arrival in. As for KSEZ... If you're directly flying out of PHX, you have your choice of the vectored or RNAV procedures. If you go RNAV, be sure you're either /E, /F, /G, or /R equipped. Otherwise, use the vectored departures. My suggestion: PHX SILOW1.SILOW direct. You can stay low on this one, as the departure procedure is geared towards props. But once you hit SILOW, a left turn to join the FLG R-183 inbound will take you directly to the field. Those are my thoughts, going directly off your question. Anyone else more in the PHX area want to chip in? BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.2.6 (GNU/Linux) iD8DBQFBSNTCyBkZmuMZ8L8RAlMyAKC+AeBrXM0JdiwMY681w9 FXpCVYJwCg7Fyr YJOhxL9D/uO5HlNOTN5/MVw= =O5fK -----END PGP SIGNATURE----- |
Thank you for the informative reply on IFR routings to PHX from the LA area.
I do wish to avoid the commerical traffic and planned to file SLI -V64-Blythe-V16- Buckeye. The Arlin Three and Blythe Four arrivals appeared to be designed for the turbo's. The plane is /G and I most likely will file the Silow One departure to Silow. Norman Schwartz www.nsapc.com |
"NS" wrote:
Thank you for the informative reply on IFR routings to PHX from the LA area. I do wish to avoid the commerical traffic and planned to file SLI -V64-Blythe-V16- Buckeye. The Arlin Three and Blythe Four arrivals appeared to be designed for the turbo's. The plane is /G and I most likely will file the Silow One departure to Silow. Norman Schwartz www.nsapc.com For Sedona, if the weather's good (and it usually is), why not just go VFR? Just climb out to 6500 or so, and enjoy the scenery. Just aim for the San Francisco peaks and Sedona is right on the direct path to FLG. The MEA's are so high, going IFR is really more trouble than it's worth for such a short trip. Mike |
