please excuse my dumbness,but just what is "IFR certification" when
used in the context such as "What was the date of your last IFR certification?" if your aircraft has all required instruments and you have complied with FAR 91.411 regarding static, transponder, and altimeter tests within last 24 months; then what else is needed? tia john |
that should do it..
unless perhaps your GPS data base may be out of date.. BT "john freeman" wrote in message ... please excuse my dumbness,but just what is "IFR certification" when used in the context such as "What was the date of your last IFR certification?" if your aircraft has all required instruments and you have complied with FAR 91.411 regarding static, transponder, and altimeter tests within last 24 months; then what else is needed? tia john |
On Mon, 20 Sep 2004 20:29:41 -0400, john freeman wrote:
please excuse my dumbness,but just what is "IFR certification" when used in the context such as "What was the date of your last IFR certification?" if your aircraft has all required instruments and you have complied with FAR 91.411 regarding static, transponder, and altimeter tests within last 24 months; then what else is needed? 30-day VOR check. Perhaps "certification" is being incorrectly used to mean "IFR currency", meaning the date you last completed your required 6 actual or simulated approaches (and VOR intercept, tracking and holding procedures), or instrument proficiency check? |
![]() "john freeman" wrote in message ... please excuse my dumbness,but just what is "IFR certification" when used in the context such as "What was the date of your last IFR certification?" if your aircraft has all required instruments and you have complied with FAR 91.411 regarding static, transponder, and altimeter tests within last 24 months; then what else is needed? Nothing. The transponder/static/encoder checks is what people typically mean with IFR "certification". The real IFR certification happens when the type certificate is approved and never expires :-). |
You can take a "no radio" aircraft and upgrade it to "full IFR capable". I
think this requires some sort of sign-off. Conversely, you could remove all of the radios from an aircraft and it would no longer meet IFR requirements. I imagine some sort of "decertification" is necessary. I doubt that the type certificate enters into it at all... "Ron Natalie" wrote in message m... "john freeman" wrote in message ... please excuse my dumbness,but just what is "IFR certification" when used in the context such as "What was the date of your last IFR certification?" if your aircraft has all required instruments and you have complied with FAR 91.411 regarding static, transponder, and altimeter tests within last 24 months; then what else is needed? Nothing. The transponder/static/encoder checks is what people typically mean with IFR "certification". The real IFR certification happens when the type certificate is approved and never expires :-). |
![]() "Bill Denton" wrote in message ... You can take a "no radio" aircraft and upgrade it to "full IFR capable". I think this requires some sort of sign-off. You certainly can provided the type certificate does not preclude it. Conversely, you could remove all of the radios from an aircraft and it would no longer meet IFR requirements. I imagine some sort of "decertification" is necessary. Nonsense. I doubt that the type certificate enters into it at all... The type certificate very much enters into it. If the type certificate says DAY VFR only or lists specific equipment that is required for IFR flight, this is what you have to do. If the type certificate doesn't have any such limitations, then only equipment and inspection requirements in part 91 matter. |
"Bill Denton" wrote
You can take a "no radio" aircraft and upgrade it to "full IFR capable". I think this requires some sort of sign-off. Radio installation has nothing to do with the aircraft being certificated for IFR operation on its original type certificate. "No radio" IFR operation in uncontrolled airspace is completly legal. I doubt that the type certificate enters into it at all... The type certificate (or a supplement) is ALL that matters in addition to the usual Part 91 transponder/static checks. You will find that the POH or FM will list the approved types of operation and for most production aircraft these include DAY/NIGHT and VFR/IFR. Bob Moore |
![]() "Bob Moore" wrote in message You will find that the POH or FM will list the approved types of operation and for most production aircraft these include DAY/NIGHT and VFR/IFR. Make that MAY list. Depending on when/how the aircraft is certficated it may or may not spell out restrictions/requirements for NIGHT and IFR flight. |
You can take a "no radio" aircraft and upgrade it to "full IFR capable". I think this requires some sort of sign-off. Conversely, you could remove all of the radios from an aircraft and it would no longer meet IFR requirements. I imagine some sort of "decertification" is necessary. I doubt that the type certificate enters into it at all... The type certificate states whether the plane can be flown IFR. The certification testing includes hitting it with lightening (in a secure room) and seeing how the electrons move around the plane. This has become a challenging thing for the new composite planes. Most every plane that you will see sitting on the FBOs ramp has met this requirement. Some planes certified by the old CAA may be graced though. There is no requirement to have radios to fly IFR. -Robert |
Let's look at this last-to-first. You stated: "There is no requirement to
have radios to fly IFR." First of all, this statement is far too broad. Which radios are you referring to? COM, NAV, ADF, ELT, LORAN, GPS, or something else? And that statement is just plain false! See FAR 91.205: (d) Instrument flight rules. For IFR flight, the following instruments and equipment are required: (2) Two-way radio communications system and navigational equipment appropriate to the ground facilities to be used. That looks pretty clear to me: you DO have to have radios on board to fly IFR. On the next part of this post, you state: "The type certificate states whether the plane can be flown IFR." That is not correct. What the type certificate says is that the plane has met ONE of the sets of criteria required for it to be used for IFR flight. A plane cannot be flown IFR unless it has IFR on the type certificate, but just because a plane has IFR on the type certificate doesn't mean it can be flown IFR. The other requirements must also be met. A brand new aircraft rolling out of the factory with IFR on the type certificate but with no radios cannot be flown IFR... "Robert M. Gary" wrote in message om... "Bill Denton" wrote in message ... You can take a "no radio" aircraft and upgrade it to "full IFR capable". I think this requires some sort of sign-off. Conversely, you could remove all of the radios from an aircraft and it would no longer meet IFR requirements. I imagine some sort of "decertification" is necessary. I doubt that the type certificate enters into it at all... The type certificate states whether the plane can be flown IFR. The certification testing includes hitting it with lightening (in a secure room) and seeing how the electrons move around the plane. This has become a challenging thing for the new composite planes. Most every plane that you will see sitting on the FBOs ramp has met this requirement. Some planes certified by the old CAA may be graced though. There is no requirement to have radios to fly IFR. -Robert |
Adding IFR Plane Certification To Planes Without It | Blanche Cohen | Owning | 10 | November 29th 04 06:37 PM |
Aircraft certification questions. | psyshrike | Home Built | 40 | November 22nd 04 06:10 PM |
Aircraft certification questions. | psyshrike | Owning | 42 | November 22nd 04 06:10 PM |
certification of composite aircraft | sebastian | Home Built | 6 | March 25th 04 03:48 PM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
